Procedure turn required?
Old June 5th 05, 08:03 PM
Bob Gardner wrote:
Gotta wonder why the protected airspace on the non-PT side is 1.4 miles wide
all the way out to the maximum distance. If flying on the black line is a
regulatory requirement, why not just protect the turn area alone?
Where did you get that number?
Old June 5th 05, 09:18 PM
Peter Clark
On Sun, 5 Jun 2005 10:53:40 -0700, "Bob Gardner"
Maybe to take into account and give some protection for VOR, onboard
equipment, and operator error? At the far end of the maximum 10NM
circle for a standard procedure turn distance, if the VOR itself was
drifted say 4 degrees and then your aircraft was off 4 degrees and
then you didn't have the exact number dialed in and so were off 1
degree to begin with... So say there is a combined error of 9 degrees
off, you're already 1.1NM off the 'desired' track at about 7nm, right,
but still would have a centered needle. Even with a perfect needle
(say glass cockpit for the VOR OBS setting and autopilot handling
accuracy) the VOR approach to 6B6 puts you at/over (I forget the exact
number right now) around 1NM to the right of the airport at the MAP.
It was quite interesting doing it under the hood, having the needle
centered the whole time, and then playing 'find the airport' when I
pulled up the hood.
Old June 5th 05, 11:41 PM
Matt Whiting
Probably because neither pilots, their nav radios more the ground VOR
stations are that accurate. :-)
Matt
Old June 6th 05, 12:47 AM
Peter Duniho
"Ron Rosenfeld" wrote in message
Yes, but "course" only refers to "The intended *direction* of flight in
horizontal plane measured in degrees from north." It does not refer to a
particular ground track.
Where does it say that?
On the other hand, there are "Some procedure turns are specified by
procedural track. These turns must be flown exactly as depicted."
As far as I know, that's to distinguish from those procedure turns that
require a particular kind of turn, versus those that simply require the
pilot to remain on the "protected" side of the turn. It has nothing at all
to do with whether one is supposed to fly the depicted outbound course.
Pete
Old June 6th 05, 01:31 AM
Ron Rosenfeld
On Sun, 5 Jun 2005 16:47:49 -0700, "Peter Duniho"
Pilot/Controller Glossary under the C's for Course
Old June 6th 05, 01:38 AM
Peter Duniho
I'm not aware of any reason that glossary is legally applied to words found
in FAR 97.3. The glossary exists to describe communications between pilots
and controllers, nothing more.
Pete
Old June 6th 05, 01:53 AM
Ron Rosenfeld
I don't know where you find a requirement that one must fly for any
distance at all outbound along the "depicted outbound course" in executing
a procedure turn that does not have a required track.
You cite 97.3 but that paragraph also states that "the point at which the
turn may be commenced, and the type and rate of turn, is left to the
discretion of the pilot". Some of the types of turns that would not
require flying along the charted outbound track include teardrop, racetrack
and 80-260. Even the 45° turn would not require flying along the "depicted
outbound course" if the pilot elected to start that turn immediately.
At the approach under discussion (KFUL VOR-A via the WILMA transition), I
would probably elect to fly a racetrack turn after Seal Beach and,
depending on the winds, I might never even be parallel to the charted
inbound course of 020 until I turned inbound. All perfectly legal
according to both 97.3 and the AIM.
Old June 6th 05, 05:54 AM
Peter Duniho
Asked and answered.
Unless by "turn" they are referring to the final course reversal, that
sentence IMHO basically makes this entire thread moot. That is, it answers
the question, and leaves the entire procedure up to the discretion of the
pilot.
Now, that's a fine interpretation by me. But I take it as granted that
those arguing that the entire procedure is required to be flown (absent the
explicitly stated exceptions, of course) feel that the sentence you quote is
referring only to the final course reversal, not the entire procedure turn.
racetrack
"depicted
All of your examples are ways to complete the course reversal *after flying
the outbound leg*. That is, if those are all valid methods for executing
the entire procedure turn itself, then surely so too is simply turning onto
the final approach course. So, either you are simply supporting my point,
or your examples are in no way a counter-example to what I've written.
If you have the discretion to choose your outbound track, why bother flying
outbound at all?
Pete
  #29
Old June 6th 05, 12:06 PM
Ron Rosenfeld
On Sun, 5 Jun 2005 21:54:12 -0700, "Peter Duniho"
outbound at all?
You are skipping over the part of the regulation which states that the
"point at which the turn may be commenced" is up to the pilot. There is no
MINIMUM length of an outbound leg. There is only a maximum length. You
can begin your turn (or course reversal if you will), immediately.
But if you do not see that, then further discussion here is pointless.
There is certainly nothing wrong with returning to the outbound course
after Seal Beach, flying outbound for some length that you determine you
want to; and then executing a 45° turn on the charted side, so long as you
remain within the mileage limit. But it is not the only valid, legal
method of executing the procedure.
  #30
Old June 6th 05, 01:50 PM
Matt
Especially at a VOR intersection.
Procedure turn required? Yossarian Piloting 85 July 6th 05 08:12 PM
Sports class tasking [email protected] Soaring 12 April 25th 05 01:32 PM
Agent86's List of Misconceptions of FAA Procedures Zero for 15 Putz!!! copertopkiller Military Aviation 11 April 20th 04 02:17 AM
