I just removed my old Gill G-35 from my Archer and I'm waiting for a
Concorde RG35-AXC from Spruce. This non-sealed unit lasted a few months past 8 years while being flown about 2 hours per week. According to some spec's I was looking at (on the Concorde web page?) the sealed batteries do not require a battery box and can be mounted in any position, so I guess they are not expected to crack and vent. The failure mode for the old battery was a shorted cell spewing electrolyte against the inside of the battery box lid. Since it ate away the paint it would be easy to pick up on a routine inspection of the battery. Regards, Mike. "nrp" wrote in message oups.com... What are other people's experience with battery life? C172M - I've always gotten at least 8 years from the last three batteries. Just never let the plates get exposed to air, never let it get discharged & keep the top clean. I do not put any trickle charger on it unless everything is down for many weeks. I also have never had to use the ground service plug - except when the FAA Certified Repair Station left the master on after an annual....... |
On 7/6/05 13:59, "Maule Driver" wrote:
What are other people's experience with battery life? Going on six and a half years on a Concorde RG 25 in a Husky. However, I'm flying about 150 + hours/year. - Don History does not long entrust the care of freedom to the weak or the timid. - Dwight D. Eisenhower |
Maule Driver wrote:
What are other people's experience with battery life? The Concorde RGs in my Maule lasted about like yours. I got 6 years from the Gill in my Cessna. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
Jay Honeck wrote:
When I pulled the 8-year old battery out, there was an area of spilled acid/crusty stuff that had to be cleaned thoroughly. I'm looking forward to this new "sealed" battery eliminating that problem, and the yearly expense of paying my A&P to clean the battery box (and surrounding area) at every annual inspection. Yike! 8 years? I suspect that replacing that battery with ANY battery would have made it spin faster. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
You should check, but my understanding is that the RG batteries may only
last 2-3 years, and that the decreased life is a trade-off compared to normal lead acid batteries. For what it's worth, I was told to change the battery on the Extra (by necessity an RG) every two years, while the normal batteries in the Baron are a lot older and still crank well. |
last 2-3 years, and that the decreased life is a trade-off compared to normal lead acid batteries. Man, I hope not. At $162, this battery ain't cheap. Anyone got any real-life numbers on this? For what it's worth, I was told to change the battery on the Extra (by necessity an RG) every two years Why would they tell you to replace a battery based on the calendar? If it's still cranking fine, what other parameter is there to worry about? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
They (Extra) recommended changing the battery every two years since they
seem to know the history of the typical battery life (cranking the IO-540), and the fact that it is much easier to change the battery (an RG35XC) during an annual rather than waiting for it to die. (It involves taking all of the panels off of the plane as well as the front seat, so is much easier to do during an annual). In my much smaller Decathlon the battery seemed to last around three years before needing a change, so this sounds about right to me. |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 09:12 PM |
