#21
I was going to spend = $30k on a taildragger.
Your realistic options, if you want to stick to metal (and lacking a hangar, I certainly would) are a C-120 or C-140 (many are now all-metal), a Luscombe, a metallized short wing Piper (Pacer, Clipper, etc - there are a few out there), and the oddball conversions. There are C-150's and Yankees converted to tailwheel. There are also some experimental options. Other than just flying around (which all of them will do) what is your actual mission profile? Rough/short strips? Long trips? What made you choose the Texas Taildragger to begin with? Michael |
Maule Driver wrote:
Is that without paint? That's the whole job, paint and all. I got that price from Rautgunde several years ago, though. It may have gone up. They also had a price of ~$15,000 for a complete renovation. By the way, I have a '96 "we have them on sale" MX7180a model (actually built in '95). Not the good paint (still doing it against the hangar wall). Not the really bad (auto)paint. IOTW, it chips off slowly. If I'd bought the 180, I might still have mine. On the other hand, the loan would've been larger and I might have lost it all. I found out what the paint scheme was from a Randolph representative at Oshkosh several years ago. He said that Maule used the Ceconite process, which specifies a coat of nitrate dope, followed by silver butyrate. He said they would add a coat of white butyrate over the silver as a primer and then spray the enamel over that. He said it was possible to sand off the color coats (the enamel) down to the white dope primer or even down to the silver. Don't go into the silver coat at all -- if you see it, stop. Once you get the enamel off of the fabric, spray with butyrate rejuvenator. After that, you can apply either polyurethane or butyrate top coats. If you're plane is like mine was when I sold it, you can see patches of the white butyrate where the color coats have flaked off of the horizontal stabilizer. We did not discuss redoing the paint on the metal or fiberglass sections (unless maybe he was recommending that technique for those sections too). I know that the upper surfaces of my wings were badly peeled by the time I sold it, so something would have to be done there. Since chemical paint strippers will melt Ceconite in a heartbeat, I would consider something like bead-blasting. Randolph made the paints Maule was using back then. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
"Michael" writes:
I was going to spend = $30k on a taildragger. Your realistic options, if you want to stick to metal (and lacking a hangar, I certainly would) are a C-120 or C-140 (many are now all-metal), a Luscombe, a metallized short wing Piper (Pacer, Clipper, etc - there are a few out there), and the oddball conversions. There are C-150's and Yankees converted to tailwheel. There are also some experimental options. Other than just flying around (which all of them will do) what is your actual mission profile? Rough/short strips? Long trips? What made you choose the Texas Taildragger to begin with? I was going through my logbook, and I realized that 2/3 of my PIC time over the last year was taking friends on tours of the SF Bay. I want a taildragger because I want to up keep proficiency my, and because they are more fun (e.i. fewer people have them). My thinking is that anything I can rent, I'm better off renting than owning. That includes 1X2 Cessnas, Cherokee-derived Pipers and Citabrias. I'm buying my first airplane; I want to make sure I don't bite off more than I can chew in terms of TCO. I've never had to deal with aircraft maintenance, and even though I wan to learn, my experience right now is limited to clearing fouled plugs. As far as certified taildraggers go, TTs are about the least demanding in maintenance, parts and mechanics AFAICT, followed closely by 120/140. I also like the side-by-side seating - nice when you're flying with a friend you want to talk to, though not an absolute requirement. I should also mention that I'm 6'5" (though skinny so I weigh the FAA-legal 170lbs) I'm not set on a TT, it just seemed to fit the bill. I've heard of tailwheel Yankees, but have never see one. A TT is a C-150/152 converted to TW, right? I've never flown a Luscombe, but it would probably work if I find one in good shape within the budget. You also mention experimentals. My anecdotal experience with them suggests that the high-quality ones are priced at least as expensively as certified airplanes, and the affordable examples often show average workmanship. (I've been an EAA member since 1993 but never got serious enough about buy an experimental to make a statement here) Ari. -- Elections only count as free and trials as fair if you can lose money betting on the outcome. |
A TT is a C-150/152
converted to TW, right? Yup. I should also mention that I'm 6'5" (though skinny so I weigh the FAA-legal 170lbs). You'd better see if you can get into a 150. The bottom of the panel will be banging your legs and your head will be close to the ceiling. We had 150s as trainers and tall guys didn't like them. Dan |
That's what I seem to have. I bought some Randolph paint to touch-up
but never did. I have chipping on the stab as you described. Wings are fine except for fairings. In fact, every surface facing the prop blast as been chipped to primer due to flying in the rain. Oh well. I would love to get it redone. With 900 to go to TBO, I'll probably fly it out while doing some homebuilding. Except for the chipping paint, it's been a (cheap) joy. Simplicity is good. BTW, I didn't buy new - 3rd owner at 35 hours. Thanks! George Patterson wrote: I found out what the paint scheme was from a Randolph representative at Oshkosh several years ago. He said that Maule used the Ceconite process, which specifies a coat of nitrate dope, followed by silver butyrate. He said they would add a coat of white butyrate over the silver as a primer and then spray the enamel over that. He said it was possible to sand off the color coats (the enamel) down to the white dope primer or even down to the silver. Don't go into the silver coat at all -- if you see it, stop. Once you get the enamel off of the fabric, spray with butyrate rejuvenator. After that, you can apply either polyurethane or butyrate top coats. If you're plane is like mine was when I sold it, you can see patches of the white butyrate where the color coats have flaked off of the horizontal stabilizer. Randolph made the paints Maule was using back then. |
Maule Driver wrote:
I would love to get it redone. One thing you might consider is to fly it down to Moultrie for an annual inspection and have the work done at that time. Of course, Maule Flight isn't the cheapest place for an annual, but they do the best work on Maules of any place I know of. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
#29
A question for you "dopers" out there.
I have seen a Citabria fabric aircraft sitting in a shop with the floor covered in big paint pieces that I was told had been stripped by using shop air and a small air nozzle on a blow gun. I had flown the aircraft previously and while it's dope (could be paint?) wasn't great it was flyable. I was told that the surface coat had come off surprisingly easily and the silver primer that was left looked like it would not require much further preperation for paint. I was told it only took a couple of hours. If I remember correctly the wings and control surfaces were removed and finished separately. Is it common to be able to remove paint or dope in this manner? "George Patterson" wrote in message news:9j9Ne.10281$Yb.7100@trndny06... Maule Driver wrote: Is that without paint? That's the whole job, paint and all. I got that price from Rautgunde several years ago, though. It may have gone up. They also had a price of ~$15,000 for a complete renovation. By the way, I have a '96 "we have them on sale" MX7180a model (actually built in '95). Not the good paint (still doing it against the hangar wall). Not the really bad (auto)paint. IOTW, it chips off slowly. If I'd bought the 180, I might still have mine. On the other hand, the loan would've been larger and I might have lost it all. I found out what the paint scheme was from a Randolph representative at Oshkosh several years ago. He said that Maule used the Ceconite process, which specifies a coat of nitrate dope, followed by silver butyrate. He said they would add a coat of white butyrate over the silver as a primer and then spray the enamel over that. He said it was possible to sand off the color coats (the enamel) down to the white dope primer or even down to the silver. Don't go into the silver coat at all -- if you see it, stop. Once you get the enamel off of the fabric, spray with butyrate rejuvenator. After that, you can apply either polyurethane or butyrate top coats. If you're plane is like mine was when I sold it, you can see patches of the white butyrate where the color coats have flaked off of the horizontal stabilizer. We did not discuss redoing the paint on the metal or fiberglass sections (unless maybe he was recommending that technique for those sections too). I know that the upper surfaces of my wings were badly peeled by the time I sold it, so something would have to be done there. Since chemical paint strippers will melt Ceconite in a heartbeat, I would consider something like bead-blasting. Randolph made the paints Maule was using back then. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
#30
private wrote:
Is it common to be able to remove paint or dope in this manner? The Randolph paint rep to whom I spoke said that it is not unusual for an enamel top-coat to peel off of dope this way; in fact, he said I might try using a pressure washer on my Maule to see if I could avoid sanding the enamel off. I've never seen dope top-coats separate from dope undercoats, but perhaps it's possible if the undercoat was not prepared properly. I do not know how well polyurethane bonds to dope. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
George Jr sent out of Texas by father as a 'drunken liability' | WalterM140 | Military Aviation | 17 | September 9th 04 05:26 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
Texas Soars into Aviation History | A | Piloting | 7 | December 17th 03 02:09 AM |
Bob Wander at Marfa, Texas | Burt Compton | Soaring | 0 | September 16th 03 02:59 PM |
good book about prisoners of war | Jim Atkins | Military Aviation | 16 | August 1st 03 10:18 AM |
