#21
Bruce Hoult wrote:
That seems silly. Sure, taking some random aircraft and using it to tow a glider would be a silly idea, but surely it's ok to design and build your own experimental aircraft for the specific purpose of towing gliders! If this was the only silly FAA rule, perhaps it would be worth worrying about. I seem to recall an experimental aircraft called "White Knight" air-dropping a glider called "SpaceShipOne", with the FAA administrator present. Ah, but that did not fit the definition of a "glider tow". In fact, it does not fit definition of any form of glider launch currently recognized by the FAA (i.e., aero tow, ground launch, or self-launch), so the pilots weren't required to have a launch type endorsement... Marc |
The Zenair CH601XL SLSA has an O-200.
With 800# empty weight, one pilot and light fuel, I wonder what it would tow... At 300# under max gross, it may just get over the trees towing 800# or less. 2 people in a 1000#+ aircraft, hmmm...pretty doubtful there. I have yet to believe an RV-9 under 1000# empty can be built with any engine bigger than a O-200. An inquiry to Van's confirmed that there are no plans to try to make any of the existing RV kits into SLSA or ELSA eligible aircraft. They are sturdy and capable, but a few hundred pounds past the 600kg limit. Flaps, engine weight, engine accessories, battery, and sturdy landing gear all add up. I think a good SLSA towplane would need to be made from the bottom up as a single seater. I don't see enough demand for a single-seat SLSA to make this likely. I'm not sure we will ever see a single seat SLSA airplane at all... At 01:00 07 April 2005, Bill Daniels wrote: 'Roy' wrote in message . com... Many thanks for all the advice and suggestions so far. Non of the suggestions were for other than standard (old) aircraft products. It has been suggested that an RV9 with a big motor (160-200hp) would be great to do the job. Anyone else considered this approach? We are not a commercial operation and dont have to pay our pilots. There is no insurance problem so this solution has some appeal. ie new airframe, easy repair & maintenance. 'Experimental - Amateur Built' aircraft will always have a 'No glider towing' paragraph in their operation limitations letter. However, Sport Light Aircraft under the new regs seem to have a loophole that allows glider towing for profit. Actually the key design parameter isn't the engine it's the propeller and after that, the wing. If you start with a prop optimized for max thrust at towing speed and then a wing optimized for that speed, the HP requirements go way down. This assumes that the prop RPM can be reduced by belts or gearing. Maybe somebody should cook up an SLA design optimized for towing. This would be a very efficient and very quiet airplane. Bill Daniels Mark J. Boyd |
Getting back to the original thread - what you need
my friend is a Turbo-Czmelak like they used at WGC2003. 1000ft/min+ with a fully loaded Nimbus4/4D/ASH25, throttled back I believe! |
Have you considered winch launching?
Mike Schumann "Roy" wrote in message om... Our operation has started the hunt for a new towplane. The main criteria is that from our 2200ft strip at sea level we need to have a two seater (janus) "over the fence" at 300ft in still air. What would you recommend? Dont dwell on purchase cost but rather performance/running costs We would consider a) Used b) New c) Experimental/anything else. Thanks for your thorts. |
Scott wrote in message ...
Uh, but I think you might be missing an important point. Experimental aircraft such as the RV series can't be used for hire. If the plane and pilot are provided free, and not compensated in any way, then it might be doable. I guess you'd have to find a pilot that is only interested in building time and not wanting to make money...I'm out ![]() Scott Scott Presume you haven't heard of that phenomina called Gliding Clubs, where volunteers act as instructors and others as towpilots... FOR FREE. I hear there are lots of them functioning around the world.:-)) AND gentlemen, wonder of wonders, there are other juristictions than the USA that have glider towing.....sometimes it appears that people presume only US residents read or contribute to this news group :-))) Well off to go flying on a great Noo Zeeland day. Yep its FRiday and the therms are popping. |
Roy wrote:
Presume you haven't heard of that phenomina called Gliding Clubs, where volunteers act as instructors and others as towpilots... FOR FREE. I hear there are lots of them functioning around the world.:-)) AND gentlemen, wonder of wonders, there are other juristictions than the USA that have glider towing.....sometimes it appears that people presume only US residents read or contribute to this news group :-))) Well off to go flying on a great Noo Zeeland day. Yep its FRiday and the therms are popping. Oh relax Roy. We'll get over ourselves as soon as we're done selling ourselves to the Chinese. Sometime around the second week of December. How were those upside down thermals? Shawn |
Glider - Towplane Signals | Mike the Strike | Soaring | 24 | March 26th 05 09:33 PM |
Performance World Class design proposal | iPilot | Soaring | 85 | September 9th 04 09:11 PM |
Complex / High Performance / Low Performance | R.T. | Owning | 22 | July 6th 04 08:04 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Super Cub towplane performance | Marc Arsenault | Soaring | 1 | July 11th 03 01:42 PM |
