So, I was flying back home, happily burping all the shellfish I ate at the
Shelton Oysterfest, when my engine started speeding up. Well, it didn't really - but my tach said it did. Without touching the throttle, I went from 2400 rpm up to 3400. Funny, my airspeed didn't change. It looks like my sturdy, simple mechanical tach (bought used at OSH) has gone South on me. I pulled it out and removed the case. Everything inside looks great. It is cable driven through a magnetic coupling just like a car speedo. The needle has a return spring wound in a coil like a clock spring. I assume the calibration is done by setting the needle on its shaft in a position relative to the return spring, so a given rpm matches the needle position on the dial. I thought I would discover a broken return spring, but it looks okay. Turning the drive with an 1100 rpm electric drill shows ~2500 on the dial. If I allow the needle to bypass the stop pin and add an extra full turn of tension on the return spring, the tach shows the drill turning ~400. It looks like the needle has slipped on the shaft releasing about a half-turn of spring tension. Either that or A. the spring has developed a weak spot or B. the other end of the spring has come unsoldered from the frame. I don't think it's "B" because the entire spring would be unwound. Visual examination of the spring doesn't show any defects. Any ideas? Rich "May as well take it apart - it don't work" S. |
Ramifications of Cherokee Trim Jackcrew Failure | Bob Chilcoat | Home Built | 23 | June 9th 04 02:48 AM |
Tail flapper failure | Veeduber | Home Built | 2 | May 22nd 04 06:52 AM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
Interesting Flybaby wing failure analysis... | Richard Lamb | Home Built | 3 | August 27th 03 05:21 PM |
Hinges under stress - mechanical engineering type question | Corrie | Home Built | 21 | August 6th 03 08:49 AM |
