Wing pin grease
Old July 19th 20, 05:21 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Default Wing pin grease
My observation is that grease makes a difference in reducing lift pin wear from fretting. It’s pretty much impossible to get the wings to fit tight enough to avoid the lift pins sliding in and out of the bearings when yaw forces are transferred between the fuselage and wings. It isn’t much movement, but over time it’s a significant cause of wear. The movement should be reduced as much as possible by inserting shims, but getting to zero movement makes assembly difficult. No free lunch.
Craig
JN
Old July 19th 20, 04:54 PM posted to rec.aviation.soaring
Most of the dust is near the ground, you should try flying a little
higher...
Lol! Ive seen dust devils past 10k agl! But as 6K used to say "All I ever find in dust devils is dust"
CH
Rigging grease recommendations for long-term-rigged gliders Jim Hogue Soaring 19 February 4th 20 03:29 PM
Youth soaring program looking for wing wheel for large-chord wing Jay[_2_] Soaring 1 September 17th 14 02:44 AM
Grease recommendation Bastoune Soaring 20 April 2nd 10 08:57 PM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 03:23 AM
2.4 hours - no oil/grease on prop/windshield Jay Honeck Owning 8 September 30th 06 01:25 PM
