Starting new C172s
Old September 5th 05, 04:40 PM
navghtivs
Default Starting new C172s
I have flown it 6~7 times now, and still find starting the engine of
new Cessna 172S quite tricky, and often I have to try two or three
times to start it. I never had problem in older C172s.
So what's the trick, guys? How much throttle (1/8, 1/4 or 1/2 inch) do
you open? How fast do you advance the mixture when the engine starts to
fire? Anthing else?
Thanks
Old September 5th 05, 06:15 PM
Well I think each airplane is slightly different.
However I fly most the newer 172SP, and what I have found is that you
need to prime (Fuel pump on, mixture rich) for a little longer than
what the POH specifys. Otherwise it just cranks, and cranks while of
course the fuel that was there to prime it is now gone, so you restart
the process but this time you use even less prime because you think you
have primed plenty the first time. Which makes the issue worse. Also
make sure you have 1/4 throttle, any less and it may be have enough to
get it going. As far as when to advance the mixture.... As soon as it
first starts to catch, advance it in all the way, rather quickly but
smoothly.
One thing you DO NOT want to do (I learned this the easy way, by
watching my instructor do this) is pump the throttle open and close to
force prime it. We (rather he) tried this method and we started
smelling fuel, we got out and saw a puddle of fuel near the front
wheel. We waited 5 mins and it finally started.
Old September 5th 05, 10:09 PM
Withheld By Request
Having three hands helps a bit.
WBR
"navghtivs" wrote in message
fire? Anthing else?
Thanks
Old September 6th 05, 02:58 AM
cjcampbell
fire? Anthing else?
Thanks
I prime it per the manual, then start it with the throttle closed. If
it does not start immediately, I crack the throttle ever so slightly,
leave the fuel pump on, and start it. If the engine tries to die after
starting, I leave the fuel pump on until it warms up. Pretty much all
of this can be found in the manual.
Most people who have trouble starting C172s have tried to learn to
start the airplane by using the checklist without first gaining a
thorough understanding of what the manual says. There are way too many
instructors who fall into that category.
Old September 6th 05, 04:26 AM
OP
On 5 Sep 2005 08:40:45 -0700, "navghtivs"
fire? Anthing else?
Thanks
I rent from a Cessna dealer FBO at VNY. The procedure there is:
Throttle - open 1/4 inch
Mixture - Idle Cutoff
Propeller area - Clear
Master Switch - ON
Beacon - ON
Aux Fuel Pump - ON
Mixture - Advance full - 2 to 3 seconds, then return to Idle Cutoff
Aux Fuel Pump - OFF
Ignition - START
Mixture - Advance full, when engine fires
Works every time for me.
BTW... same procedure when the engine is hot - EXCEPT - Mixture -
advance full - 1 second, then return to Idle Cutoff.
Ron Kelley
Old September 6th 05, 05:21 AM
Mortimer Schnerd, RN
Master Switch - ON
Beacon - ON
Aux Fuel Pump - ON
Aux Fuel Pump - OFF
Ignition - START
I take it from the procedure the new 172s are fuel injected?
VE
Old September 7th 05, 04:33 AM
OP
On Tue, 06 Sep 2005 09:14:49 +0200, Greg Farris
says...
Master Switch - ON
Beacon - ON
Aux Fuel Pump - ON
Aux Fuel Pump - OFF
Ignition - START
Pretty close to the standard method - but why use a "timed" method to
determine fuel flow from the pump, when there is an instrument in front
of you that gives precise information? If you didn't have a fuel flow
guage, or suspected that it wasn't working, this would be a good backup
method - but on the ones I've flown this guage is always working, and
gives a reliable indication for the starting procedure.
G Faris
The reason given by the FBO was that the fuel flow meter in "some"
of the injected 172's is either slow to respond or doesn't read
accurately at the aux fuel pump flow rate. And it is easier to
flood the engine using the fuel flow meter. Don't know how true
that is, but the timed method (using a simple one thousand, two
thousand count) is accurate enough.
I guess if you are flying your own plane or the same one every time,
using the fuel flow meter would be more convenient once you knew
what the fuel flow meter should read to properly start your engine.
The only place I see a problem would be starting a hot engine.
Apparently you don't want as much fuel in there under that
condition. Maybe that would be a lower fuel flow rate.
Ron Kelley
Starting Prop Engines in FS2002 [email protected] Simulators 3 August 30th 04 02:54 PM
Starting Engine Question (O-320, Warrior) Lisa Piloting 13 April 1st 04 06:45 AM
New A&P: Typical Starting Salary Range ? Robert11 General Aviation 1 February 6th 04 09:02 PM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
Boeing 307 Starting Up! Jay Honeck Piloting 5 August 8th 03 06:53 PM
