#21
On Wed, 06 Jul 2005 16:05:39 GMT, "Jay Honeck"
wrote: With the runway coming up at remarkable speed, I flared and put her down just past the numbers -- arriving like the proverbial load of sand. It was a perfect "3-point landing" -- except you don't *ever* want to land that nose-heavy 6-cylinder on the nosewheel! Jay, Do you have any speed mods? I have K2U's mods on my PA28-180 and the stabilator seal greatly improves pitch authority. It is easy to hold off the nose during landings (even power off). -Nathan |
stabilator seal greatly improves pitch authority. It is easy to hold off the nose during landings (even power off). Yep. A previous owner installed every speed mod available on our Cherokee 235. I didn't run out of elevator -- I just blew the flare, plain and simple. If I had pulled harder, the nose would've come up, but I am so used to the flare with power that the descent rate caught me by surprise. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Icebound" wrote: But the question really was: what are the consequences? Does it typically lug and die, or will it lug and lumber upward slowly, or do I get one of the above plus twist the crank, etc.??? Do I get away with it? None of the time? Most of the time? Once in while? I suppose it depends. G Pressures in the cylinder will be higher than normal, if taken to extremes you might crack a cylinder. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
On Thu, 07 Jul 2005 04:23:28 GMT, "Jay Honeck"
wrote: Do you have any speed mods? I have K2U's mods on my PA28-180 and the stabilator seal greatly improves pitch authority. It is easy to hold off the nose during landings (even power off). Yep. A previous owner installed every speed mod available on our Cherokee 235. I didn't run out of elevator -- I just blew the flare, plain and simple. If I had pulled harder, the nose would've come up, but I am so used to the flare with power that the descent rate caught me by surprise. Gotcha. Easy to do, which is why we need to practice these things... |
Next time you might try adding about 10 kts to you final approach speed
when power off. The extra speed will help compensate for the lack of power and make your flare easier. You also wont' need as much flap to get down. Brian CFIIG/ASEL |
and drop that third notch of flaps !!!!!!
Flaps with engine-out emergency landing ???????? Yeah, I've pondered that. I was too high, so I dropped the third notch -- which on my plane we NEVER do, when landing with power, unless we're going a short-field landing. Next time, I'll stick with two notches and land long(er)... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
and drop that third notch of flaps !!!!!! Flaps with engine-out emergency landing ???????? Yeah, I've pondered that. I was too high, so I dropped the third notch -- which on my plane we NEVER do, when landing with power, unless we're going a short-field landing. Next time, I'll stick with two notches and land long(er)... That's one reason I always land without power and with full flaps in normal wind conditions. That way if (when?) I have an engine failure and have to do it for real, it won't be a surprise. I've yet to fly an airplane that won't flare just fine without power, with full flaps and at the minimum airspeed recommended for approach in the POH. Matt |
normal wind conditions. That way if (when?) I have an engine failure and have to do it for real, it won't be a surprise. I've yet to fly an airplane that won't flare just fine without power, with full flaps and at the minimum airspeed recommended for approach in the POH. Well, it's not that it can't be done with our Pathfinder -- we did it that way for the first year or two we owned the plane. Then we were shooting the breeze with a previous owner of the plane (the guy who put all the speed mods on), and he told us his "two notches of flaps and roll the electric trim back as you're flaring" landing technique that he always used when he owned the plane. We tried it, loved it, and never went back. It's a landing technique that simply produces superior results on medium-length runways in our (somewhat) nose-heavy airplane. As an owner, I've decided that whatever produces the most consistent, smoothest landings is what we will use, in the interest of keeping maintenance costs (I.E.: Tires, brakes, struts, etc.) to a minimum. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#29
Jay Honeck wrote:
It's a landing technique that simply produces superior results on medium-length runways in our (somewhat) nose-heavy airplane. As an owner, I've decided that whatever produces the most consistent, smoothest landings is what we will use, in the interest of keeping maintenance costs (I.E.: Tires, brakes, struts, etc.) to a minimum. This technique may result in increased tire wear from higher landing speeds and increased rolling distances. Depending on runway length and conditions, you may also have increased brake wear. Strut wear shouldn't matter because, performed properly, the touchdown speed/rate of descent shouldn't be excessive at minimum airspeed. |
#30
speeds and increased rolling distances. Depending on runway length and conditions, you may also have increased brake wear. Strut wear shouldn't matter because, performed properly, the touchdown speed/rate of descent shouldn't be excessive at minimum airspeed. Something worth considering. However, all it takes is one really bad full stall landing on the nose wheel to make that excessive tire wear seem pretty inconsequential. ;-) Hasn't happened yet (Mr Piper built some pretty stout landing gear) -- but it's always something to consider. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| Thread Tools | |
| Display Modes | |
| Precision Landings and practice | [email protected] | Piloting | 34 | December 17th 04 03:08 PM |
| V-8 powered Seabee | Corky Scott | Home Built | 212 | October 3rd 04 12:45 AM |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 02:48 PM |
| Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 05:09 PM |
