ntsb report
Old March 29th 05, 12:30 AM
A Lieberman wrote:
Check out the CFI number in the report.
I don't know the time frame, but I believe the certificate numbers were
SSN's before identity thief became a problem.
They started using SSNs for airman certificates in the late 1960s or early
1970s. Before that it was just an FAA-assigned number.
Old March 29th 05, 01:37 AM
Gary Drescher
On Mon, 28 Mar 2005 13:24:59 -0500, "Gary Drescher"
ink.net...
One cannot be above clouds and have VMC upon reaching controlled
airspace
at 700' AGL, VFR cloud clearance requires a minimum of 1000' above
clouds.
Good point. So the puzzle here is not why the pilot was found to have been
careless and reckless, but rather why he *wasn't* found to have knowingly
entered controlled airspace in IMC without a clearance.
--Gary
Maybe he didn't.
Maybe he stayed below 700' until he got into an area where the
uncontrolled airspace went to 1200', or the fog was not a factor.
Well, the report says the pilot says he entered controlled airspace at 700'.
But you're right, there might not have been clouds below him by then.
--Gary
Old March 29th 05, 04:25 AM
Ron Garret
In article t,
"Steven P. McNicoll" wrote:
"Ron Garret" wrote in message
The pilot's contention is that he was operating legally under IFR
without a clearance because the regs require a clearance for IFR only in
controlled airspace. But the controlled airspace only went up to 700
AGL, and the pilot had no way of knowing for sure that the tops of the
clouds were lower than that. But he took off anyway, technically not
violating a reg by doing so, but gambling that he would be able to
complete the flight without violating a reg. That sure sounds careless
and reckless to me.
You state the controlled airspace only went up to 700 AGL. I assume that's
a typo, it was uncontrolled airspace from the surface to 700' AGL.
Yes, that's what I meant (obviously).
One cannot be above clouds and have VMC upon reaching controlled airspace at
700' AGL, VFR cloud clearance requires a minimum of 1000' above clouds.
Good point.
rg
Old March 29th 05, 06:53 AM
Hilton
cfeyeeye wrote:
You are wrong - it is NOT a no-no.
The NTSB report acknowledges as such. He was held in violation of the
catch-all "careless and negligent", which only exists so that the FAA
can bust pilots when they haven't really violated a regulation.
OK, let's look at this situation. You are out with friends at the movies.
You walk outside and visibility has dropped significantly. You hop in your
car, and your two friends hop in literally putting their lives in your
hands. You manage to drive slowly enough to find the freeway. It is a
single-lane two-way freeway. You accelerate to 65 mph and drive on home.
Careless? Negligent?
From dictionary.com:
1.. Taking insufficient care; negligent: a careless housekeeper; careless
proofreading.
2.. Marked by or resulting from lack of forethought or thoroughness: a
careless mistake.
3.. Showing a lack of consideration: a careless remark.
4.. Unconcerned or indifferent; heedless: careless of the consequences.
5.. Unstudied or effortless: danced with careless grace.
6.. Exhibiting a disposition that is free from cares; cheerful: a careless
grin; a careless wave of the hand.
Hilton
Old March 29th 05, 02:21 PM
As well as comply with 91.177.
Old March 29th 05, 02:38 PM
Steven P. McNicoll
wrote in message ...
They cannot both apply. If the pilot claims to be VFR upon reaching
controlled airspace FAR 91.177 does not come into play at all.
Old March 30th 05, 02:52 PM
My comment pertains to the pilot actually reaching VFR conditions. His claim
may not be valid, thus 91.177 becomes pertinent if he were to level off less
than 1,000 on top or with less than 3 miles flight visibility.
  #29
Old March 30th 05, 03:44 PM
Steven P. McNicoll
claim
less
That's not correct either. He was in uncontrolled airspace until he reached
700' AGL and he broke out between 100' and 200' AGL. Had he remained below
700' AGL he's have been in VMC and FAR 91.177 would not apply.
  #30
Old March 30th 05, 04:25 PM
claim
less
You're speaking of the specific case and I am speaking of the general
circumstances of doing such an operation. You have to be prepared to comply
with 91.177. We have lots of places out west where Class E overlies a Class G
airport well above 91.177 altitudes.
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Looking for a See and Avoid NTSB report Ace Pilot Piloting 2 June 10th 04 01:01 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
Senator asks Navy for report on pilot Otis Willie Naval Aviation 0 July 17th 03 10:08 PM
