emergency chute
Old April 6th 05, 09:17 PM
Interesting... is this an active myth in skydiving circles? That some
chutes turn naturally into the wind?
Old April 6th 05, 09:50 PM
Michael
Aren't most BASE jumps done without a reserve?
Yes. This may be changing - I no longer actively BASE jump so I have
not kept up.
Do BASE jumpers prefer
the reserve square or the sport chute (since control into tight LZs
is
a consideration)?
BASE jumpers prefer a parachute designed for BASE. Before these were
available, most BASE jumpers used parachutes normally used as reserves
(the Raven series were quite popular). Some still use them. None used
anything even vaguely similar to the modern sport main canopy.
Michael
Old April 6th 05, 10:06 PM
Michael
I don't think you will find that there are any emergency
prachutes with square canopies, they are all round.
Not true. Both Relative Workshop and Strong make emergency rigs that
will accept square reserve canopies, and will sell them to you if you
convince them you know what you are talking about when you ask for one.
They're the only kind I use.
Square parachutes while offering more control
when open require the wearer to be in a stable position
when the chute is deployed, they are therefore less
reliable when deployed in anything other than a stable
attitude.
Not true. Square emergency parachutes are used with freebags (they
won't even have a bridle attach point), which allow deployment even if
the pilot chute or bridle entangles with the body of the jumper due to
an unstable opening. The same is not true of rounds, which are thus
more prone to 'horseshoe' malfunctions. Picture what that looks like -
if you really want to.
The Irvin EB** series were reputed to be the fastest
opening chutes in the world at one time and they certainly
use round canopies (I24). Maybe they still are, I hope
so cos that is what I have.
The primary factor affecting the speed of opening (assuming such
variables as airspeed, altitude, etc. are kept constant) is the volume
of air required to inflate the canopy. Square canopies need less air
to inflate, as they are smaller. The can be made smaller since they
generate lift, not just drag. Because of this, squares inflate much
quicker than rounds designed to carry the same loads - so quickly in
fact that all modern squares (other than those used for BASE jumping
from VERY low altitude - about 600 ft or less) are equipped with
sliders to slow the opening to something only a little faster than
rounds. Square sport canopies often have sliders that slow the opening
enough to make it 'comfortable' but the emergency parachutes have just
enough slider to keep you from breaking your back in a terminal
velocity opening.
There are actually only two advantages to rounds.
The first is cost - old obsolete technology is always cheaper. You can
pick up a serviceable round rig for a couple hundred dollars US; a
square rig will be newer and more expensive.
The second is the reduced need for training. The square parachute is a
wing. It must be flown and flared for a landing. Further, for various
reasons I will be happy to go into if anyone is interested, it doesn't
really fly and flare like a rigid wing. Finding yourself under one
with 30 seconds to figure out its flight characteristics and land it in
a suboptimal landing area is NOT the hot tip. Much as I dislike rules,
I would still recommend a training jump or two for anyone planning to
use a square rig without prior experience, as well as briefing from
someone who understands both ram-air wing and rigid wing aerodynamics
and can prepare you for the differences.
Michael
Old April 6th 05, 10:41 PM
Don Johnstone
Thanks for that. It would seem therefore that the standard
conical chute is the only choice for the majority of
glider pilots on the grounds that it is likely that
we will only ever use it if we have to.As I have already
said, if it is good enough for Martin Baker it's good
enough for me.
I am firmly of the opinion that people who jump out
of perfectly serviceable aeroplanes are .........how
can I put it.......... lacking in some way. :-)
rigs that
them to you if you
you ask for one.
attitude.
freebags (they
deployment even if
the jumper due to
which are thus
that looks like -
hope
such
is the volume
need less air
since they
inflate much
- so quickly in
for BASE jumping
equipped with
faster than
slow the opening
have just
a terminal
velocity opening.
cheaper. You can
dollars US; a
parachute is a
it doesn't
under one
and land it in
as I dislike rules,
anyone planning to
as briefing from
wing aerodynamics
Michael
Old April 7th 05, 12:55 AM
Charlie Lite
I'd consider installing a ballastic parachute and riding the damaged
glider to the ground surrounded by the cockpit.
Charlie "Lite"
Charlie Lite
Charlie "Lite"
Old April 7th 05, 05:29 AM
Ted Wagner
It's an active myth in non-skydiving circles.
Old April 7th 05, 05:35 AM
Ted Wagner
BASE (Building, Antenna, Span, and Earth) jumps are done without a reserve
because they would be useless. (Main didn't open? Prepare to die, or get
seriously b0rke.) BASE jumpers prefer reserve/emergency chutes for obvious
reasons: they don't want to die.
Aren't most BASE jumps done without a reserve? Do BASE jumpers prefer
the reserve square or the sport chute (since control into tight LZs is
a consideration)?
Just trying to get educated since we appear to have a group of folks
with useful information.
  #29
Old April 7th 05, 06:12 PM
How can a chute weathervane if it is freely drifting with the wind?
This sounds like the old "downwind turn" myth of general aviation fame.
I can see that if the chute is descending rapidly through a strong wind
velocity gradient, it would tend to orient into or out of the wind (not
sure which) due to the height of the chute/risers/chutist stack.
If that is the effect being described, how much of a wind gradient is
required?
Just curious,
66
  #30
Old April 7th 05, 07:56 PM
Michael
Thanks for that.
You're welcome.
If by that you mean that you won't train to use your emergency
equipment, then you are correct. Stick with the round. Just don't be
surprised if it lands you in the hospital. Remember - those maximum
loadings are based on a fit man in his 20's wearing boots with ankle
support. For a middle aged man wearing tennis shoes, they really ought
to be reduced by 30% or so. Not so the weights on squares - they are,
if anything, conservative if you know how to land one.
As opposed to the spectacular good sense exhibited by those who fly
airplanes that don't even have engines
Glass houses, stones, etc.
Michael
Emergency Parachute questions Jay Moreland Aerobatics 14 December 3rd 04 05:46 PM
Military jet makes emergency landing at MidAmerica Otis Willie Military Aviation 0 September 1st 03 02:28 AM
Emergency landing at Meigs Sunday Thomas J. Paladino Jr. Piloting 22 August 3rd 03 03:14 PM
First Emergency (Long Post) [email protected] Owning 14 July 23rd 03 02:46 AM
