#21
![]() George Patterson wrote: Roger wrote: That doesn't make sense as commercial aircraft travel is considered about the safest form of travel. Of course they could be including crop dusters. PPL would not, or should not be in that category. They said they're including all types of professional pilots. Crop dusters and bush pilots included. It isn't dangerous to go skydiving (1-in-10000 chance of dying) once. But "being a regular skydiver" where one jumps 100 or perhaps 1000 times in a lifetime gives you a much less trivial chance of being killed. These numbers would be more interesting if they broke out airline flying by regional/commuter versus longer-haul ops. My brother-in-law flies 767s for UPS on international routes, but started out on a Beech 1900 with Mesa. At Mesa he might have made 6 or more flights in one day, versus UPS where he might do 12 in a month. IIRC risk on 121 airlines is proportional to the # of TO/landings. -cwk. |
If each jump carries a 1-in-10000 chance of dying, wouldn't the 1000th
jump also carry a 1-in-10000 chance of dying? Yes. But the odds of being dead before reaching the 10,000th jump increase with each jump you make. Jose -- Quantum Mechanics is like this: God =does= play dice with the universe, except there's no God, and there's no dice. And maybe there's no universe. for Email, make the obvious change in the address. |
On Tue, 30 Aug 2005 14:57:28 GMT, Jose
wrote: If each jump carries a 1-in-10000 chance of dying, wouldn't the 1000th jump also carry a 1-in-10000 chance of dying? Yes. But the odds of being dead before reaching the 10,000th jump increase with each jump you make. The more times the coin turns up heads, the more likely the next toss will be tails? Actuary's numbers relate to populations, not individuals. But you knew that. You just left out the smiley Don |
"Jim" wrote in message
... It isn't dangerous to go skydiving (1-in-10000 chance of dying) once. But "being a regular skydiver" where one jumps 100 or perhaps 1000 times in a lifetime gives you a much less trivial chance of being killed Curious. Not really. If each jump carries a 1-in-10000 chance of dying, wouldn't the 1000th jump also carry a 1-in-10000 chance of dying? Yes, assuming the jumper survived the first 9999 jumps. The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. The difference is that the first jumper's probability of the first 9999 jumps are all 100% successfully, having been made in the past. If one flips a fair coin, over the long run there is a 1-in-2 chance of either side coming up. Yes, but there isn't a 1-in-2 chance of flipping ten heads (say) in a row. Except, of course, if one is improbable enough to flip nine heads in a row, then the tenth head is 1-in-2. If one flips a fair coin 1 million times do the odds of either side coming up change? One is not just loooking at the last flip, one is looking at the accumulation of *all* the flips. For instance, it's no good surviving the 10000th jump, if you didn't survive the 7359th. :-) :-( :-S "Don Tuite" wrote: Actuary's numbers relate to populations, not individuals. Does the parachute know whether 10,000 jumpers made one jump each, or whether one jumper made 10,000 jumps? -- Jeff Shirton jshirton at cogeco dot ca Keep thy airspeed up, lest the earth come from below and smite thee. - William Kershner Challenge me (Theophilus) for a game of chess at Chessworld.net! |
Ah yes, but flying a small, tandem, amphibious aircraft hangared at my
particular airport, flown by a 50 something pilot with Commercial, IFR and CFI ratings, is actually quite safe, statistically. In fact, I don't believe there has EVER been a fatality in one of those! |
![]() wrote in message oups.com... "Jim" wrote in message ... It isn't dangerous to go skydiving (1-in-10000 chance of dying) once. But "being a regular skydiver" where one jumps 100 or perhaps 1000 times in a lifetime gives you a much less trivial chance of being killed Curious. Not really. If each jump carries a 1-in-10000 chance of dying, wouldn't the 1000th jump also carry a 1-in-10000 chance of dying? Yes, assuming the jumper survived the first 9999 jumps. The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. No, if the abolute odds of not surviving A jump are 1:10,000. The odds of death are 1:10,000 on jump #1,#2,...#10000...#20000. The dice don't have a memory. Which is exatly what you say below so I think you just mis-spoke above. The difference is that the first jumper's probability of the first 9999 jumps are all 100% successfully, having been made in the past. If one flips a fair coin, over the long run there is a 1-in-2 chance of either side coming up. Yes, but there isn't a 1-in-2 chance of flipping ten heads (say) in a row. Except, of course, if one is improbable enough to flip nine heads in a row, then the tenth head is 1-in-2. If one flips a fair coin 1 million times do the odds of either side coming up change? One is not just loooking at the last flip, one is looking at the accumulation of *all* the flips. For instance, it's no good surviving the 10000th jump, if you didn't survive the 7359th. :-) :-( :-S "Don Tuite" wrote: Actuary's numbers relate to populations, not individuals. Does the parachute know whether 10,000 jumpers made one jump each, or whether one jumper made 10,000 jumps? -- Jeff Shirton jshirton at cogeco dot ca Keep thy airspeed up, lest the earth come from below and smite thee. - William Kershner Challenge me (Theophilus) for a game of chess at Chessworld.net! |
#29
![]() "Doug" wrote in message oups.com... Ah yes, but flying a small, tandem, amphibious aircraft hangared at my particular airport, flown by a 50 something pilot with Commercial, IFR and CFI ratings, is actually quite safe, statistically. In fact, I don't believe there has EVER been a fatality in one of those! But Doug, you're not statistically relevant until you die in a crash and burn. Then, because since relatively few people do crash and burn you will have an effect on the statistics. Think about it. |
#30
... The probability of a person having successfully made 9999 jumps surviving his 10000th jump is very different (and less) than the probability of a person who has made no jumps, successfully making 10000 safe jumps. I've been inclined to see each event as independent of and not influenced by any preceding events. Well, in a case like this, it's not true. While each jump taken in isolation has the same probability, the odds of a successful 10,000th jump certainly *are* dependent on having 9,999 successful jumps before hand. If any of those previous 9,999 jumps are unsuccessful, then the probability of a successful 10,000 jump is 0%. Jeff Shirton jshirton at cogeco dot ca Keep thy airspeed up, lest the earth come from below and smite thee. - William Kershner Challenge me (Theophilus) for a game of chess at Chessworld.net! |
Ten Years of Flying | Jay Honeck | Piloting | 20 | February 19th 05 02:05 PM |
How safe is it, really? | June | Piloting | 227 | December 10th 04 05:01 AM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
