Anyone try paragliding?
Old May 24th 05, 12:40 PM
Stefan
Antońio wrote:
Yes. And if you had ever been in a paraglider yourself in a thermal
you would know that you often experience partial deflations.
My statement stands though: If you thermal in a paraglider you *will*
experience deflations.
Of course, I agree on this. But a partial deflation is not the same
thing as a collapsing canopee. A partial deflation is not inherently
dangerous. (More precisely: It is dangerous, if you're not adequately
trained, as are all aviation activities.)
Stefan
Old May 24th 05, 08:11 PM
Antońio
Stefan wrote:
thermal
*will*
Stefan
You say it is and it is not dangerous in the same paragraph. You don't
seem to realize that a full collapse begins with a wing tip deflation.
A deflation can go unrecognized even by an expert until it's too late.
You also failed to reply to my comment about ever having been in a
paraglider. Have you ever actually flown a paraglider?
I once flew a paraglider off of a 6000 ft mountain at about 10am when
the thermals were not yet developed. I launched, and had been flying
about 30 seconds when I noticed the relative wind pick up *beneath* me.
I looked down because I though it was kind of odd.
What I didn't realize was that I was falling and picking up speed. I
looked up just in time to see my paraglider reopen on its own. I was
very lucky it held together.
Later, my friends who had been watching my launch described my chute as
"a wadded ball of aluminum foil".
So don't tell me that paragliders don't collapse! =20
Antonio
Old May 24th 05, 10:08 PM
John Galban
Anto=F1io wrote:
The paraglider is not the same machine as a parachute, as you have
noticed.
snip
Thanks for the thorough explanation. I appreciate it!
John Galban=3D=3D=3D=3D=3DN4BQ (PA28-180)
Old September 1st 05, 12:59 AM
Dana M. Hague
On Sat, 21 May 2005 22:04:19 -0600, "Michael 182"
Very good info. I may reconsider... Thanks,
Michael, don't let all the scare stories scare you. Yes, paragliding
has its risks, just as does GA. Like GA, those risks can be reduced
by good training and careful decision making, and also like GA, can't
be eliminated. It's all about flying within your limitations and the
limitations of the aircraft.
I have around 200 hours now in _powered_ paragliders (following around
600 hours GA). Powered paragliding (PPG) is about the most fun I've
had in the air, and the motor gives the flexibility to avoid the
thermic conditions required to keep an unpowered paraglider or hang
glider aloft. A year or so ago, I looked at the statistics. The
number of PPG pilots in the U.S. isn't all that large and data is hard
to come by, but as near as I could figure, the fatality rate per hour
is about the same as GA (though the risk of a minor injury is higher).
Unpowered paragliding is somewhat (but not horribly or unacceptably)
worse.
To answer your original question, GA experience does help as general
background... not so much at first, or for the actual flying, but if
you continue with it there's some stuff that you won't have to relearn
(aerodynamics, airspace, regs, etc.)
-Dana
If replying by email, please make the obvious changes.
-------------------------------------------------------------------------------Dyslexics Untie!
Old September 1st 05, 01:13 AM
Larry Dighera
On Wed, 31 Aug 2005 19:59:55 -0400, Dana M. Hague
d(dash)m(dash)hague(at)comcast(dot)net wrote in
had in the air ...
A subscription to this magazine will give one an idea of the state of
the PPG art: http://www.ultraflight.com/
Old September 1st 05, 02:05 AM
BDS
"Dana M. Hague" d(dash)m(dash)hague(at)comcast(dot)net wrote in message
With a big emphasis on "the limitations of the aircraft". One huge problem
with a paraglider is that the wing can be compromised by turbulent air or
thermic action at the worst possible time, during your approach to land.
When you're 30 feet above the ground and your wing is suddenly 50% collapsed
due to localized turbulent air or a nearby thermal lifting off, no amount of
training is going to help you deal with the 30 foot plummet you are about to
experience because there isn't going to be time to recover.
One very important thing to keep in mind is that conditions that a GA pilot
wouldn't normally give a second thought to can be very significant to an
aircraft like a paraglider or an ultralight, especially when your legs and
feet are your landing gear.
Old September 1st 05, 07:10 AM
private
"BDS" wrote in message
problem
collapsed
of
to
Well spoken description of a significant risk. IMHO this risk increases
with the higher performance PGs. It claimed one of the very best PPL/HG/PG
(several time national champion) pilots I have known.
pilot
From personal experience my preference for free flight is hang gliders.
While they are a flex wing they have a ridgid frame and have much better
penetration and fly more like a traditional wing. Soaring them is a truly
exqusite experience. Current models are well developed and proven designs,
and even intermediate types offer good performance.
Old September 2nd 05, 01:24 AM
Dana M. Hague
thermic action at the worst possible time... no amount of
training is going to help you...
True. However, the training I refer to includes how to avoid these
conditions, often (at least by powered paragliders) by flying in the
calm air of early morning or evening.
No argument there.
-Dana
-------------------------------------------------------------------------------Don't put it off, procrastinate today.
  #29
Old September 2nd 05, 01:36 AM
Dana M. Hague
On Thu, 01 Sep 2005 06:10:53 GMT, "private"
The higher performance PG's are definitely riskier to fly. However,
the performance of even entry level PG's has gotten so close to the
performance models that most recreational pilots stick with the basic
models nowadays.
The flying is very different; certainly a HG has better performance...
but you lose in portability, and the higher speed adds its own element
of risk. Actually, HG and PG accident statistics are pretty similar.
-Dana
Cheap sailplanes tango4 Soaring 100 December 21st 04 08:21 PM
new pictures in Paragliding Gallery jaro Soaring 0 July 8th 04 11:30 PM
www with paragliding adds Mariusz Klos Aviation Marketplace 0 April 22nd 04 11:53 AM
New Paragliding Gallery jaro Soaring 0 December 28th 03 08:51 PM
Red Bull Vertigo 2003 Red Bull Vertigo Aerobatics 2 August 11th 03 08:02 PM
