I believe you can now download obstacles on the 196
But not terrain - see the obstacle, change heading, hit the mountain ![]() Plus, when I enquired about how many obstacles it showed in Canada, the response was . . . . . . some. Now that has to be worth buying. Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
Tony,
But not terrain - see the obstacle, change heading, hit the mountain You're telling us you would rely on a handheld, non-certified, non-WAAS VFR-GPS with a systematic altitude error of at least a couple hundred feet to avoid terrain? Terrain on a (handheld) GPS looks really cool and makes it easier to correlate the moving map picture and reality outside the window, but IMHO you just can't use it to avoid terrain by only a few hundred feet as necessary during scud running. For all other situations, I don't really see what it is needed for: VFR you just look outside at the terrain, IFR you should be high enough to not hit the terrain anyway - and the map without terrain should give you enough situational awareness to avoid being where you shouldn't be. That said, terrain is nice to have and adds to SA - but not critical. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote: Terrain on a (handheld) GPS looks really cool and makes it easier to correlate the moving map picture and reality outside the window, but IMHO you just can't use it to avoid terrain by only a few hundred feet as necessary during scud running. For all other situations, I don't really see what it is needed for: VFR you just look outside at the terrain, IFR you should be high enough to not hit the terrain anyway - and the map without terrain should give you enough situational awareness to avoid being where you shouldn't be. That said, terrain is nice to have and adds to SA - but not critical. IFR during the approach to an airport with surrounding terrain seems like a pretty good use of terrain avoidance. VFR during the approach to an airport in the summer when the visibility may be reduced in haze seems like a pretty good use of terrain avoidance. This nonsense that I've been reading here and on other message boards suggesting that a situational awareness tool is useless or almost useless because it isn't "certified" is sheer lunacy, in my opinion. I think it was the AOPA boards where some folks said they would trust an ADF over a portable GPS because the ADF was "certified." No, you shouldn't rely on it to scud run, and you shouldn't be doing approaches with a non-certified GPS, but it is tremendously useful for situational awareness--which includes awareness of obstacles and surrounding terrain. JKG |
Cub Driver wrote:
I fly low, so the terrain avoidance is indeed useful (radio towers on hills). The moving map is the screen I most often use. It's brilliant. Dan, you are flying a Cub! How much time do you need to miss something sticking up in front of you? :-)) |
Mike,
look at the Lowrance Airmap 1000, too. -- Thomas Borchert (EDDH) |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
