Shear Pins for Propellors?
Old April 2nd 05, 05:13 PM
The shear pin would fail at idle. The propeller on an airplane
is the engine's flywheel, and its inertia carries the crankshaft
between power strokes and smoothes its rotation. There's a
reciprocating force between the prop and crank flange, therefore, and
ANY looseness between the two will result in forces that will fail
attaching hardware. There have been cases of six 7/16" prop bolts
breaking when they weren't tight enough. There have been cases of
charring of wooden props when they weren't tight enough; the friction
created by small amounts of movement between the prop and flange heats
the wood. Props use six or eight substantial bolts for a reason: to
keep the thing on there tight. A shear pin in the system requires
looseness in the drive, and it just won't work. This isn't a boat ot
tractor. Imagine the damage when the flywheel of an outboard motor,
auto or tractor engine is a little loose.
Further, a sudden stop of the prop also pulls the crank radially
as the weight of the prop at its free end tries to keep moving. The
crank gets bent anyway, or the case fails, or engine mounts are
damaged. Any forward movement bends the prop backwards, too.
Dan
Old April 3rd 05, 01:44 AM
This system would also allow the prop to windmill without attempting
to turn the
engine in cases of engine failure.
So what do we do for a flywheel?
Dan
Old April 2nd 05, 10:10 PM
David CL Francis
On Fri, 1 Apr 2005 at 02:32:55 in message
.net, Rich Lemert
This morning, while driving past the airport on my way to work, the
thought occured to me that a shear pin could be used to protect
airplane engines (at least partially) from prop strikes. My
understanding is that the props on light singles (at least) are
connected directly to the engine's drive shaft
It occurs to me that a shear pin could only work effectively against a
rotational stoppage. Since a normal prop either fits over a crankshaft
end or is bolted to a plate, a shear pin could do little or nothing.
What loading cases would you propose for the shear pin failure?
In a minor accident which way are the prop tips usual bent?
I somehow feel that the possibility of a prop detaching in flight should
not be encouraged. :-)
David CL Francis
Newbie question on trailering Setup joe Soaring 11 December 26th 04 11:10 PM
sound of wind shear Dan Jacobson General Aviation 2 May 11th 04 11:43 PM
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 08:48 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 10:23 PM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
