#21
Keep in mind that a DME is a transmitter.
At some point in time, the transmitter final stage power transistors are going to die and need replaced. When they need replaced depends on how often you have it turned on. (PS... A new stack, eh? So does this mean the Navion will be at OSH this year? :-)) ) jsmith wrote: Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. Ron Natalie wrote: Maintenance? I've had a KN64 in my panel for over a decade. I haven't had any maintenance done to it. Now the rest of the King SC stack is a different story. The GS crumped and occasionally the displays on the KX155's fail. The transponder needs regular attention and the stupid ADF I am never certain if it is ever working. I'm in the middle of switching over to a Garmin stack, the only thing I'm keeping is the KN64. On the other hand, I'm not sure I'd go out of my way to install one if I didn't already have one. Back when I put it in, I knew it was likely to be the first casualty of the GPS era. |
"Ross Richardson" wrote in message ... jsmith wrote: Adam, that is what I did. I had a ADF that didn't work and no DME. I purchased a factory reconditioned KLN89/B and had it installed and removed the ADF. The 89/B is working for me althought a Garmin 530 would also me nice. Ross -- Regards, Ross ________________________________________ 972.952.3170 Phone 972.949.9249 Pager 972.952.2574 FAX McKinney / Wing A2 North @ 48v72 Ross, Since the original post, I've been looking at the KLN 89B. How do you like it? Is it certified for both enroute and approach? I was thinking of selling my Airmap 1000 to help finance the purchase. Is it good enough that I won't miss the moving map, etc? Adam N7966L Beech Super III P.S. Are you in McKinney, TX? That's where I bought my plane last October... |
mindenpilot wrote:
Since the original post, I've been looking at the KLN 89B. How do you like it? Is it certified for both enroute and approach? I was thinking of selling my Airmap 1000 to help finance the purchase. Is it good enough that I won't miss the moving map, etc? The Airmap has an obstruction database and all the airport data, since they are now selling for nearly half the price of what they once were, I'd hold on to it... |
On Sun, 03 Apr 2005 17:19:22 GMT, jsmith wrote:
Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. I beg to differ. My Cheap ******* IFR Upgrade circa-1980 KNS80 VOR/GS/DME unit has required ZERO maintenance in the 2 1/2 years since I had it installed. If it had been an IFR GPS, I would be poorer by about $1200 (i.e. $400/yr) for GPS database updates. So my KNS80 has essentially paid for itself ;-) The KNS80's are great units, and can be had for about half the cost the cheapest used IFR GPS units. Cheaper to install too. Ross Oliver Cheap ******* Aviator |
jsmith wrote:
Keep in mind that a DME is a transmitter. It is...but irrelevent. At some point in time, the transmitter final stage power transistors are going to die and need replaced. When they need replaced depends on how often you have it turned on. At some point ANY electronic component may die and require replacement. Transistor finals will last the lifetime of the airframe unless abused. |
mindenpilot wrote:
"Ross Richardson" wrote in message ... jsmith wrote: Adam, that is what I did. I had a ADF that didn't work and no DME. I purchased a factory reconditioned KLN89/B and had it installed and removed the ADF. The 89/B is working for me althought a Garmin 530 would also me nice. Ross -- Regards, Ross ________________________________________ 972.952.3170 Phone 972.949.9249 Pager 972.952.2574 FAX McKinney / Wing A2 North @ 48v72 Ross, Since the original post, I've been looking at the KLN 89B. How do you like it? Is it certified for both enroute and approach? I was thinking of selling my Airmap 1000 to help finance the purchase. Is it good enough that I won't miss the moving map, etc? Adam N7966L Beech Super III P.S. Are you in McKinney, TX? That's where I bought my plane last October... Yes, I work in McKinney and commute from 35 miles north. Small world. The 89/B is certified for enroute, terminal, and approach. It is old technology but works for me. The owners manual is poor. I got a couple of hours dual with an instructor that had knowledge in the unit and boght the John & Martha King videos on GPS and they use the 89/B as the example. Watched them several time. Keys I discovered: 1) must be in the flight plan mode ( not direct to) to get the approach to activate, and 2) I like the heading up (vs north up or trk up) mode and the moving map (it does have moving map) even as simple as it is, gives good infomation. I update via laptop getting the downloads from the internet.. You will need a enunciator panel and CDI to interface with it. I got a separate CDI (total of 3 now one each radio and GPS). Sure, I would like one of the new Garmins, but couldn't afford it. You can store flight plans, modify the plans you have in use, calculate TAS, wind driection, etc. I bought a factory reconditioned unit. Hope this helps. Ross Email me privately who you brought the plane from if you do not mind. |
Here's where I'm at now.
I was interested in checking out IFR GPS units as a DME alternative. You can get an older (KLN 89/B) unit pretty inexpensively. So I went to my local avionics guy and talked to him a bit. After explaining what I wanted to do, he actually recommended going the DME route. For an older GPS, I'd have to get another indicator to slave to it. He also said installation costs would go up as a result. He said the best solution (cost/complexity-wise) would be to pull my ADF and put in a DME. If the avionics guy is telling me this is lower cost/complexity, I guess I better think about it! So now I'm thinking of two choices. 1. Find an inexpensive DME. I'm thinking either Narco 890 or King 62/64. Definitely not a remote unit. 2. Find an inexpensive IFR GPS with built in CDI (kind of like a King KX-125 NAV). If anyone knows of such a GPS, I'd appreciate it. If anyone knows a source of great used avionics, I'd appreciate that, too. Oh yeah. One other alternative I was thinking of was using a KLN 89/B for enroute only, no approach. That is, using the GPS sort of like a DME. Is this legal? Can you do this? The only reason I ask is that I can find a KLN 89/B for less than a DME 64. Thanks, Adam N7966L Beech Super III |
mindenpilot wrote:
: 1. Find an inexpensive DME. I'm thinking either Narco 890 or King 62/64. : Definitely not a remote unit. : 2. Find an inexpensive IFR GPS with built in CDI (kind of like a King KX-125 : NAV). : If anyone knows of such a GPS, I'd appreciate it. : If anyone knows a source of great used avionics, I'd appreciate that, too. : Oh yeah. One other alternative I was thinking of was using a KLN 89/B for : enroute only, no approach. : That is, using the GPS sort of like a DME. : Is this legal? Can you do this? The only reason I ask is that I can find a : KLN 89/B for less than a DME 64. AFAIK, you can only legally use the distance information in an IFR GPS if it's actually IFR certified. That means that you need all the bells and whistles and an actual IFR cert. In other words, if it's old enough to be inexpensive, it also needs a dedicated CDI to go along with it. If you install an older IFR GPS as VFR-only, you can't legally use its distance info as a substitute for ADF/DME. As far as the DME goes, some of the units get their channeling from another NAV, and some can chose between that and dial-themselves. Wiring up the channeling to another nav will cost some labor on the install, as it's tedious and has to break into existing wiring. If you have the panel space and/or desire to go with the KNS-80, you get lots of functionality for the same or less than the DME only. Be aware, however, that it takes CDI head that doesn't have a NAV converter built-in, but sends out the OBS encoder to the unit. They're less common, and useful with IFR GPS installs, so they can be hard to come by. Lots of people have upgraded their KNS-80 to IFR GPS and kept the NAV head. Technically speaking, you could install the KNS-80 without an indicator and just use it as a slightly heavy, tall DME (or even a DME to an RNAV point, come to think of it... maybe even an ILS with a converter-head). -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Similar Threads | ||||
Phoenix FBO Recommendations | Robert Easton | Piloting | 5 | February 3rd 05 07:22 AM |
FBO Recommendations - Montreal | Jay Somerset | Piloting | 3 | February 1st 05 10:31 PM |
TSA's General Aviation Airport Security Recommendations Might Become Requirements | Larry Dighera | Piloting | 1 | February 25th 04 05:11 PM |
paint shop recommendations wanted (SE) | Stephen N Mills | Owning | 0 | January 29th 04 03:44 PM |
Extra Headset recommendations? | Mike Z. | Piloting | 1 | June 30th 03 10:02 PM |
