Two nearby ASOS broadcasts on the same frequency: Why no squeal?
Old August 12th 05, 12:09 AM
Dave Stadt
"Ron Parsons" wrote in message
"Peter R." wrote:
For some reason known only to the FAA, both Dunkirk, NY (KDKK), and
Wellsville, NY (KELZ), two small, uncontrolled airports in southwestern
NY
state that are about 60 nm apart, share the same ASOS frequency.
For pilots flying to Dunkirk from the east, retrieving the current ASOS
broadcast is not possible until about 25nm east of the airport, due to
more powerful KELZ broadcast. This is not so much a problem when
conditions are VFR, but when they are IFR I prefer to retrieve the ASOS
as
early as possible in order to choose and prepare for a particular
instrument approach.
In any case, I am curious how it is possible for two transmissions to be
heard over an aviation frequency without the squeal (I forgot the
appropriate technical term for this).
It's not unusual for a chain of transmitters to broadcast on what
appears to be the same frequency. They are actually all set about 5khz
apart and aviation radios filter out the squeal. That filter also makes
it more difficult to hear the higher pitched female voice.
Guess every aviation radio I have ever used was broken 'cause they all
squeal. I think you need to review basic radio theory as it applies to our
dear old AM aviation radios.
Old August 12th 05, 12:13 AM
RST Engineering
One sheriff, several sheraphim
One kleenex, several kleenesces
One moose, several meese
....we can keep going if you like {;-)
nk.net...
"john smith" wrote in message
Does it work on spouses and kids?
If the plural of mouse is mice, why isn't the plural of spouse spice?
Old August 12th 05, 01:27 AM
George Patterson
It is. It gets *real* hot if you have more than one.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 12th 05, 01:29 AM
George Patterson
Newps wrote:
Dave Butler wrote:
Ron Parsons wrote:
That filter also makes it more difficult to hear the higher pitched
female voice.
Where can I get one of those?
Every man gets issued one at birth.
The natural filter can be enhanced by extensive use of a rifle range without
hearing protection. In a pinch, a circular saw or a router will do the same, but
it takes longer.
George Patterson
Old August 12th 05, 03:35 AM
W P Dixon
For a Man,
The plural of spouse is ALIMONY
Patrick
student SPL
aircraft structural mech
"George Patterson" wrote in message
news:P1SKe.6112$lK2.3883@trndny01...
George Patterson
Old August 12th 05, 05:56 AM
Morgans
"RST Engineering" wrote
Having said that, since power consumption for a ground station is not a
primary concern, you can put the electronic device that controls frequency
into a temperature chamber (crystal oven) and expect that day in and day
out
it will be within a few Hz. of where it was originally set.
Is this still commonly done today? What is a crystal oven, how big, and how
is the temperature regulated?
What? (wha) I (wha) can't (wha) hear (wha) you! (wha) g
Old August 12th 05, 05:59 AM
RST Engineering
The etymology of the word "alimony" is from the Latin, meaning to drag a
man's wallet out through his testicles.
"W P Dixon" wrote in message
For a Man,
Old August 12th 05, 06:01 AM
Morgans
Cut off your testicles, and start taking hormones.
Sorry gang, I typed it and hit send before I realized my alter ego did it.
g
  #29
Old August 12th 05, 06:14 AM
RST Engineering
Oh, it is common and fairly easy. You simply say, "the temperature here
will never exceed (some number say) 60d C. You then calculate the
parameters for the crystal oven for a fair margin of error (say, 65d C)
The crystal is about the size of two dimes held face to face. The oven is
about the size of four quarters held face to face with a cutout in the
middle to accept the crystal. On one side of the face of the quarters is a
fairly large resistor (1-5 watts) bonded with thermal epoxy to the face of
the outside quarter. On the opposite face is the temperature sensor,
similarly bonded to the quarter (thermistor or diode; I prefer diodes)
A controllable heater heats the resistor. When the temperature of the
quarters exceeds the temperature set of the thermistor/diode, the heater
shuts off. It is a bang-bang servo. There are a THOUSAND refinements that
you all can have.
how
  #30
Old August 12th 05, 07:36 AM
Morgans
Who'uda thunk I'd learn something new today, when I got up? Not me, and not
here! g
Thanks! (I bet that makes yur life wurth liv'n) ;-))
RAP & RAH Oshkosh field frequency RST Engineering Owning 24 July 23rd 05 03:42 AM
RAP & RAH Oshkosh field frequency RST Engineering Piloting 20 July 23rd 05 03:42 AM
Boston Approach frequency question John R Piloting 6 June 22nd 04 08:22 PM
Picking up ATC from 300 NM away? Frequency bleed? Peter R. Piloting 10 August 21st 03 02:32 PM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 04:03 PM
