FAA suspends Bruno Vassel's Pilot Certificate
Old June 28th 20, 03:20 PM posted to rec.aviation.soaring
Default FAA suspends Bruno Vassel's Pilot Certificate
I agree with Karl..........when that low...........nose up, then roll..........like checking for your spot on the range.
Enjoy your videos,
JJ
Old June 28th 20, 10:07 PM posted to rec.aviation.soaring
Enjoy your videos,
JJ
The origin of the "50 foot" rule in contests, when using the line finish, comes from a pilot turning before pulling and running his wing tip through a corn field.
Observers said it sounded like a machine gun. He landed safely.
Yep- gotta pull before you roll.
UH
Old June 28th 20, 09:41 PM posted to rec.aviation.soaring
Dan Marotta
I watched a glider touch a wing tip to the ground in a low, low final
turn.Â* Pilot walked away, the glider is still in Fidel's shop.
On 6/28/2020 7:25 AM, Karl Striedieck wrote:
Thanks for the report Bruno. I'd bet my (so far unnoticed) "infractions" exceed yours by a factor of 10.
Also thanks for the countless hours and hassle you contribute to the sport.
One observation that may have a safety implication was noted at 6:15 on the video. The left tip was probably closer to the ground than I would like.
Hoping you find a buddy with nice two-seater to slip some surly bonds in the immediate future.
KS
Dan, 5J
Old June 28th 20, 11:02 PM posted to rec.aviation.soaring
Bob Youngblood
KS
Well only thing that I can say is too bad the FAA guy had nothing better to do than bust a good ole glider guy. I liked the pass, I have seen better, by none other than the late E9. Yes I saw Alfonso do a pass where the grass was blazing and then pull up into a loop as Bennie and I were watching and laughing as he pulled out of the loop and made a 180 to land. E9, we miss you! Bob
Old June 29th 20, 12:53 AM posted to rec.aviation.soaring
Bob T
KS
Have I missed something.... I notice on yesterday's OLC that he posted a flight on OLC in his 27. ?????? https://www.onlinecontest.org/olc-3....l?dsId=7906941
Old June 29th 20, 01:37 AM posted to rec.aviation.soaring
SoaringXCellence
Actually, his suspension is over, was given before the first of the year and occurred mostly during the virus shut-down time.
Old June 28th 20, 03:32 PM posted to rec.aviation.soaring
Roy B.
The sad part about this is that while the suspension ends after a few months the effect of it goes on forever in insurance applications ("Have you ever had any enforcement actions?"), in Glider club applications ("any incidents or suspensions?") etc. The FAA used to have a policy of expunging suspensions after a period of no further violations - but that policy ended a few years ago.
To restate what KS said, the only difference between us and Bruno is that Bruno got caught. I got caught too (low level flying in a J3 Cub within 500' of a Park Ranger I never saw). All you can do is learn from it and avoid putting yourself in a position where your flying can be criticized by the FAA. Arguing about special treatment for Boeing, for Harrison Ford, or others is pointless. We put our own shirt tail in the wringer. Bruno did a service to warn others.
ROY
Old June 29th 20, 12:38 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
[quote=Roy B.;t policy ended a few years ago.
To restate what KS said, the only difference between us and Bruno is that Bruno got caught. I got caught too (low level flying in a J3 Cub within 500' of a Park Ranger I never saw). s.
ROY[/QUOTE]
So motoring down a ridge is infraction if hikers are there ?????
Old June 29th 20, 02:05 AM posted to rec.aviation.soaring
Roy B.
That is correct. read FAR 91.119 (c):
"Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
Like I said, everyone who has ever been down a ridge with a "structure" or a "person" on it has violated this section. Most don't get caught . . . Some do.
ROY
Old June 29th 20, 11:22 AM posted to rec.aviation.soaring
Stephen Struthers
those
person,
"structure" or
Some do.
ROY
In the UK we have a get out clause
The Civil Aviation Authority permits, under SERA.3105 and
SERA.5005(f) a glider to fly below 150 metres (500 feet) above the
ground or water or closer than 150 metres (500 feet) to any
person, vessel, vehicle or structure if it is hill-soaring.
http://publicapps.caa.co.uk/modalapplication.aspx?
catid=1&pagetype=65&appid=11&mode=detail&id=7417
Stephen
Pilot certificate required? Jim[_33_] Soaring 18 November 25th 18 02:24 AM
Private Pilot Certificate, or Lightsport Pilot Mark IV Piloting 39 April 19th 11 09:45 PM
Canadian Pilot wants U.S. Certificate [email protected] Soaring 17 November 27th 08 04:42 PM
New use for a Pilot Certificate El Maximo Piloting 5 July 22nd 07 11:34 AM
New pilot certificate face-off Ben Jackson Piloting 3 June 26th 04 07:08 AM
