#21
Lakeview Bill wrote:
When you are flying to a non-towered airport, do you always have to fly the pattern, or can you make a straight-in or crosswind approach? If these are permissible, under what circumstances? Thanks... I remember my examiner advocating a crosswind entry on my (private) checkride. He preferred it because of the visibility it gave of the runway, pattern and departing traffic. Otherwise, there are as many opinions on the supposedly correct way to enter the pattern as there are pilots (and as others have said, you don't have to fly a pattern at all if you don't want to). My personal preference is the 45 deg entry or, if the pattern is on the other side of the runway, crossing over midfield and joining the downwind there. I'll do straight-ins if I"m in a hurry (i.e. need to use the bathroom), but prefer to fly a full pattern normally. But that's just what I'm used to. LS N646F |
The "final" leg at uncontrolled airports is where most air-air
collisions and near misses occur. You have potentially converging traffic at the same altitude banking, turning and doing GUMPs checks all in a very confined space.My strong recommendation is to avoid straight in approaches at uncontrolled airports. it can be hard to see the guy turning from base to final who is flying a normal pattern and he is not too likely to see you. It may be legal to do straight ins...but it isn't prudent. |
On 30 May 2005 19:03:08 -0700, "Michael" wrote:
My strong recommendation is to avoid straight in approaches at uncontrolled airports. it can be hard to see the guy turning from base to final who is flying a normal pattern and he is not too likely to see you. It may be legal to do straight ins...but it isn't prudent. I bought my handheld radio the day after I turned final to see myself on collision course with a twin flying straight in at Hampton NH. (I turned 90 degrees for a bit, then followed him in.) I hadn't seen him, he hadn't seen me. Afterward he said: "Don't you have a radio in that thing?" (It was a J-3 Cub.) He was an instructor! He had a student flying the plane! It was his first-ever visit to this grass field which is flagged "intensive flight training"! As you say: legal but not prudent. Indeed, I would call it stupid. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net In Search of Lost Time: www.readingproust.com |
![]() "Paul Tomblin" wrote in message ... 5 miles out on an ILS is not "on final". Final is a part of the pattern, and unless you fly 5 mile patterns, that's not part of it. Well, there are those that do fly patterns with a five mile final. If right-of-way is an issue, they have it. Be sure to yield to them. |
Michael wrote:
The "final" leg at uncontrolled airports is where most air-air collisions and near misses occur. You have potentially converging traffic at the same altitude banking, turning and doing GUMPs checks all in a very confined space.My strong recommendation is to avoid straight in approaches at uncontrolled airports. it can be hard to see the guy turning from base to final who is flying a normal pattern and he is not too likely to see you. It may be legal to do straight ins...but it isn't prudent. Actually, I think you'll find that nearly all of those accidents involve either two aircraft on final who had flow the traffic pattern or involved an aircraft rolling out or departing on the ground. It's rare that there is a straight-in involved because most people DO fly the patterns. Your comments about people being distracted and fixated on the threshold is well take though. |
Cub Driver wrote:
I bought my handheld radio the day after I turned final to see myself on collision course with a twin flying straight in at Hampton NH. (I turned 90 degrees for a bit, then followed him in.) I'm confused. He was flying to the reciprocal runway? If you turned final and were on a collision course with a straight in for the same runway sounds like you were at fault. |
news ![]() 5 miles out on an ILS is not "on final". Final is a part of the pattern, and unless you fly 5 mile patterns, that's not part of it. Well, there are those that do fly patterns with a five mile final. If right-of-way is an issue, they have it. Be sure to yield to them. To reinforce this point: If a pilot has a question about right-of-way with an airplane on a five-mile final, then that pilot is flying a similarly "extended" pattern. If you're in a position where you *might* need to yield to an airplane on a five-mile final, then that airplane does have the right-of-way. Conversely, if you're flying a normal pattern, turning base 1/2 mile or so from the runway end, an airplane five miles out just isn't an issue at all. They'd have right-of-way if you were in their way, but you're not so their right-of-way is irrelevant. And yes, contrary to the example given, even a pilot on an IFR flight plan, once they are communicating on the CTAF they really ought to use landmarks and position reports that VFR traffic in the pattern will recognize. "Five-mile final runway 18", for example. Pete |
![]() "Jay Honeck" wrote in message news:WEtme.19232$IC6.15139@attbi_s72... With apologies to the FAA, this is a perfect example of what NOT to say at a non-towered, uncontrolled airfield. Example: We have a VOR 36 approach into Iowa City. The VOR is located ~9 miles south of the field, and often-times you will hear "Cessna 123-Tango is inbound from the VOR at 2500 feet on the VOR 36 approach, low approach only..." Primary students, transient pilots, and many VFR pilots have NO idea where that puts our friend in 123-Tango. He may as well not have announced at all. Well, Jay, based just on your description, without looking at any charts of the area, I'd say that announcement puts our friend in Cessna 123T something less than nine miles south of the field at 2500 MSL heading directly for the runway 36 threshold. Why do you believe others can't draw that same conclusion? Personally, I prefer to hear reports over a known fix or landmark or a DME distance. That way I know it's an accurate report and not a semi-wild-ass-guess. I think you'd be surprised how inaccurate some reports are. http://makeashorterlink.com/?T10E3223B More properly (and what I say when I'm practicing that approach) is "Iowa City Traffic, Piper N56993 is nine miles south of the field, over the VOR, inbound for landing on a practice VOR 36 approach..." with subsequent position reports when I'm 5 miles out and again entering the pattern. (Space permitting on the freq.) This helps everyone concerned. I think you're talkin' too much. There's no need to say you're over the VOR and also say that you're nine miles south of the field. The VOR's on the charts, transient pilots will know where it is and local pilots are familiar with it. |
#29
![]() "A Lieberman" wrote in message ... I agree with this "somewhat" as you need to remember, the student needs to learn the radio calls as well. So, any practice lessons with an IFR student should include IFR jargon as you state in his radio calls. With this in mind, I personally include VFR references in my approach into Madison, MS (MBO). When I practice approaches, I will say: Madison, Sundowner 12345L 5 miles NW, inbound VOR Alpha Madison. This tells all pilots my position relative to the airport, as well as tell any IFR traffic what my intentions are. If any pilot doesn't know where 5 miles NW is, then I would question their navigation abilities. I question the ability of many pilots to estimate distance. One pilot's 5 mile report is another pilot's 10 mile report. I'll trust a position over a charted fix or landmark or a DME distance, anything else I assume to be a SWAG. |
#30
![]() wrote in message oups.com... Question their navigation abilities or not, but these people are in the pattern. Remember, there are student pilots and they don't know which way anything is. Don't believe me? Do a google search on "landing pattern computer" and look at the products. Someone is buying these things. If they don't know which way anything is they shouldn't be in the pattern solo. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Newbie Question - Vacuum vs Electric | Bill Denton | Aerobatics | 1 | April 15th 04 11:30 PM |
Pattern Entry Procedures - FAA Guidance | Bill Denton | Piloting | 15 | January 22nd 04 02:13 PM |
Stupid hp to thrust question | Mark | Home Built | 52 | December 9th 03 01:41 PM |
Stupid super cub question | Robert Loer | Home Built | 9 | November 22nd 03 05:28 PM |
