"Refusing to Handle You"
Old July 17th 05, 02:59 AM
Steven P. McNicoll
"A Lieberman" wrote in message
Putting me into a heading that weather may compromise my safety. I am
basing this on Mikes original post.
Denying you your desired route does not require you to fly into any weather.
Old July 17th 05, 03:08 AM
A Lieberman
If the weather was behind you like Mike described, and you can't proceed
forward, that in my opinion would be an emergency. He couldn't go further
on, and had to retrace his steps which would put have put him into bad
weather. His words we
So now, here I am, in the air with two small kids
on board, and being turned back towards what was, a while back at
least, some nasty weather.
I am making a lot of assumptions, since Mike was the one there and I was
not, so I don't know any other alternatives he had.
Again, if the weather was behind him and he couldn't proceed further on,
being turned back into nasty weather (his words, not mine) can be
considered an emergency.
Allen
Old July 18th 05, 02:03 AM
Richard Kaplan
You are PIC. I would have declared an emergency and squawked 7700.
No emergency declaration. "Unable reroute" is all that is necessary.
Richard Kaplan
www.flyimc.com
Old July 18th 05, 02:59 AM
A Lieberman
Richard,
See http://asrs.arc.nasa.gov/report_sets_nf.htm and download the .pdf file
for weather encounters.
If the heavy iron pilots says unable and follows up by declaring an
emergency and squawking 7700, then there must be some substance to my
position.
I don't think unable is enough to keep you out of hot water or puts the
ball in ATC's court. If ATC cannot accommodate an "unable", then you need
to declare an emergency. This is well documented in the .pdf file I am
pointing you to. Once you declare an emergency, ATC has to comply with
your requests.
To override an ATC directive (or in this case "non directive"), I'd suspect
a plan of action would be needed and rather quickly if ATC has not offered
a second option (which sounds like what happened in Mikes case).
From Mikes original post, it did not appear he had too many options.
He has since then clarified he had a couple of "outs" to sort this out (I.E
go hold at HGR or land at HGR).
If Mikes situation happened to me, and I do have storm scope in my plane,
and I knew there was bad weather behind me, I will not hesitate to declare
an emergency IF I THINK THE SAFETY OF MY FLIGHT is compromised.
Allen
Old July 18th 05, 04:06 AM
Richard Kaplan
Richard Kaplan
www.flyimc.com
position.
Note that in the report you mention it is ATC that mentioned pilot emergency
authority. That sounds to me as if the controller did it to cover himself
when he realized he should not have given the pilot the clearance through
the restricted area. Note that the airline pilot did precisely what I have
suggested -- he told ATC he was "Unable" to accept the new clearance.
suspect
The biggest problem I see here is the implication of the urgency with which
the controller wanted the pilot to accept the reroute or propose an
alternate plan.... no dice. That is the controller's problem unless he
provided a very good reason for the urgent change, i.e. some major radar
outage or national security event or something similar. In a situation as
described, the pilot has every right to think through his options and get a
new weather briefing and whatever other information is necessary to decide
if a re-route is safe before accepting a new clearance -- indeed, the FARs
REQUIRE the pilot to be aware of "all available information" for the planned
route of flight. Absent some national security emergency, there is no
reason to rush into accepting a revised clearance through weather -- and
"Potomac will not accept you" is NOT a national security emergency.
an emergency
Again... no emergency declaration is necesary on the pilot's part... just
the magic word "Unable" or perhaps "Unable reroute into convective weather."
Old July 19th 05, 01:23 AM
Steven P. McNicoll
"Richard Kaplan" wrote in message
news:1121656021.b4838ad7ee7d5a53cc4632516df5ffcc@t eranews...
emergency authority. That sounds to me as if the controller did it to
cover himself when he realized he should not have given the pilot the
clearance through the restricted area. Note that the airline pilot did
precisely what I have suggested -- he told ATC he was "Unable" to accept
the new clearance.
But he did it to avoid an area of weather.
Old July 19th 05, 01:07 AM
Steven P. McNicoll
position.
But he's saying it because the ATC instruction would have put him in bad
weather, that's not the situation we're discussing here.
your requests.
Sure, but what's your emergency in the case we're discussing? Declaring an
emergency when none exists won't keep you out of hot water.
Old July 28th 05, 07:37 PM
Robert M. Gary
Changing squawk code seems like a bad idea (as well as totally
unnecessary). You are already radar identified, changing squawk code
would just "un identify" you. Seems bad.
As far as declaring an emergency goes, I would only do that if there
was no other route that would not endanger me. Perhaps if TS were
closing around me that would be an emergency. Being irritated that you
must turn back and go back to the airport you took off from doesn't
sound like a reason to roll fire trucks.
-Robert, CFI
Old July 18th 05, 11:26 PM
Steven P. McNicoll
news:1121648616.ba937d939e05237b4228738fe266ced1@t eranews...
That's not a particularly useful answer to the controller's request for your
intentions. If you're on a route that takes you through Potomac approach
and you're informed that Potomac approach won't accept your flight it
follows that you will be rerouted in some manner.
Old July 19th 05, 12:01 AM
Richard Kaplan
But why didn't ATC just issue the re-route instead of saying "State
Intentions"? The whole things just seems weird, as if ATC were in an
unstated and subtle fashion encouraging cancelling IFR.
Richard Kaplan
www.flyimc.com
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 04:54 AM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
G103 Acro airbrake handle Andy Durbin Soaring 12 January 18th 04 11:51 PM
How do you handle your EFB in the cockpit? greg Instrument Flight Rules 5 November 17th 03 03:47 AM
Need door handle for 1959 Cessna 175 Paul Millner Owning 0 July 4th 03 07:36 PM
