Polar numbers for Discus A
Old April 26th 05, 06:15 PM
Serge Serfaty
Default Polar numbers for Discus A
Can anybody tell me the numbers to enter in the Cambridge
302 for the Discus A, or where to find these numbers?
Thanks.
Old April 26th 05, 11:17 PM
cfinn
You can review the poplars that are available from WinPilot at
http://winpilot.com/Gliders.htm. Go to the bottom of the page and
select "Polars". This list was created by Carl Herold.
I hope that helps.
Charlie
cfinn
I hope that helps.
Charlie
Old April 26th 05, 11:35 PM
This isn't everything you need, but there is a WinPilot polar file you
can get for the Discus A at http://www.winpilot.com/polar.asp.
Unfortunately, different manufacturers like to ask for polars in
different ways. My LX5000 wants the polar's (a,b,c) coefficients and
min and max wing loadings. Cambridge wants (1) best L/D, (2) wing area
in sq meter, (3) best L/D speed in kph, (4) dry weight in kg, (5) speed
at 2 m/s sink in kph, and (6) ballast capacity in liters. You can get
some of that from your glider's manual.
What's the difference between the Discus and the Discus A? SeeYou (my
3.1 version anyway) has polars for "Discus" and "Discus 2". I derived
the C-302 polar numbers by plugging the SeeYou polar numbers for H304CZ
into LXe's Polar tool to get a graph of the polar. From that I read off
the numbers for best L/D speed and speed at 2 m/s sink. I can do that
for you, if "Discus" and "Discus A" have the same polar.
-ted/2NO
Old April 26th 05, 11:58 PM
Something I forgot to add: the Cambridge 302 utility has a "From File"
button that looks for files of type "Polar Files (*.plr)". Do not
confuse those with WinPilot .plr files, they have completely different
formats.
Old April 27th 05, 05:40 AM
Serge Serfaty
That's my problem. I can get all these different numbers
but they are not the ones that I need for the Cambridge.
I can get SeeYou polars too.
The Discus or Discus 2 come with 2 different fuselages:
A and B.
Old April 27th 05, 06:42 AM
Marc Ramsey
A and B.
You may wish to give some consider that any polar coefficient numbers
you obtain are, at best, simply an approximate curve fit to numbers
measured off of one particular clean glider on one particular day, that
flight computers use these approximate numbers to calculate a further
approximation for speed to fly, and that the real world difference in
performance between an A and B model Discus is quite likely smaller than
errors inherent in these approximations. Use some middle of the road B
polar numbers, the result will be close enough to reality of the day to
day performance of your ship...
Marc
Old April 27th 05, 03:30 PM
Udo Rumpf
The CAI numbers for the Discus A as per R. Johnson.
Wing loading 32kg/m^2
42.5 @ 98km/h
V 2 163km
You will have to make adjustment for your wing loading
I hope this will help.
Udo
"Serge Serfaty" wrote in message
A and B.
Old April 11th 16, 08:11 PM posted to rec.aviation.soaring
xcnick
11 years later and now I have bought Serge's Discus. Udo, if you have your ears on, are the R. Johnson numbers from his 1986 article? The way I read the article he tested at 700 lbs which is 30.2kg/m^2 rather than 32.
thanks
nick
42.5 @ 98km/h
V 2 163km
Udo
Old April 11th 16, 08:26 PM posted to rec.aviation.soaring
C-FFKQ (42)
thanks
nick
Nick, I'm sad to inform you that Udo died a few years ago after a lengthy illness.
Commercial polar routes? General Aviation 6 January 28th 05 08:03 PM
Stemme S10-VT Polar Catherine Conway Soaring 2 December 21st 04 05:17 PM
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
1930s Navy side numbers. JDupre5762 Naval Aviation 3 September 24th 03 07:51 PM
Is anyone still interested in CuSoft "Polar Explorer" program for PC? Branko Stojkovic Soaring 1 July 26th 03 01:06 AM
