task not completed ClearNavII
Old May 16th 20, 04:13 PM posted to rec.aviation.soaring
Craig Reinholt
Default task not completed ClearNavII
After 40 years in retail, this commonly circulated statement is probably the greatest piece of horse manure ever created.
Craig
Ever heard that phrase about the customer always being right? Didn't
Old May 17th 20, 01:45 PM posted to rec.aviation.soaring
BobWa43
On Thursday, May 14, 2020 at 10:04:24 AM UTC-4, BobWa43 wrote:
I am new to ClearNav2. I have planned and flown two FAI tasks using the ClearNav2. ClearNav gave me a start time and changed from the start to first way point and then to the second way point, and then to the finish but no finish was acknowledged. I had the same task in my Nano and my Oudie, both recorded a completed task and the Oudie gave me a "task finished" announcement. This sequence applies to both flights. When the flights were analyzed on SeeYou, the files from the Nano and Oudie produced task completed analysis while the files from the ClearNav in one case said no valid start and in the other only the start was acknowledged. Does ClearNavII give a task completed statement like the Oudie? This is very frustrating. Please help me figure out what I am doing wrong. I would be happy to email the flight files to anyone who is interested and could help.Thanks ,
BobW
One mystery solved another found. It seems as though my ClearNav2 has suddenly started randomly recording high levels of engine noise, sometimes even when it is sitting on the ground. SeeYou gave me credit for an engine run in the middle of the flight thus changing the soaring start time to well after the task start time. Anyone experience similar behavior from their ClearNav2? Any explanation other than the usual vent noise, etc? Nano near ClearNav did not record any significant noise. Another good reason to restore the utility allowing downloads from Cambridge 302 through ClearNav.
Old May 17th 20, 02:25 PM posted to rec.aviation.soaring
Tango Eight
BobW
No, it's not supposed to do that. In the worst case, it's a hardware fault that will have to be corrected.
I answered the initial query here because it seemed like something that might have been of more general interest. I should have made clear that we typically do online customer support here https://clearnav.net/forum/index.php
best regards,
Evan Ludeman for CNi
Old May 17th 20, 03:01 PM posted to rec.aviation.soaring
kinsell
BobW
best regards,
He posted on the support forum first, got no solution, so then he posted
here.
I looked at his log, he also has a bizarre issue with B records having
duplicate time stamps. Sounds like flakey hardware that needs to be
replaced.
-Dave
Old May 17th 20, 04:20 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
to
produced
help.Thanks ,
BobW
sometimes
engine
through
ClearNav.
we
best regards,
here.
replaced.
-Dave
When recording at 1 second intervals, with a 1 second resolution, this can
happen. When it does. download again at (say) 4 second intervals.
Tim.
Old May 17th 20, 04:42 PM posted to rec.aviation.soaring
kinsell
to
produced
help.Thanks ,
BobW
sometimes
engine
through
ClearNav.
we
best regards,
here.
replaced.
-Dave
Tim.
He had downloaded at 2 second intervals and was getting this. Very
peculiar pattern to it, if the number of seconds ended in "3", then that
time stamp tended to be repeated, but with slightly different position
data, so it was a new reading. Occasionally other time stamps would be
repeated. Seems like electrical noise, or a bad chip to me.
I've asked for a 1 second interval download to see what that looks like.
Old May 19th 20, 04:25 AM posted to rec.aviation.soaring
5Z
Properly designed software would validate the output it produces.
If the spec for an IGC file stipulates that the timestamps on each record must be different and increasing, then why doesn't the FR drop those? There's already various algorithms in there massaging the data, so why isn't there logic to ensure the file is correctly formatted?
5Z
Old May 19th 20, 01:28 PM posted to rec.aviation.soaring
Tango Eight
5Z
There have been plenty of cases of valid IGC files coughing up hairballs on OLC. "Properly designed software" applies to more than the flight recorder.
2/3 completed Duster For Sale Blake Miller Soaring 1 November 28th 10 05:34 PM
FS: partially completed KR2 Jon Anderson Home Built 4 July 11th 08 07:03 PM
GA to 8ohm Headphone Adapter Completed Gary G Home Built 3 December 2nd 05 02:39 PM
GA to 8ohm Headphone Adapter Completed Gary G General Aviation 4 November 22nd 05 03:03 AM
TW Endorsement Completed [email protected] Piloting 7 May 9th 05 12:00 AM
