When to acknowledge ATC
Old May 6th 05, 06:19 PM
Peter R.
"Steven P. McNicoll" wrote:
Altimeter settings don't tend to vary a great deal from one controller to
the next. If you're issued one that differs by more than a few points from
the previous then it's a good idea to check on it.
During my short three years in the air, I had one IFR flight about a month
ago where the pressure difference between three approach facilities
(Syracuse to Buffalo, actual distance around 150nm) was almost 3/4's of an
inch. That equated to about 700 feet difference in altitude from start to
finish.
I recall a few of the airline pilots that morning were doing double-takes
and commenting on this dropping pressure as they flew west.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
Old May 8th 05, 04:07 PM
John T
ink.net
controller to the next. If you're issued one that differs by more
than a few points from the previous then it's a good idea to check on
it.
This is true. However, one of the exceptions I remember was back when the
remains of hurricane/tropical storm Ivan were rumbling around my flight
path. The low pressure system definitely caused a very significant change
in altimeter settings from one sector to the next - so much so that I
thought I misunderstood her call the first time.
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old May 5th 05, 11:18 PM
Happy Dog
"Andrew" wrote in message
ATC says "radar contact, 20 miles south of XYZ, proceed on course". Do
you acknowledge this transmission? How about when ATC says "altimeter
setting 2992" on your first contact after a handoff? Does this require
acknowledgement?
Yes.
In the past, I've acknowledged such things if the controller was not
busy. But I've heard all kinds. Some people read back the altimeter
setting. I've even heard people reading back the "radar contact"
message. I feel that this is a waste of bandwidth. However, I don't
know what ATC prefers. Do they want read back for everything, or should
we shut up as much as possible?
Learn to get a quick feel for how busy they are. NYC Class B is insanely
busy and ATC there can practically tell what you mean if all you do is
grunt. Try to anticipate how important your read back will be to them.
Traffic confirmation, exact traffic confirmation, helps them immensely and
is worth the time to let them know if you're really sure you have the
traffic they're talking about. Things like radar contact and altimeter
setting only require your abbreviated call sign (assuming that's how they ID
you) as a response. Xponder code should be read back if you have the
slightest doubt you you've heard it correctly. If things are slow, read
back everything. If you can arrange it, pay a visit to a tower or ATC
facility. It's worth the time.
moo
Old May 6th 05, 01:26 AM
John Clonts
Yes, "Roger, 7NZ"
acknowledgement?
Yes, "Roger, 7NZ"
ALWAYS acknowledge. Now if you were meaning "readback" when you wrote "acknowledge", thats a different
question...
Aha, now your talking about readback. My experience is, only readback clearances and numbers, and a few other
important items like "hold short of runway XX" . But I don't usually read back altimeter settings.
Cheers,
John Clonts
Temple, Texas
N7NZ
Old May 6th 05, 02:07 AM
Al Gilson
Bob Gardner: What say you?
acknowledgement?
Old May 6th 05, 02:22 AM
kage
I haven't seen Bob on the board lately. In fact, not since before I went
flying with him about 10 days ago.
Karl
"Al Gilson" wrote in message
acknowledgement?
Old May 6th 05, 02:36 AM
George Patterson
acknowledgement?
Dunno about required, but I acknowledge both.
busy.
I acknowledge with my N-number only. They'd have to be *real* busy for that to
cause trouble.
George Patterson
There's plenty of room for all of God's creatures. Right next to the
mashed potatoes.
Old May 6th 05, 02:47 AM
iflyatiger
The reason you need to acknowledge the altimeter setting is that it lets the
controller know that you hear him and there is 2 way communications.
Your first check in on the freq lets him hear you, the altimeter setting
lets you know you can hear him and your reply to the altimeter setting lets
him know you can hear him.
Jon
acknowledgement?
Old May 6th 05, 03:30 AM
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Jon
It's a bit more than that.
If you're working in any sort of Class C or D airspace, his
response to you is in fact clearance into that airspace. So if he
responds, you can fly through unless ATC tells you 'remain outside
Class x Airspace'. Then you must read back something. Class B airspace
requires ATC to tell you that you are cleared into it. So if ATC tells
you 'radar contact location, altimeter xx.xx', you're cleared through
that space where he's controlling, establishes 2-way comms, in which
you need to acknowledge that he hears you whether it's a vector he's
given you, or just replying with your callsign, that is all that's
needed. You can reply back with the alt. setting, but it isn't really
necessary.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.sbcglobal.net/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
iD8DBQFCetanyBkZmuMZ8L8RAkc2AKCK7625aF18AmeVmfXnMS KoklG68QCfVO5q
HOcNk9ZM0MRhMAqyGY0MOdQ=
=gFlV
-----END PGP SIGNATURE-----
Old May 6th 05, 04:21 AM
Ron Natalie
No clearance is required.
So if he
The last sentence makes no sense whatsoever. If I call and he answers,
that's two-way communciation and that's all that's required.
Class B airspace
necessary.
RADAR CONTACT is not required. Altimeter setting is not required.
Readback is not required. You know he hears you because he responded
to your radio call with your call sign. I'm having a hard time
following your argument.
What F-102 units were called up for Viet Nam Tarver Engineering Military Aviation 101 March 5th 06 03:13 AM
