Solar panel controller
Old December 29th 20, 03:42 PM posted to rec.aviation.soaring
krasw
Default Solar panel controller
Any ideas for Strobl controller replacement? The voltage is not enough for LFP battery. Victron SmartSolar MPPT 75/10 looks good, but according to specs Strobl solar cell voltage is not enough to start the unit (!). Genasun has appalling efficiency.
Old December 29th 20, 04:03 PM posted to rec.aviation.soaring
Soartech
We need more info: how many Volts does your cell put out? What is the battery type and size in Watt-hours? What aircraft is this on?
Old December 29th 20, 04:52 PM posted to rec.aviation.soaring
jfitch
I'd be amazed if you had room for a Victron in your glider. Both Victron and Genasun make generally good stuff. From the data sheets, the Victron efficiency is "98% peak" and the Genasun is "94 - 99.85% typical". These are effectively the same. What do you find appalling?
Old December 29th 20, 06:36 PM posted to rec.aviation.soaring
krasw
Genasun consumes 150mA, six times more than Victron (25 mA). My solar panel produces 550mA (via Strobl controller). Genasun robs almost third of the panel produced power.
Old December 29th 20, 07:27 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
krasw wrote on 12/29/2020 10:36 AM:
The Genasum datasheet say 0.150 ma (150 ua), so much less power consumed than the Victron.
Old December 31st 20, 11:18 AM posted to rec.aviation.soaring
krasw
Thanks, I should probably learn to read.
Old December 29th 20, 11:59 PM posted to rec.aviation.soaring
Moshe Braner
I've often thought of adding small solar panels in my glider to extend
the battery life, but when I do the math it makes no sense. Most
gliders have very limited room for solar panels (unless you glue the
flexible type outside the cockpit). I am surprised you got 550 mA,
that's about 7 watts. But that's probably peak, when the panel is
perfectly aligned towards the sun, and not under a cloud, and the
average would be much lower, probably 200 mA or less. Meanwhile people
have been loading their gliders with so much electronics that they say
they need TWO 12AH batteries to last a flight. Let's take the example
of a 1-amp average load, i.e., one 12AH LFP battery (or two SLAs) would
last 12 hours. Add a 200mA-average solar charging setup and that
reduces the load on the battery to 0.8 amps, extending the battery life
to 15 hours. Useful?
Old December 31st 20, 11:45 AM posted to rec.aviation.soaring
krasw
I wouldn't bother with solar panels unless my glider was factory equipped with one. My panel draws 830mA and I have 2*7 Ah of battery capacity, but OTOH I like to have one fresh battery to extend my engine in those very cold days.
Old December 30th 20, 03:26 PM posted to rec.aviation.soaring
Brian[_1_]
Old December 30th 20, 03:42 PM posted to rec.aviation.soaring
Brian[_1_]
I put a 10 Watt a panel on my HP16. It averaged 200-250ma charging a 12AH Lead Acid batteries. The real advantage was when I was flying contests or safaris where I left the plane tied down. I could fly about 3 days in a row without needing to charge the battery. If we had a rest day it would pretty much top off the battery. I didn’t use a charge controller, I just used a volt meter. Since I only left it tied down when I was flying almost daily I didn’t figure 200-250 was enough to hurt the battery. But if I didn’t fly for more than a day I would disconnect it.
I loved having the solar panel, most of the time I didn’t need to charge the battery when flying daily. I wish I could come up with a reasonable panel to install on my LS6.
IMO Unless you are leaving the plane outside for extended periods without flying almost daily, my opinion is you don’t need a charge controller for a 20 watt or less solar panel. An appropriately sized and heat sinked Zenor diode would prevent it from overcharging if you did inadvertently leave it connected. If it is connected only when flying then no controller is required.
Any interference from the Genasun LFP solar charger controller? jfitch Soaring 2 May 18th 18 03:41 AM
Strobl Solar Charge Controller Doug[_9_] Soaring 0 June 22nd 17 09:55 PM
Flexible solar panel deal Soartech Soaring 5 June 15th 16 08:26 PM
Connecting my 2 Batteries to 1 Solar Panel Dan G[_2_] Soaring 14 January 5th 13 11:12 PM
sizing solar panel Udo Rumpf Soaring 18 February 17th 06 01:36 AM
