S&B wrote:
My point is to not rely solely on electrical components/indications I agree. This is why I always take along a cross country flight log with blocks at each waypoint for estimated time of arrival and actual time of arrival. En route, I use this log and a clock to monitor fuel usage. OK, so the XC log is produced by Jepp's FlightStar flight planning software, but I could produce one by hand if I had to. ![]() -- Peter |
oups.com... [...] My point is to not rely solely on electrical components/indications. Who said anything about making the fuel flow meter one's sole source of information with respect to fuel quantity? Geez...take a chill pill. The correct "takeaway" here is that a) fuel flow meters ARE useful (when properly calibrated) and b) you cannot trust any one source of information (not even your watch) and so the more sources of information you have available, the better (so you can cross-reference). It's got nothing to do with being "one of the soon to be gone dinosaurs". Other than a dinosaur who refuses to take advantage of new technology *in addition to* their existing tools may be gone sooner rather than later, that is. Pete |
Pete
You misread or misunderstand me. I said not to rely SOLELY on electrical. I'm delighted to see the modern advances and electronics and use them as often as they are available. But, I've been around a long time and have yet to see a foolproof system. I've encountered more than a few in-flight failures of nearly everything that can go wrong! Fortunately I was close enough to make a landing when I had some serious failures in flight. BTW, what is a "takeaway"? Is that a new word that us old english major dinosaurs have to learn? Of course I understand the meaning or intent, I think, but have never seen it used before. geeezzzo....chill pill? fly safe and don't take anything for granted Ol S&B |
My JPI is always within a gallon when I top up.
![]() Dylan Smith wrote: snip So my lesson is - keep track of time AND cross check time and your expected fuel burn with the fuel gauges. If the gauges show less than expected, land and check it out. They might well be right. That's the key to using the often less-than-accurate fuel gauges found on most aircraft. Even though they may not tell you the exact quantity of fuel in each tank, an unusual reading can tip you off to a fuel leak or higher than expected fuel burn. One more trick that I keep in the bag is to burn fuel from one tank at a time (even when flying a high wing that allows both). If you have a leak or unusually high fuel burn, you'll be alerted when a tank goes dry ahead of schedule. At that point, you (hopefully) have fuel remaining in the other tank to get you safely on the ground. When flying on a "both" setting, by the time you realize that something is wrong, you may have emptied both tanks. John Galban=====N4BQ (PA28-180) |
Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 10:20 PM |
Most experienced CFI runs out of gas | Robert M. Gary | Piloting | 54 | November 19th 04 01:24 AM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
