The exiting data is not only compelling, it's pretty much overwhelming.
I'm glad you feel that way. Those of us who are actually qualified practicing engineers do not concur. Michael |
"Michael" wrote in message ups.com... The exiting data is not only compelling, it's pretty much overwhelming. I'm glad you feel that way. Those of us who are actually qualified practicing engineers do not concur. In what field of engineering? |
"Michael" wrote in message ups.com... The exiting data is not only compelling, it's pretty much overwhelming. I'm glad you feel that way. Those of us who are actually qualified practicing engineers do not concur. Why? Be specific and technical. -- Matt |
Where is your long-term field study comparing LOP and ROP operations? How many engines have been monitored in service from start to overhaul, under what conditions, and for how long? Have you shown a statistically significant difference in MTBF, service life, or cost of maintenance? That's really the only way to cover all bases. Sometimes this is not practical, but lacking a long term field study, you at least need a reasonable model. A compelling model would address the following issues, as a minimum: What are your parameters to asess engine roughness in normal LOP and ROP operations? How do you model the imperfections caused by pilot technique? Do you have amplitude and frequency data on engine vibration at various mixture settings? What kind of sensors did you use? Do you have long term operational data or at least a model showing the long term behaviour of the engine mounts, bearings, cases, crankshaft, etc. under the vibration conditions? Without long-term operational data, I would expect at least an FEA. Do you have any information at all on the differences in combustion end-products in excess-air vs. excess-fuel combustion reactions? I can assure you they are differrent. Are any of the combustion products harmful to the engine components long-term? Do any pose corrosion issues when the aircraft is not flown for several days or weeks, as commonly happens with private planes? How about that big mixture pull - it takes the mixture through peak. What is the effect of this transition on the crankshaft? Some analysis of this issue was done in the 1940's, using the limited available tools - but only for radial engines, which have significantly different crankshaft designs. For that matter, about the only large base of operational data in the LOP regime comes from radial engines - which are different - using 1940's and 1950's fuels which were significantly different than what you're burning now. I'm sure given time I could think of other issues. The main arguments for LOP operation are short-term economic ones - less plug fouling, lower fuel burn. These are pretty compelling. As for effect on TBO and general engine longevity, there has been much hype and no compelling evidence. BTW - to answer your other question - I run the R&D group for a major manufacturer of industrial instrumentation. So yes, this is pretty much right up my alley. Michael |
"Michael" wrote in message oups.com... Why? Be specific and technical. Where is your long-term field study comparing LOP and ROP operations? How many engines have been monitored in service from start to overhaul, under what conditions, and for how long? Have you shown a statistically significant difference in MTBF, service life, or cost of maintenance? That's really the only way to cover all bases. Sometimes this is not practical, but lacking a long term field study, you at least need a reasonable model. A compelling model would address the following issues, as a minimum: It's been done. What are your parameters to asess engine roughness in normal LOP and ROP operations? How do you model the imperfections caused by pilot technique? Do you have amplitude and frequency data on engine vibration at various mixture settings? What kind of sensors did you use? It's been done. Do you have long term operational data or at least a model showing the long term behaviour of the engine mounts, bearings, cases, crankshaft, etc. under the vibration conditions? It's been done. Without long-term operational data, I would expect at least an FEA. Five years of data. Do you have any information at all on the differences in combustion end-products in excess-air vs. excess-fuel combustion reactions? Yes. I can assure you they are differrent. Are any of the combustion products harmful to the engine components long-term? Do any pose corrosion issues when the aircraft is not flown for several days or weeks, as commonly happens with private planes? Non-sequitur. How about that big mixture pull - it takes the mixture through peak. What is the effect of this transition on the crankshaft? Some analysis of this issue was done in the 1940's, using the limited available tools - but only for radial engines, which have significantly different crankshaft designs. For that matter, about the only large base of operational data in the LOP regime comes from radial engines - which are different - using 1940's and 1950's fuels which were significantly different than what you're burning now. Bull****. I'm sure given time I could think of other issues. The main arguments for LOP operation are short-term economic ones - less plug fouling, lower fuel burn. Lower internal pressures, etc. All have been hypothesized, tested... These are pretty compelling. As for effect on TBO and general engine longevity, there has been much hype and no compelling evidence. Bull****. BTW - to answer your other question - I run the R&D group for a major manufacturer of industrial instrumentation. So yes, this is pretty much right up my alley. What sort of industry? Baed on that your only angle to comment on is about the test bed at http://www.engineteststand.com Not doing tests? A 64 point analysis tool, doing thousands of readings a second? I'm seeing something here besides naiveté on your part. I'm claiming "Bull****" on your part. |
| Thread Tools | |
| Display Modes | |
| Looking for JPI's older software to download engine monitor data to a PC | Peter R. | Piloting | 11 | February 14th 05 09:58 PM |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 07:48 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
