#21
Did, no answer there either! But, lots of people were willinig to share photographs with me. I just need to have someone who knows the answer to come by and see my post, I guess.
Quote:
"Christopher" wrote I also bought the plans for the STOL King but haven't received them yet. Although the general specs on this aircraft are enough for me to want to build one I have tried to get more detailed information about this aircrafts performance by emailing Preceptor aircraft twice and they will not respond other than to say thank you for the email and that they will get back with me later. Also, I found these numbers for the aircraft which differ by a large amount with what is currently on their web site: http://tinyurl.com/n4m6v I have tried to get the opinion of CPotter (post above) and although very friendly and helpful in every other way he is reluctant to guess on the performance figures I am looking for because his project isn't finished yet. Anyone know someone who has one flying right now and how to contact them ? There are BS flags all over the place, when looking at that web site. Turn around, and walk, no, turn and run away! Why does it have such long landing gear? To look like a storch. The difference is, the storch has it to get prop clearance, for greaat big props. BS alert! Now for what told me to tell you to run away. Did you see the HP rating for the VW engine they will sell you? THAT is a good one! (joke, that is) A VW engine that is rated for 103 HP???????? Give me a break!! If you somehow were able to get that much power out of a VW, the valves and head would be a big melted pile of aluminum and steel, within 2 minutes, or less. Also you would have to run it at super high RPM's, and that means you would need a small prop. Small props are only good for poor take-off performance, and high cruise speed. Sound like a STOL??? Nope. Run away! -- Jim in NC |
The STOL King was based on the 3/4 Storch kit being offered by a fellow in Australia which I believe had its origins in Europe somewhere (aside from the original Fi 156 Storch). Essentially, I think it is the same aircraft but streamlined quite a bit. I had heard (web searches) that he had partnered with them but for some reason they went their own ways and thus this aircraft came out of it.
Although this gear isn't the original 'Storch' gear I believe it is that long because the slats on the wings produce the best climb vs distance when at a high angle of attack. If this aircraft can get close to its claimed performance, even if not right on it, I would be happy and wouldn't have too much heartburn over the specs being fluffed a bit to keep up with all of the other fluffers but if they are far from unrealistic I would sure like to know before I invest more time and money into this. If I could just find one person who is flying one who would be willing to share their experiences and opinions about its performance (and there are completed STOL Kings out there) I could clear this up in a hurry. I have a couple of leads through web seaches but not easy to find contact information. Here is another kit version of the 3/4 scale Storch called the Criquet with performance figures similar to the STOL King but much heavier (Modified, modified 'Storch'): http://tinyurl.com/qupra The statement that a "VW engine can produce 100 HP" is misleading because this engine is different. They manufacture new jugs with more coolant flow and use a special high volume pump to keep them cool. Here is a link to their web page http://tinyurl.com/pbwb7 Chris in Palmer, Alaska Quote:
The Australian manufacturer is propably Nestor Slepcev:
http://www.slepcevstorch.com/index.htm JP "Christopher" wrote in ... The STOL King was based on the 3/4 Storch kit being offered by a fellow in Australia which I believe had its origins in Europe somewhere (aside from the original Fi 156 Storch). Essentially, I think it is the same aircraft but streamlined quite a bit. I had heard (web searches) that he had partnered with them but for some reason they went their own ways and thus this aircraft came out of it. |
I received an email response from Nestor for a quote:
Quote:
There is also this nice looking Australian kit aircraft Hornet STOL
developed by the Australian Aircraft Kits. Required building time seems to be quite reasonable. I don't know is it included in any link sections somewhere. http://www.aircraftkits.com.au/index.htm JP "Christopher" wrote in ... If anyone else is researching this I am putting links to all of the sites I can find about the STOL King and or Storch homebuilts plus a few others on a new yahoo group at: http://groups.yahoo.com/group/Extreme_STOL - there is no activity there but the links section of the group is full of lots of different homebuilt aircraft which will take off and land in 300 feet or less which is growing and may be helpful to others like myself who are deciding on which extreme STOL aircraft to build. |
Morgans wrote:
... Did you see the HP rating for the VW engine they will sell you? THAT is a good one! (joke, that is) A VW engine that is rated for 103 HP???????? .. Look again, Great Planes is claiming 120 HP: http://www.greatplainsas.com/llc1.html As noted elsewhere in this thread, the conversion to liquid cooled heads makes refering to it as a VW enigne questionable--sort of like referring to a Lexus as a NIssan. I don't see an estimate of total weight on that page, but it seems that the power to weight ration may be a tad unrealistic. -- FF |
#29
wrote \ Look again, Great Planes is claiming 120 HP: http://www.greatplainsas.com/llc1.html As noted elsewhere in this thread, the conversion to liquid cooled heads makes refering to it as a VW enigne questionable--sort of like referring to a Lexus as a NIssan. I don't see an estimate of total weight on that page, but it seems that the power to weight ration may be a tad unrealistic. Yep, and that has been scoffed upon by those better in the know than me. g I can also get over 750 HP out of a Chevy 350. Only one catch. It will blow up after about 6 hours. Is that what you want out of an airplane engine? Those kind of figures for a VW are about as realistic. Granted, the liquid cooled head may help get sustainable HP up from a realistic 45 to a bit more, but not that far, IMHO. -- Jim in NC |
#30
Having no experience with these modified VW engines myself I cannot defend their claims, nor can I deny them. Just thought I'd show what they have on their web site.
BTW: That 120 HP isn't sustained full power, just for takeoff. IMO I wouldn't call it a VW engine anymore, not with all of the modifications they have done to it. The size of the jugs and all of the changes to the original engine (including vastly increased cooling) determines the power rating of the engine, not the crank shaft. That is, assuming both it and the other original components, what ever is left of them, can take the increased stresses. |
| Thread Tools | |
| Display Modes | |
| Fly Baby Plans Sets Wanted | Ron Wanttaja | Home Built | 0 | June 9th 04 07:18 AM |
| Fly Baby Plans Off the Market | Ron Wanttaja | Home Built | 9 | June 6th 04 03:45 PM |
| Modifying Vision plans for retractable gear... | Chris | Home Built | 1 | February 27th 04 10:23 PM |
| What do you do with you plans? | Bill A. | Home Built | 2 | January 23rd 04 12:48 AM |
| Here's a silly question regarding plans | David Hill | Home Built | 21 | October 8th 03 05:17 AM |
