My question is, would it be possible to laminate your own shell using
vacuum bagging? Seems to me even the wettest veneers would split if you tried to force them into or around a male or female mold. to date, the only sort of manipulation I've done with ply is to wrap 1/16 leading edge pieces over a hot pipe. I just don't see how Hawley Bowlus got the compound curves.. They used a boatbuilding and canoemaking technique that used bands of thin veneer laminated over a male mould. The process is called "Cold Moulding" and there are a couple of books about it in the "boatbuilding" section of the library. Essentially you build up a male plug with plywood formers covered with fairly closely spaced strips of lath. The veneer thickness is selected to give you an odd number of laminations, 3, 5, 7, etc. The bottom layer goes on about forty five degrees to the lathing. Staple it down here and there to hold it in place. It is wise to use heavy cardboard tags under the staples because you are going to pull them out when you put the next layer in place. Brush the first layer with glue and cross it with the second layer at something approximating 90 degrees. Aerolite glue works well. Brush the cream component onto the first layer and then brush the hardener onto the bottom of the second layer. Pull the staples as you go and restaple through both layers. The third layer goes on like the second, but aligned with the airflow so the finished grain will be pretty! :-) Pull staples and staple it down as you go. After all the layers are down pull you vinyl over the whole banana and turn on the vacuum pump to pull it all tight and hold it down. If you want more than three layers of veneer repeat layers 1 and 2, finishing with the top layer aligned with the airflow. After the glue is hardened, remove the bag and sand the whole thing with a random orbital sander to contour. Standard industrial veneer for veneering furniture, etc. is 1/28 inches thick. That is just under a millimeter for you continental folks. A three layer veneer would be close to 3mm thick or a stout 1/8 inch. Be gentle sanding because it is really easy to sand completely through a veneer layer and get real embarassed! Any stringers or frames are glued inside after the skin is finished. This CAN be done without expensive or bulky tooling. The Dutch made fighters using this technology in WWI. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
As a naval architect, and at one time, a budding yacht designer, I've
got a lot of familiarity with "Cold Molding", which is the amateur's version of the Lockheed process for making molded plywood shells. The best book on the subject is "The Gougeon Brothers On Boat Construction" http://www.westsystem.com/webpages/p...m#publications http://www.amazon.com/exec/obidos/AS...874798-1028916 It's available in many libraries near the water, so you don't have to run off and buy it yet. And you shouldn't, for once you realize how much work this method will be for a One-off, you may, you should, think twice. Due to the small sized, and compond curves on the Baby Bowlus fuselage, cutting and trimming the veneers is going to be your key challenge. Each piece of veneer will need to be fitted to it's mate PRIOR to gluing it up. All this hand work is why I don't think vacuum bagging is going to buy you much on this project. You would have to vacuum bag EACH piece of veneer seperately, clean up the glue squeze - out at the free edge, and then fit the next piece of veneer. At least using this method, you won't have to pull all the damn staples!! I can easily see spending upwards of a 1000 hours just on the fuselage alone, between building the male form, spiling (fitting) the veneers, glue up (you need 3 layers), fairing, etc. Some respondents have mentioned steam bending plywood. I've tried that, and it's a non-starter, for the most part: http://users.lmi.net/~ryoung/Sonerai/MySonIIL.html Scroll down to find my tale of woe. Note the mention of special "bending plywood". I got the stuff from Woodline - The Japanese Woodworker in Alameda, California, it was Italian Poplar, and was extremely easy to bend. This may offer you a way out of a lot of labor, albeit at a high price in matierals. You may be able to use ONE layer of this stuff, cut into "gores" and faced inside and out with the lightest weight fiberglass and epoxy you can manage. There is a similar product out of Gabon made with some tropical hardwood, and a Hoop Pine product from Oz. http://www.marineply.com/stagflex.htm http://www.australply.com.au/pr_bendy.html http://www.tapeease.com/plywood_panels.htm http://www.lumberproducts.com/Produc...ingplywood.htm Good Luck, |
"flybynightkarmarepair"
groups.com: As a naval architect, and at one time, a budding yacht designer, I've got a lot of familiarity with "Cold Molding", which is the amateur's version of the Lockheed process for making molded plywood shells. The best book on the subject is "The Gougeon Brothers On Boat Construction" http://www.westsystem.com/webpages/p...x.htm#publicat ions http://www.amazon.com/exec/obidos/AS...874798-1028916 It's available in many libraries near the water, so you don't have to run off and buy it yet. And you shouldn't, for once you realize how much work this method will be for a One-off, you may, you should, think twice. Due to the small sized, and compond curves on the Baby Bowlus fuselage, cutting and trimming the veneers is going to be your key challenge. Each piece of veneer will need to be fitted to it's mate PRIOR to gluing it up. All this hand work is why I don't think vacuum bagging is going to buy you much on this project. You would have to vacuum bag EACH piece of veneer seperately, clean up the glue squeze - out at the free edge, and then fit the next piece of veneer. At least using this method, you won't have to pull all the damn staples!! OK, I've never done anythng like that before (aside form planking models when I was a kid) but it's close to what I reckoned was involved. I only imagined that each srip might have to be trimmed to match it's neighbor, and was hoping that it might not be so, and that someone here would tell me some magic secret that would sail me right past that problem! Oh well! I can easily see spending upwards of a 1000 hours just on the fuselage alone, between building the male form, spiling (fitting) the veneers, glue up (you need 3 layers), fairing, etc. Some respondents have mentioned steam bending plywood. I've tried that, and it's a non-starter, for the most part: http://users.lmi.net/~ryoung/Sonerai/MySonIIL.html Scroll down to find my tale of woe. Oh dear. Note the mention of special "bending plywood". I got the stuff from Woodline - The Japanese Woodworker in Alameda, California, it was Italian Poplar, and was extremely easy to bend. This may offer you a way out of a lot of labor, albeit at a high price in matierals. You may be able to use ONE layer of this stuff, cut into "gores" and faced inside and out with the lightest weight fiberglass and epoxy you can manage. There is a similar product out of Gabon made with some tropical hardwood, and a Hoop Pine product from Oz. http://www.marineply.com/stagflex.htm http://www.australply.com.au/pr_bendy.html http://www.tapeease.com/plywood_panels.htm http://www.lumberproducts.com/Produc...ingplywood.htm Good Luck, Thanks. I'm thinking if I get around to the Bowlus it'll have to be with the scarfed pod,though! |
Earlier, flybynightkarmarepair wrote:
Due to the small sized, and compond curves on the Baby Bowlus fuselage, cutting and trimming the veneers is going to be your key challenge. Each piece of veneer will need to be fitted to it's mate PRIOR to gluing it up... I dunno about that, Ryan, I think you're making it a lot harder than it was. Hawley and his crew weren't foolish, and they didn't have tons of time to spare, and they stomped out dozens if not hundreds of Baby pods in a relatively few short years. And they did it starting in the Depression, so I think you'll find that they didn't have a lot of money to throw at it. I'm thinking that it doesn't necessarily take finely crafted and fitted strips of veneer, and that the thing can be done with relatively wide swaths of thin veneer if you've got enough pressure. Note that the Baby pod has the very nose portion crafted in formed aluminum, and that the compound curvature of the fuselage aft of that is relatively modest. I agree that the pressures required to press the veneers into curvature are probably greater than you can get with vacuum bagging, but at a guess I'd say not hugely so. If I hankered for a Baby like the one I watched rot away at Sky Sailing in the early 1980s, here's what I'd do: I'd start by making a fuselage plug as I did for the HP-24 kit sailplane (see http://www.hpaircraft.com/hp-24 specifically the 2001 Updates), or perhaps by planking a set of bulkheads. Then I'd dress it with parting flange features and make right and left female molds of it in the back yard using regular old concrete. After the concrete cures, I'd pull the plug out, and then lay up Freeman tooling wax in the female molds to the thickness of the expected plywood layup. And then, I'd pour concrete into the tooling-waxed tubs to make male molds of the inside of the fuselage. To make the fuselage pod skin, I'd laminate relatively large swaths of veneer with +/- 45 degree grain and press them between the male and female mold parts. I'd press the male plug down using nuts on threaded rods set into the flange of the female mold. Sure, that plan is relatively time intensive, but the basic materials are pretty cheap, and once you get the process figured out you can bring your fellow Baby enthusiasts over to make their own pods before you turn the tubs into planters or backyard barbecues. Just a thought. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Bob Kuykendall wrote: Earlier, flybynightkarmarepair wrote: Due to the small sized, and compond curves on the Baby Bowlus fuselage, cutting and trimming the veneers is going to be your key challenge. Each piece of veneer will need to be fitted to it's mate PRIOR to gluing it up... I dunno about that, Ryan, I think you're making it a lot harder than it was. Hawley and his crew weren't foolish, and they didn't have tons of time to spare, and they stomped out dozens if not hundreds of Baby pods in a relatively few short years. And they did it starting in the Depression, so I think you'll find that they didn't have a lot of money to throw at it. Well, they had some duPont money at least ;-) Once you get the first one ship-set spiled out, you can use a router or a shaper to chew out as many as you want, likety-split. And they had the prototype to use as a full-size "tailer's dummy" to get a first approximation of the shape of the veneers for the molded version - neither advantage will apply to a one-off. |
I have built a number of cedar strip canoes and kayaks, and the process is
simple and beautiful. Basically, thin cedar strips can be easily bent into almost any shape, then glued together. Once the shape is completed, the inside and outside is dovered with cloth and epoxy resin. In essence, the cedar is simply the core (replacing foam). The strength is the inner and outer layers of epoxy multiplied by the thickness of the cedar strips. The epoxy is almost clear, so the beauty of the cedar shows through nicely. By mixing up grains, patterns and colors, gorgeous boats result. They are very light and strong. A cedar strip canoe properly built will weigh 50 pounds. The same technique could be use for aircraft. I have taken my canoe through rapids, over small water falls and survived collisions with rocks. The same technique should work for a lightweight aircraft. Colin |
COLIN LAMB wrote:
I have taken my canoe through rapids, over small water falls and survived collisions with rocks. The same technique should work for a lightweight aircraft. Colin Dang your brave I wouldn't want to do that in my airplaneG!! |
"COLIN LAMB" wrote I have built a number of cedar strip canoes and kayaks, and the process is simple and beautiful. The same technique could be use for aircraft. I have taken my canoe through rapids, over small water falls and survived collisions with rocks. The same technique should work for a lightweight aircraft. One problem is that for an airplane, there are bunches of point loads, like the spar, engine, and landing gear. There are also some wicked bending moments involved. If you canoe breaks, you go swimming. If you airplane breaks, you...... -- Jim in NC |
"One problem is that for an airplane, there are bunches of point loads, like
the spar, engine, and landing gear. There are also some wicked bending moments involved. If you canoe breaks, you go swimming. If you airplane breaks, you......" No question the point loads are a big issue. However, it is the same issue for those who build epoxy airplanes - because that is what a cedar strip boat is really, an epoxy boat with a cedar core, instead of foam. All of the cautions against cedar strip aircraft would apply to foam/epoxy airplanes - yet there are a number of successful creations flying around. The main difference is that you have to paint a foam/epoxy job because foam is not intrisically beautiful - wood is. I am not sure I advocate building a twin engined cedar strip fighter, but the original query was regarding a Bowlus. It has no engine and the strength demands are not nearly as great as a 10 G fighter. Colin |
"COLIN LAMB" wrote No question the point loads are a big issue. However, it is the same issue for those who build epoxy airplanes - because that is what a cedar strip boat is really, an epoxy boat with a cedar core, instead of foam. All of the cautions against cedar strip aircraft would apply to foam/epoxy airplanes - yet there are a number of successful creations flying around. The main difference is that you have to paint a foam/epoxy job because foam is not intrisically beautiful - wood is. My concern is the fact that there is only one layer, or ply of wood. It will have way less than 1/4 the strength than a craft with 2 plies of wood, unless many more plies of fiberglass and epoxy are used. There is also no resistance to twisting loads, without much more fiberglass. Another layer of wood at between 90 and 45 degrees would make it much stronger in that regard, also The point loads in fiberglass airplanes are carried through strong bulkheads, bonded very well to the body. I don't think what your describing has that. If the use of a single layer of wood is used to be the core, instead of foam, and the same thickness of fiberglass is applied, as it would be in the fiberglass and foam plane, there should not be a problem. Is this the intent? -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| Nut/thread securing compound | nauga | Home Built | 7 | April 22nd 04 08:56 AM |
| Randolph Wing Walk Compound | Larryskydives | Owning | 7 | March 7th 04 10:44 PM |
| Plywood | Kathi Jo | Home Built | 3 | January 12th 04 11:48 PM |
| Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 03:40 PM |
| Substitute for Mahogany plywood | Kelvin & Janice Rempel | Home Built | 1 | September 5th 03 09:02 PM |
