Standalone artificial horizon
Old June 6th 20, 01:08 PM posted to rec.aviation.soaring
Default Standalone artificial horizon
So out of interest how do you manage to stick to VFR rules when
soaring?
I don't know the best way to adjust the regs. Clearly not VFR in a cloud. But not IFR airport stuff either. Perhaps some sort of in-between rating without the airport stuff, but with block clearance in controlled, but not too busy areas.
Might be a case of be careful what you wish for and the FAA has better stuff to worry about?
Old June 6th 20, 02:22 PM posted to rec.aviation.soaring
soaring?
I use a highly technical method developed over years of trial and error. I LOOK OUT THE WINDOW! If the clouds are getting close, I descend or go somewhere else.
Old June 6th 20, 03:06 PM posted to rec.aviation.soaring
So you never thermal to cloud base? or Dolphin fly a cloud street?
It depends. VFR regs and cloud clearance limits are spelled out quite exactly. I prefer to maintain my legal right to not incriminate myself.
You seem to be looking for a way to do something that is not allowed by current regulations simply because the equipment is available. I have a car that will do 120+ mph. The speed limit is 75. If I get caught speeding, I pay the penalty. Arguing that the vehicle is capable of going that fast does not change the fact that speeding is a violation of the law or regulations.
I am not telling you what to do, if you ask the FAA for permission to fly in clouds in an aircraft rated for Day VFR and not fully IFR equipped, and not holding a current IFR certificate, you will probably be disappointed with their answer.
And getting them to change the regulations to allow something like this shouldn't consume more than the rest of your life.
Old June 6th 20, 04:16 PM posted to rec.aviation.soaring
Dan Marotta
Quite the opposite, Mark.Â* The FAA does not ask if one is rated or
properly (legally) equipped.Â* They accept and process an IFR request.Â*
If one does not get into trouble following a clearance, who's the
wiser?Â* On the other hand, bail out because you weren't capable, and
watch the stuff hit the fan.
Dan, 5J
Old June 8th 20, 11:48 AM posted to rec.aviation.soaring
krasw
VFR vertical distance to cloud limit is being violated by every single glider pilot I have flown with (as a student, flight instructor, competition pilot, you name it). Please let's not pretend that such pilots exists. Yes, you shouldn't do it. Yes, everyone does. No, of course YOU don't.
Old June 8th 20, 01:26 PM posted to rec.aviation.soaring
Jonathan St. Cloud
But I thought cloud base was nirvana for a glider pilot. Now I can't even be happy there, **** you 2020.
  #29
Old June 8th 20, 09:40 PM posted to rec.aviation.soaring
Dirk_PW[_2_]
Don't worry Jonathan, ATC still can't see "cloud base". (yet).
  #30
Old June 10th 20, 04:22 AM posted to rec.aviation.soaring
cdeerinck
I flew with a very excellent to-remain-unnamed pilot, who once flew 1000' above me when I thought I was at cloud base. Afterward, he said he wasn't in the cloud, because he could still see the ground directly below him. My rule for cloud base was/is that if I can't see the horizon, I'm in the cloud.
I agree that damn near every glider pilot breaks the cloud separation rules unless posting on a forum, simply because the lift is strongest there. I'm not saying it is right or wrong, but it certainly happens.
All that being said, what is the actual definition of cloud base, that we are supposed to stay 1000' from? I am not trying to be a smart-ass, I would really like to know.
And since I am high-jacking Richard's thread, I will add this: If you do put a stand-alone ADHRS in your glider, you will not be able to fly contests with it. As IGC regs require an ADHR activation to be logged in the file. Again, no judgment here, just passing along information.
Artificial Horizon – HELP! Mike Mike Ground Soaring 8 September 30th 11 08:17 AM
Electronic Artificial Horizon Stuart Kinnear Soaring 14 May 3rd 07 06:56 PM
artificial horizon DavidH Home Built 14 March 14th 07 07:47 AM
Artificial horizon pinout? [email protected] Home Built 3 July 16th 06 02:02 PM
Artificial Horizon testing Rory O'Conor Soaring 6 April 5th 05 11:48 PM
