![]() Ron Wanttaja wrote: On Mon, 03 Jan 2005 19:10:45 -0600, Rick Pellicciotti wrote: I have experience with RANS and Kitfox aircraft. I have personally built 5 RANS kitplanes and I have known Randy Schlitter since 1988. The airplanes are top notch, customer support and service are second to none. RANS has a production certificate in hand and can build S-7 Couriers today. To my knowledge, this is the only LSA legal, new airplane that is certified right now. If I may make a slight clarification, Rick: The S-7 meets the FAR Part 1 Light Sport Aircraft definition, and thus can be legally flown by Sport Pilots. But as far as I know, it is certified in the Standard airworthiness category (probably Normal or Primary), *not* as a Special Light Sport aircraft. The S-7 must be annualed by an A&P with an Inspection Authorization, and cannot be inspected or have major maintenance performed by a person with a Light Sport Maintenance Repairman Certificate. Nor can it be transitioned into the Experimental Light Sport Aircraft category to allow all maintenance by the owner and inspections by those with an LS-I Repairman Certificate. I'm betting RANS can have one of the first planes certified as SLSA, if they wish. But existing Standard category S-7s won't be able to transition. However, like you said, they *are* LSA legal...from the point of view of those who wish to fly as Sport Pilots. Ron Wanttaja Yes, Ron. The S-7 is certified and RANS has a production certificate for it in the Primary category. I agree with you that they could be one of the first US manufacturers to build SLSA aircraft but the last conversation I had with Randy, he indicated that he was going to go the experimental route for now. I wish I had the command of the written word that you have. I could have explained it better. You did a great job. Rick |
On Wed, 05 Jan 2005 01:58:23 GMT, Ron Wanttaja wrote:
I hope your interpretation is right because ELSA kits were too restricted for the life of the plane in the early discussions. I have a sneaking suspicion my interpretation is wrong, just because it *would* allow a lot more flexibility that I believe the FAA and EAA intended. I've been given a good contact at the FAA, I'll try get a clarification. I've had a good exchange with one of the inspectors in the Light Sport branch at the FAA. 1. Owners of an Experimental Light Sport Aircraft (ELSA) must strictly conform to the manufacturer's assembly instruction during construction. 2. Once the aircraft is completed, the owner is free to change and modify the airplane as he desires without permission or guidance from the original kit manufacturer. Just like Experimental Amateur-Built, though, if a major change is made, the aircraft will have to go back to the Phase 1 testing. 3. Persons owning an aircraft with a Special Light Sport Aircraft (SLSA) certificate (e.g., production LSAs) may receive a new airworthiness certificate in the Experimental category upon application (e.g., no prerequisites). 4. When the new airworthiness certificate is granted, the owner must surrender the Special LSA certificate (which I interpret as meaning there's no going back). 5. Once the new certificate is awarded, the owner is free to change and modify the former SLSA as desired without permission or guidance from the original aircraft manufacturer. Major changes will require the aircraft perform Phase 1 testing. I did not ask specifically in regard to former two-seat ultralight aircraft, but given #2 and #5 above, I can't believe it'd be any different. Keep in mind, though, that this is new ground for the local FSDOs. It's likely there may need to be some policy documents generated at the national level to ensure a consistent interpretation. What struck me during the exchange is how similar the SLSA to ELSA transition is to the "owner maintenance" category in Canada. The owner of a production-type aircraft will be able to have a lot more freedom as far as changes to his bird. Ron Wanttaja |
Ron Wanttaja wrote in
: On Mon, 03 Jan 2005 23:24:21 GMT, Ron Wanttaja wrote: It is subject to the same maintaince etc requirements as SLSA but can not be used for instruction or rental. Sleepy is correct. Whoops, noticed something else. I believe ELSAs *can* be used for instruction and rental, through 2010. That's what's covering the two-seat ultralight trainers that must convert to ELSA. Ron Wanttaja ONLY the "converted" (grandfathered) 2 seat ultralight ELSA's can be used for instruction until 2010, you CANNOT by a new ELSA tomorrow and use it for instruction. ET |
On Fri, 07 Jan 2005 05:40:25 GMT, ET wrote:
Ron Wanttaja wrote in : Whoops, noticed something else. I believe ELSAs *can* be used for instruction and rental, through 2010. That's what's covering the two-seat ultralight trainers that must convert to ELSA. Ron Wanttaja ONLY the "converted" (grandfathered) 2 seat ultralight ELSA's can be used for instruction until 2010, you CANNOT by a new ELSA tomorrow and use it for instruction. Yes, on closer inspection, 14CFR 91.319 does limit the commercial use to the converted 2-seat trainers. The "Light-Sport Aircraft Maintenance and Certification Requirements" table near the beginning of the FAA release is a bit deceptive.... Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... On Mon, 3 Jan 2005 11:26:29 -0600, "Gig Giacona" wrote: "Willard" wrote in message oups.com... I am planning to buy a factory-built LSA within a few months. All the aircraft I am considering will be built by companies with a history of selling kits - e.g., Rans, Kolb, Kitfox, etc. Any homebuilders out there have any opinions about any of these companies and their products? Are any of those aircraft built under the "consensus standards"? Are the consensus standards even finalized yet? The consensus standards have been released, you can order them from www.astm.org (Stock number: Aircraft04). It's an 80-page document, used in lieu of a few hundred pages of conventional FAR. Interesting read. The maintenance standard is still under discussion, but it will probably be out soon. The FAA is having its first course for DAR-LSAs this month, but I believe a standard DAR (or, of course, the local FSDO) can do the safety sign-off for a production LSA. Ron Wanttaja Ordinary DAR can NOT do the LSA inspection/certification until he is qualified by taking the FAA LSA workshop. -- Cy Galley EAA Safety Programs Editor Always looking for ideas and articles for EAA Sport Pilot |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
