#21
![]() "Antoņio" wrote in message ... Correct. Why do you mention it? For clarity. |
Steven P. McNicoll wrote:
"Antoņio" wrote in message ... Correct. Why do you mention it? For clarity. I am sorry but I am not sure of what you are attempting to express. Your mention of Special VFR being available only in a surface area did not, in my opinion, logically follow the discussion of my comments (and the resulting responses) to the following comments made by cfeyeye... "I believe, when all is said and done, IMC refers to the meterological conditions where one must operate under IFR, and VMC refers to the conditions where one may operate under VFR." I stated: If the conditions are tecnically IMC one can still operate under Special VFR which is a VFR operation. And you responded: "Special VFR is available only in a surface area." I do not understand the relevance to your mention of *where* special VFR was made available. So I ask again (so as not to miss the point of your post): Why did you mention it? Antonio |
![]() "Antoņio" wrote in message ... I am sorry but I am not sure of what you are attempting to express. Your mention of Special VFR being available only in a surface area did not, in my opinion, logically follow the discussion of my comments (and the resulting responses) to the following comments made by cfeyeye... "I believe, when all is said and done, IMC refers to the meterological conditions where one must operate under IFR, and VMC refers to the conditions where one may operate under VFR." I stated: If the conditions are tecnically IMC one can still operate under Special VFR which is a VFR operation. And you responded: "Special VFR is available only in a surface area." I do not understand the relevance to your mention of *where* special VFR was made available. So I ask again (so as not to miss the point of your post): Why did you mention it? Because it was not clear that you understood that Special VFR was available only in a Surface Area. You went on to say that you thought there may be "specific conditions within class G airspace where IMC allows for VFR operations", so it was clear that you did not have a proper understanding of this issue in general. |
![]() "Steven P. McNicoll" wrote: "Antoņio" wrote in message ... Errr...as one of the "vast majority" would you clarify for me the difference? Do you mean that the strict definition of IMC is "less than VFR" ? Yes. From the Pilot/Controller Glossary: IMC- (See INSTRUMENT METEOROLOGICAL CONDITIONS.) INSTRUMENT METEOROLOGICAL CONDITIONS- Meteorological conditions expressed in terms of visibility, distance from cloud, and ceiling less than the minima specified for visual meteorological conditions. VMC is not necessarily VFR, and varies with the nature of the IFR operation. In the case of a visual approach, charted or not VMC means clear of the coulds and not less than 3 s.m flight visibility. |
![]() wrote in message ... VMC is not necessarily VFR, and varies with the nature of the IFR operation. In the case of a visual approach, charted or not VMC means clear of the coulds and not less than 3 s.m flight visibility. Where'd you get that idea? |
"Antoņio" wrote in message ... I am sorry but I am not sure of what you are attempting to express. Your mention of Special VFR being available only in a surface area did not, in my opinion, logically follow the discussion of my comments (and the resulting responses) to the following comments made by cfeyeye... "I believe, when all is said and done, IMC refers to the meterological conditions where one must operate under IFR, and VMC refers to the conditions where one may operate under VFR." I stated: If the conditions are tecnically IMC one can still operate under Special VFR which is a VFR operation. And you responded: "Special VFR is available only in a surface area." I do not understand the relevance to your mention of *where* special VFR was made available. So I ask again (so as not to miss the point of your post): Why did you mention it? Because it was not clear that you understood that Special VFR was available only in a Surface Area. You went on to say that you thought there may be "specific conditions within class G airspace where IMC allows for VFR operations", so it was clear that you did not have a proper understanding of this issue in general. You left out the "I vaguely recall..." part of the quote but, no biggie, I see now where you are coming from. Antonio |
![]() "Antoņio" wrote in message ... You left out the "I vaguely recall..." part of the quote but, no biggie, I left nothing out of the material I quoted. If you review your message you'll see that what appears between my quotation marks is exactly what you wrote. I see now where you are coming from. Good. |
"Antoņio" wrote in message ... You left out the "I vaguely recall..." part of the quote but, no biggie, I left nothing out of the material I quoted. If you review your message you'll see that what appears between my quotation marks is exactly what you wrote. I see now where you are coming from. Good. Yawn I think I'm gonna go see what's on the tube... |
#29
![]() "Antoņio" wrote in message ... Yawn I think I'm gonna go see what's on the tube... I suggest something simple. |
#30
"Antoņio" wrote in message ... Yawn I think I'm gonna go see what's on the tube... I suggest something simple. Ahhh..Stephenator! How nice to see you breaking out of passive-agressive, frustrated unappreciated genius government worker, I'll show those idiots by going into knowledgeable esoteric semi-troll mode; to actually form a complete, and unambiguous (though not uncharacteristic) sentence! ;-) Antonio |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! | copertopkiller | Military Aviation | 11 | April 20th 04 02:17 AM |
Agent86's List of Misconceptions about FAA Procedures Zero for 15 Putz!!! | copertopkiller | Military Aviation | 9 | April 18th 04 06:13 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
