#21
One way of putting this into practical effect is, assuming the glider
gets out of position to one side: 1. Level the wings and hold your current position. 2. Start to move the glider back behind the tug in the lateral dimension only (e.g. if you're out to the left, start to move right, but if you're also low don't try to climb at the same time). 3. Immediately it starts to move, bring the wings level again. 4. Repeat 2 and 3 until you're behind the tug. This worked for me when I was learning. Initially the glider moves a long way each time, but you soon learn to anticipate and stop the movement quicker. Once you can do this, you can start moving the glider back into position in just two goes - one large movement and a final correcting movement - and eventually in one go. The same technique can work for height displacement. Tom wrote: In control system jargon we would say that you have more than unity gain at 180 degrees of phase shift. What that means in English is that by the time you recognize you need to make a correction your corrective action is too much. So you make another corrective action to fix the problem the first action, using even more control input. This results in an even larger deviation in the opposite direction. And so it goes... Add to this that you have three control surfaces that you are manipulating (you may feel like they are manipulating you!). The phase shift part means you are late in recognizing you need to make an adjustment. Try making more timely (reduce the phase shift), but smaller adjustments (reduce the gain). Remember, once you get a large mass in motion (such as a turn to bring the glider back to center line) it can't stop immediately, so you have to anticipate stopping it with control action in the opposite direction. Start out by towing in the morning before thermal activity starts - it is much easier to maintain position in calm air. Don't worry: with practice you will get comfortable with towing. Good luck! Tom Seim |
This is a good example of "turning down the gain". When we tune control
systems we generally don't crank the gain up to the max and then reduce it until the system becomes stable. We do the opposite: start with low (zero) gain and gradually increase it until the system becomes unstable. Part of the confusion is that there are times when large control movements are required (rolling into a steep bank turn) and times when they aren't (flying straight and level). The student needs to be clearly told, and told again and again, when each is appropriate. |
Newbie Question, really: That first flight | Cecil Chapman | Home Built | 25 | September 20th 04 05:52 AM |
A question only a newbie would ask | Peter Duniho | Piloting | 68 | August 18th 04 11:54 PM |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Newbie Question - Vacuum vs Electric | Bill Denton | Aerobatics | 1 | April 15th 04 11:30 PM |
Newbie question Cessna or Beechcraft? | rbboydston | Piloting | 4 | August 13th 03 01:08 PM |
