Tools
Old September 7th 05, 04:47 AM
ORVAL FAIRAIRN
Default Tools
I got this one from a friend. How true!
Thought you might enjoy these. They are RIGHT on the mark!
a.* DRILL PRESS: A tall upright machine useful for suddenly snatching
flat metal bar stock out of your hands so that it smacks you in the
chest and flings your beer across the room, splattering it against
that
freshly painted part you were drying.
b.* WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light.* Also removes fingerprint
whorls and hard-earned guitar calluses in about the time it takes you
to
say, "Ouch...."
c.* ELECTRIC HAND DRILL: Normally used for spinning pop rivets in
their
holes until you die of old age
d.* PLIERS: Used to round off bolt heads.
e.* HACKSAW: One of a family of cutting tools built on the Ouija board
principle.* It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
f.* VISE-GRIPS: Used to round off bolt heads.* If nothing else is
available, they can also be used to transfer intense welding heat to
palm of your hand.
g.* OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire.
Also handy for igniting the grease inside a wheel hub you're trying to
get the bearing race out of.
h.* WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2
socket you've been searching for the last 15 minutes.
i.* HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
ground
after you have installed your new disk brake pads, trapping the jack
handle firmly under the bumper.
j.* EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile
upward off a hydraulic jack handle.
k.* TWEEZERS: A tool for removing wood splinters.
l.* PHONE: Tool for calling your neighbor to see if he has another
hydraulic floor jack.
m.* SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool
for
spreading mayonnaise; used mainly for getting dog-do off your boot.
n.* E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt
holes
and is ten times harder than any known drill bit.
o.* TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the
tensile
strength of bolts and fuel lines you may have forgotten to
disconnect.
p.CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool
that inexplicably has an accurately machined screwdriver tip on the
end
without the handle.
q.AVIATION METAL SNIPS: See hacksaw.
r.* TROUBLE LIGHT: The home builder's own tanning booth.
Sometimes called drop light, it is a good source of vitamin D, "the
sunshine vitamin," which is not otherwise found under cars at
night.* Health benefits aside, it's main purpose is to consume 40-watt
light bulbs at about the same rate that 105-mm howitzer shells might
be
used during, say, the first few hours of the Battle of the Bulge.
More often dark than light, its name is somewhat misleading.
s.PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used,
as the name implies, to round off Phillips screw heads.
t.AIR COMPRESSOR: A machine that takes energy produced in a
coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts last tightened 70 years ago by someone at Ford, and rounds
them off.
u.PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
v.HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
w.HAMMER: Originally employed as a weapon of war, the hammer nowadays
is
used as a kind of divining rod to locate expensive parts not far from
the object we are trying to hit.
x.MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly
well
on boxes containing seats, chrome and plastic parts.
Old September 7th 05, 05:57 AM
Morgans
"ORVAL FAIRAIRN" wrote
h. WHITWORTH SOCKETS: Once used for working on older British cars and
1/2
I am not familiar with the Whitworth socket. What is the significance, as
used here?
Old September 7th 05, 05:13 AM
Mike Rapoport
It is a different size standard. There is SAE, Metric and Whitworth.
MU-2
"Morgans" wrote in message
1/2
used here?
Old September 7th 05, 07:45 AM
Morgans
ink.net...
MU-2
*That* is one little fact that I could have gone my whole life without
knowing. g On the otherhand.... Another whole set of tools to buy! :-)
or :-( Hummm.
What is the basis of the sizes? (if you know what I mean)
What kind of beasts are (or were) they used on?
Old September 7th 05, 07:13 AM
Bart D. Hull
They were used on English cars and motorcycles.
The "size" of the wrench was based on the diameter of the
stud size that the nut fit. (Typical bass-awkwards English
idea.) A 1/4" Whitworth was about 9/16" or a little larger
in true OD measurement of the flats on the nut. They had
fine and coarse thread as well.
Biggest PITA was BSA motorcycle cylinder nuts. They were
8pt 1/4 or 3/8 Whitworth. You had to have the correct wrench
or they rounded like butter. Most Whitworth wrenches I saw
were only open jaw, not box ends, but maybe that's all that
made it to the U.S.
I'm not a old fart either. My parents owned a British,
Italian, German motorcycle shop. (We worked on ANYTHING!)
Lots of "what the heck is this", but it was interesting.
Scariest part was when MG's had American, Metric and
Whitworth. Nothing sucks more than trying to figure out what
wrench to use on what parts when your fiddleing in the dark
(remember they used Lucas electics!!!) I'd love to punch the
engineer that said "but my part of the car is (fill in the
blank with Metric, SAE, or Whitworth.)
Then to top it off, depending on what year the MG was, it
was positive or negative ground. Look at the alt wiring
BEFORE you connect those cables.
Just give me a standard and STICK WITH IT!
Rant off
Bart D. Hull
Tempe, Arizona
Check
http://www.inficad.com/~bdhull/engine.html
for my Subaru Engine Conversion
Check http://www.inficad.com/~bdhull/fuselage.html
for Tango II I'm building.
Remove -nospam to reply via email.
ink.net...
MU-2
or :-( Hummm.
Old September 7th 05, 03:51 PM
jerry wass
The "size" of the wrench was based on the diameter of the stud size that
the nut fit. (Typical bass-awkwards English idea.) A 1/4" Whitworth was
8pt 1/4 or 3/8 Whitworth. You had to have the correct wrench or they
rounded like butter. Most Whitworth wrenches I saw were only open jaw,
not box ends, but maybe that's all that made it to the U.S.
I'm not a old fart either. My parents owned a British, Italian, German
Scariest part was when MG's had American, Metric and Whitworth. Nothing
sucks more than trying to figure out what wrench to use on what parts
when your fiddleing in the dark (remember they used Lucas electics!!!)
I'd love to punch the engineer that said "but my part of the car is
(fill in the blank with Metric, SAE, or Whitworth.)
Then to top it off, depending on what year the MG was, it was positive
or negative ground. Look at the alt wiring BEFORE you connect those cables.
Rant off
Bart D. Hull
Tempe, Arizona
Check
ink.net...
MU-2
or :-( Hummm.
Rite purty set-up---why'd the leave one groove out of the 10 groove
V-belt pulley----Alignment??Jerry
Old September 8th 05, 01:40 AM
Montblack
("Bart D. Hull" wrote)
[snip]
Then to top it off, depending on what year the MG was, it was positive or
I snapped off two lug bolts on my brother's 63? Dodge pickup trying to
change a flat. Reverse thread on one side. Doh!
Montblack
Old September 11th 05, 04:56 PM
Don Hammer
This is an airplane forum. Don't forget them.
All the Hawker Siddley/BAE/Raytheon Hawkers come with a British
Standard Whitworth tool kit. All the hydraulic fittings are BS and
the rest of the hardware is SAE.
Old September 12th 05, 08:03 PM
ISTR there are different metric standards. The most common being DIN,
but didn't British have their own metric thread standards for a while?
FF
Old September 7th 05, 12:55 PM
Blue
Bloody Brilliant, cried with laughter....
Regards
Blue
"ORVAL FAIRAIRN" wrote in message
news
a. DRILL PRESS: A tall upright machine useful for suddenly snatching
that
b. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
to
say, "Ouch...."
c. ELECTRIC HAND DRILL: Normally used for spinning pop rivets in
their
d. PLIERS: Used to round off bolt heads.
e. HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
f. VISE-GRIPS: Used to round off bolt heads. If nothing else is
palm of your hand.
g. OXYACETYLENE TORCH: Used almost entirely for lighting various
1/2
i. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
ground
j. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile
k. TWEEZERS: A tool for removing wood splinters.
l. PHONE: Tool for calling your neighbor to see if he has another
m. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool
for
n. E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt
holes
o. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the
tensile
disconnect.
end
without the handle.
r. TROUBLE LIGHT: The home builder's own tanning booth.
night. Health benefits aside, it's main purpose is to consume 40-watt
be
coal-burning
them off.
is
well
Camloc Installation Tools jls Home Built 13 May 7th 04 05:11 AM
EAA Chapte Tools [email protected] Home Built 7 March 8th 04 10:51 PM
What tools do you take? Michael Horowitz Owning 31 March 8th 04 02:53 AM
FS: MORE of my aviation parts, tools, instruments on ebay Bill Berle Owning 0 January 14th 04 09:40 AM
Why do you buy Snap-on tools? Anonymo421 Home Built 12 November 9th 03 09:40 AM
