FES climb rate question.
Old October 17th 20, 05:09 PM posted to rec.aviation.soaring
Dan Marotta
Default FES climb rate question.
The CalAir A-9b, for instance...
On 10/16/2020 8:50 PM, 2G wrote:
On Friday, October 16, 2020 at 4:53:50 PM UTC-7, John Foster wrote:
On Friday, October 16, 2020 at 8:11:13 AM UTC-6, waremark wrote:
Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud.
Any idea what the endurance is of that aircraft?
As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that.
Much of the noise you hear from any propeller-driven aircraft comes from the tips of the propeller breaking the sound barrier. That won't change between an electric vs petrol engine. The longer the propeller, the faster the tips move.
My ASH31Mi has a 1.55m diameter propeller that has a max rpm of 2500. If you do the math, this works out to 454 mph, well below the speed of sound. Few GA aircraft have props that go supersonic, and you can really tell those few that can.
Tom
Dan, 5J
Old October 17th 20, 05:15 PM posted to rec.aviation.soaring
Dan Marotta
To follow up, if my simple arithmetic is correct, a 94 inch propeller
spun at 2,700 rpm achieves a tip speed of about 1,107 feet per second.Â*
According to NASA, 1,100 fps at sea level is the speed of sound.Â* At a
typical summer density altitude of, say, 8,800' MSL, the CalAir's prop
tips are supersonic.
But I may have screwed up the math...
loud.
from the tips of the propeller breaking the sound barrier.Â*Â* That
won't change between an electric vs petrol engine.Â* The longer the
Tom
Dan, 5J
Old October 17th 20, 09:21 PM posted to rec.aviation.soaring
Mike Reid
Your math seems correct, but the speed of sound varies with temperature, and not pressure, so if your density altitude is 8800' because it is 90º F, then the speed of sound is 1252 fps and the tips are subsonic.
Old October 17th 20, 11:38 PM posted to rec.aviation.soaring
Dan Marotta
Thanks for that!Â* But come to Moriarty and listen to the unholy racket
that the CalAir makes.
Dan, 5J
Old October 18th 20, 12:01 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Louder than these?
https://www.youtube.com/watch?v=XSGYL3j5EXo
(105.5 dB at 50m 400hp piston)
https://www.youtube.com/watch?v=YOTwJ1ASz1c
(750hp turboprop)
Martin | martin at
Gregorie | gregorie dot org
Old October 20th 20, 01:53 AM posted to rec.aviation.soaring
2G
loud.
Tom
Dan, 5J
What MG has such a prop? That is about 2.4m, 0.85m larger than the ASH26/31..
Tom
Old October 21st 20, 12:44 AM posted to rec.aviation.soaring
Dan Marotta
Not a motor glider.Â* The Callair A-9
https://www.google.com/search?q=callair+a9&safe=active&rlz=1C1CHBD_enUS89 2US893&sxsrf=ALeKk01KWvhDfRd1SaXXBOzZmMichhcvyA:16 03235108039&source=lnms&tbm=isch&sa=X&ved=2ahUKEwi TmOyYpMTsAhUFQ80KHQUmC9IQ_AUoAXoECAcQAw&biw=1536&b ih=722&dpr=2.5#imgrc=L7sDan_WSLAatM
is an ag-plane.Â* I did some research and it seems the prop diameter is
84 inches instead of 94 inches.Â* I thought I measured it, but that was a
long time ago...
loud.
Tom
Dan, 5J
Tom
Dan, 5J
Old October 22nd 20, 02:34 AM posted to rec.aviation.soaring
2G
A-9 is an ag-plane.Â* I did some research and it seems the prop
diameter is 84 inches instead of 94 inches.Â* I thought I measured
it, but that was a long time ago...
loud.
Tom
Dan, 5J
Tom
Dan, 5J
That is a big difference and means that the tip speed is 675mph, well below the speed of sound.
Tom
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Climb Rate for DG-600M Steve B Soaring 5 August 25th 03 08:17 AM
