![]() "C J Campbell" wrote in message ... Even the Cirrus will spin -- you just pull the CAPS handle to make it stop. :-) Spin certification is an additional expense and the planes are expensive enough as it is. That is what I was getting at. Just because it isn't certified for spins and Cirrus "says" it hasn't been tested for spins doesn't mean that Cirrus has spun the hell out of it. Not seeking spin certification and the recomendations of the manual appear to me as a means to reduce liability. Consider the possible consequences of Cirrus saying that it has great spin characteristics but it isn't certified for spins and they don't recommend conventional recovery techniques. |
On Fri, 24 Sep 2004 00:11:04 -0700, "C J Campbell"
wrote: "Justin H" wrote in message ... Why dont people make airplanes that will spin anymore? Even the Cirrus will spin -- you just pull the CAPS handle to make it stop. :-) Spin certification is an additional expense and the planes are expensive enough as it is. Still, there are plenty of airplanes certified for spin training, not least the ubiquitous Cessna 172. The Cessna 172 is not certified under the same regulations as the Cirrus. Unlike cars, once an airplane has received its type certificate, it does not have to be redesigned whenever the regulations are updated. The 172 came out in the '50s, and there's a good chance that the actual type certificate is that of the Cessna 170, which came out in the '40s. The 172 was certified under CAA regs, not under the modern Part 23 that the Cirrus had to meet. Take a 1954 Ford and a 2004 Ford, and compare the complexity, and the degree of Government standards that had to be met. With that said, I am reminded of an article I read several years ago, about the development of the Aviat Husky. While looking much like an older design, it was a brand-new aircraft that was certified under the modern Part 23. The article quoted the company president saying that the certification process was not especially onerous or time/money consuming. It'll be interesting to see how the Sport Pilot consensus standard comes out, for the certification of Light Sport Aircraft. I can't see the standard requiring in-depth flight testing...but maybe it will, and allow the manufacturers to install a ballistic chute if they don't want to go through the design/test effort. Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... On Fri, 24 Sep 2004 00:11:04 -0700, "C J Campbell" wrote: "Justin H" wrote in message ... Why dont people make airplanes that will spin anymore? Even the Cirrus will spin -- you just pull the CAPS handle to make it stop. :-) Spin certification is an additional expense and the planes are expensive enough as it is. Still, there are plenty of airplanes certified for spin training, not least the ubiquitous Cessna 172. The Cessna 172 is not certified under the same regulations as the Cirrus. Unlike cars, once an airplane has received its type certificate, it does not have to be redesigned whenever the regulations are updated. Actually, when Cessna started building new piston aircraft, they were re-certified under the new regulations. |
![]() "Ron Wanttaja" wrote in message ... The 172 came out in the '50s, and there's a good chance that the actual type certificate is that of the Cessna 170, which came out in the '40s. The 172 through 172S type certificate was originally issued in 1955 and amended up through 2000. The 172RG is a different type certificate, as is the 170 (came out in 1948). |
Earlier, Ron Wanttaja wrote:
...I am reminded of an article I read several years ago, about the development of the Aviat Husky. While looking much like an older design, it was a brand-new aircraft that was certified under the modern Part 23. The article quoted the company president saying that the certification process was not especially onerous or time/money consuming. Probably Alfred Scott's article "Lite Engineering and the Myth of Simplified Certification": http://www.seqair.com/Other/LiteEng/LiteEng.html Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
They do spin. Not all recover.
BJC "Justin H" wrote in message ... Why dont people make airplanes that will spin anymore? |
Ballistic chute saves 4 souls | Bob Babcock | Home Built | 28 | April 27th 04 09:29 PM |
