#21
In article eUhEe.68$S72.32@trndny06,
George Patterson wrote: wrote: Hmmm, so Foam is needed in an airplane fire. Probably takes a specially equipped and expensive truck, dedicated to airport duty. Nope. You need the same equipment for auto fires, and for the same reasons. Most airports count on service from the local fire department if they need it. Yes and no. It's possible to dispense foam with limited equipment. All you need is a supply of foam (usually a 5 gallon bucket), an eductor and a charged hoseline. This is the kind of equipment carried by most structural fire departments. It takes a while to deploy and is limited in volume of agent applied. If the airport is under part 139 (I think it's still 139) then the trucks will be dedicated crash/rescue vehicles...they will have to be to meet the specifications. The trucks can arrive quickly at the crash sight and dispense huge quantities of fire fighting agent very quickly. Even the "little" crash trucks put out around 1000GPM, the big guys are closer to 2000GPM. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Dale wrote: In article eUhEe.68$S72.32@trndny06, George Patterson wrote: wrote: Hmmm, so Foam is needed in an airplane fire. Probably takes a specially equipped and expensive truck, dedicated to airport duty. Nope. You need the same equipment for auto fires, and for the same reasons. Most airports count on service from the local fire department if they need it. Yes and no. snip If the airport is under part 139 (I think it's still 139) then the trucks will be dedicated crash/rescue vehicles...they will have to be to meet the specifications. The trucks can arrive quickly at the crash sight and dispense huge quantities of fire fighting agent very quickly. Even the "little" crash trucks put out around 1000GPM, the big guys are closer to 2000GPM. Just to keep the score straight, Part 139 only applies to airports that serve commercial passenger operations, primarily airlines. Therefore there is no statutory requirement for a dedicated firefighting resource at the vast majority of public-use airports. Part 139 overview: http://www.faa.gov/arp/certification/overview.cfm -cwk. |
| Thread Tools | |
| Display Modes | |
| ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 09:40 PM |
| twin tail questions | Kevin Horton | Home Built | 12 | January 2nd 04 04:21 PM |
| Trexler now 7th Air Force commander | Otis Willie | Military Aviation | 0 | November 28th 03 12:32 AM |
| True costs of a light twin... | Captain Wubba | Owning | 20 | November 20th 03 03:32 AM |
| Air Force names best commander, spouse team | Otis Willie | Military Aviation | 0 | September 24th 03 01:10 AM |
