Two Seat Cobra Trailer Tire Replacement
Old May 8th 21, 04:22 PM posted to rec.aviation.soaring
Robert Seccombe BE
Default Two Seat Cobra Trailer Tire Replacement
On our single axle two place glider trailer I destroyed the two original tires that were on it when I acquired it. One was just a cut in the sidewall that I discovered while parked. The other was a total failure while on the highway; and I wasn't aware of it but for another driver alerting me. The tire was completely missing and the rim was destroyed; this while towing behind a 21' class C. The replacement wheel and tire were from W&W. Though it does seem to tow somewhat better with the newer tires, I have never been happy with the way this trailer tows and I am seriously considering adding a second axle. The Airforce Duo Discus trailers are duel axle.
Old May 8th 21, 07:12 PM posted to rec.aviation.soaring
John Galloway[_2_]
Having had previous experience of one trailer losing a wheel and another having a dramatic tyre destruction, when we got a Duo with a Cobra trailer I over-ruled advice from Cobra and insisted on specifying the dual axle option. I came to regret this, partly because of the difficulty in hand manoeuvring it but mainly because the trailer, having a level it wanted to maintain that was not what the vehicle hitch wanted, tended to nod during towing.. Keeping the front axle tyres a little less inflated than the rear ones helped but did not eliminate this. It may have been more comfortable if the tow car did not have self-levelling suspension but I sold out of the glider before I sold the car.
Old May 8th 21, 10:18 PM posted to rec.aviation.soaring
Jon May
I used to have a Duo,We bought it new from the works in Germany, complete with a new trailer.
We rolled out of the works and on to the autobahn towards England.
The first pullover we stopped and put every thing at the hitch end of the trailer.
At the second stop we took our suitcases and everything we could find and put it in the front of the trailer.
We had the Duo 10 yeas and love it,I think the shock absorbers settled a bit because it never bounced that much again.
But I used to set the hitch weight to 75Kg which is the max allowable for the car, and I did this by adding a sand bag to the front locker.
In an earlier life I used to move boats on rented car trailers which are always double axle.
You will have an accident with one you just don't know when or how bad.
Having had previous experience of one trailer losing a wheel and another having a dramatic tyre destruction, when we got a Duo with a Cobra trailer I over-ruled advice from Cobra and insisted on specifying the dual axle option. I came to regret this, partly because of the difficulty in hand manoeuvring it but mainly because the trailer, having a level it wanted to maintain that was not what the vehicle hitch wanted, tended to nod during towing. Keeping the front axle tyres a little less inflated than the rear ones helped but did not eliminate this. It may have been more comfortable if the tow car did not have self-levelling suspension but I sold out of the glider before I sold the car.
Old May 9th 21, 04:25 PM posted to rec.aviation.soaring
Craig Reinholt
Add 30 + lbs to the nose of your glider trailer and see how it tows. It may fix your sway issues.
Craig
Old May 9th 21, 05:16 PM posted to rec.aviation.soaring
andy l
Craig
I didn't think John was talking about the trailer swaying.
I entirely agree with him. With two axles, uneven roads create a pitching moment on the trailer. Looking in the mirror, one can see the front bouncing up and down, sometimes an inch or more, and if this is relative to the car it means something is bending. Further, if the pitching is happening on a road that isn't straight, it means it could be adding unstable inputs in the yaw direction too.
So although some under-confident folks might think a twin axle trailer is more directionality stable, I'm not convinced, and there's certainly not enough benefit to make up for the drawbacks
On the worse ridged motorway I've driven on, the D1 from Prague towards Brno a few years ago. the pitching was so bad, shaking my head up and down, that I drove at 40 mph for a while, then turned off and took a different route towards Vienna. Then I avoided the road for a few years until I read it had had some work done - not fully resurfaced but planed down flat again.
The only advantage of twin axle over single is that if you have a puncture you can continue a bit to a better place to change the wheel, as for instance when I noticed a trail of sparks in the mirror while driving through road works contraflow, and carried on to the next services.
Old May 9th 21, 05:45 PM posted to rec.aviation.soaring
John Galloway[_2_]
Craig
That's correct Andy, that is exactly what I experienced - especially over ridged or concrete sectional motorway.
Old May 10th 21, 12:36 AM posted to rec.aviation.soaring
AS
Craig
On the worse ridged motorway I've driven on, the D1 from Prague towards Brno a few years ago. the pitching was so bad, shaking my head up and down, that I drove at 40 mph for a while, then turned off and took a different route towards Vienna. Then I avoided the road for a few years until I read it had had some work done - not fully resurfaced but planed down flat again..
We must be talking about two different tandem axle trailers here. ;-)
I have a Cobra tandem axle trailer with the original tires (175/70R14), which I run at the max. permissible pressure. For the last five years, I have made an annual trip from South Carolina to Moriarty, NM and back. That is roughly 1,500 miles (2,400km) one way, so I have accumulated roughly 15,000 miles (24,000km) on that route alone. The road conditions are not always the best and in some instances, one could have easily fried an egg on the highway's surface. The only difficult stretch is the elevated part of I-55 east of Memphis, TN, where the segmented concrete bridge is sagging in the middle of each segment. This will excite a severe nodding action, which can only be countered by slowing down to below 35mph. Even the 18-wheelers do that on this stretch. For the rest of the trip, the trailer is rock-solid around all three axis', i.e. it has zero tendency to either nod, rock left to right or fish-tail!
One big influence on the overall behavior of the trailer is what's in it and how the load is distributed. In my case, the heaviest part - the wing's center panel weighing in at 220# (100kg) - is located a few cm above the floor and centered over the axles. The wings have an aspect ratio of 25, so they are not very tall when placed leading edge down. The fuselage straddles the center panel just a few cm above it. The trailer is has an Aluminum top. With all that, I would venture to say that the CG is fairly low compared to other trailers. Also, in my case, the axle track (width from wheel flange to flange) is very wide compared to other trailers, which has to have a further stabilizing effect.
Another big influence on the trailer's stability is the type of vehicle towing it. I don't want to (re-)start a thread on this (there are several on RAS) but I am towing with a full-size Ford E150 van, which in itself is a heavy and very stable rear-wheel drive vehicle. I towed my trailer once with my VW Passat SW a short distance and although the trailer has well functioning and maintained brakes, I would not do that ever again. I wasn't sure who was actually in charge!
In summary, not all tandem axle trailers are the same and comparable. There are just too many variables in this equation.
Uli
'AS'
Old May 10th 21, 06:41 AM posted to rec.aviation.soaring
2G
On our single axle two place glider trailer I destroyed the two original tires that were on it when I acquired it. One was just a cut in the sidewall that I discovered while parked. The other was a total failure while on the highway; and I wasn't aware of it but for another driver alerting me. The tire was completely missing and the rim was destroyed; this while towing behind a 21' class C. The replacement wheel and tire were from W&W.. Though it does seem to tow somewhat better with the newer tires, I have never been happy with the way this trailer tows and I am seriously considering adding a second axle. The Airforce Duo Discus trailers are duel axle.
Add 30 + lbs to the nose of your glider trailer and see how it tows.. It may fix your sway issues.
Craig
Uli
'AS'
Trailers are designed with tandem axles because one axle can't carry the load of the trailer, not to provide greater stability. When turning while pulling a tandem the axles are not aligned with the center of rotation - they can't be because the axles are parallel. The tires want to go in a different direction than the rotation of the turn and must, to some degree, scrub to make the turn. This is why maneuvering them by hand is so difficult. The same thing is happening when being towed but the power of the tow vehicle forces the tires in the direction of the turn. This scrubbing action deteriorates stability, not enhances it.
Tom
  #29
Old May 10th 21, 08:05 AM posted to rec.aviation.soaring
Tango Whisky
The scrubbing action greatlyenhances stability againts swaying.
I have driven my twin-axle Catley trailer for 15 years, and it has been absolutely great, and the stablest trailer I have ever seen.
Le lundi 10 mai 2021 Ã* 07:41:50 UTC+2, 2G a écritÂ*:
Tom
  #30
Old May 10th 21, 12:39 PM posted to rec.aviation.soaring
andy l
Craig
Uli
'AS'
It's a little odd that you express scepticism about what John and I said, but then give an example of exactly the same thing happening with the same type of trailer in exactly the same circumstance, an uneven concrete surface
Cobra Trailer Spare Tire mount failure Barny Soaring 29 July 23rd 15 12:52 AM
Cobra trailer tire size? Tuno Soaring 15 June 8th 10 06:39 AM
Cobra trailer weatherstrip replacement Larry Goddard Soaring 0 November 25th 09 05:26 AM
Cobra Trailer Replacement Wheel Chip Bearden Soaring 5 September 29th 09 08:35 PM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 02:06 PM
