Why no new diesel radials?
Old September 12th 05, 07:03 PM
EAA TC 1441
The "Lycoming-Detroit" opposed motor is actaually the Italian V-M of
V-M Motori, a onetime company owned by AlfaRomeo. This is the 2nd time
that americans have attempted to market this line in the US. It is
modular and very economical. Back in the 70's the attempt to
distribute failed due to lack of experience and a serious investment in
the future. When FIAT "bought" AlfaRomeo, they did not want the sister
companies of Alfa, so they were sold off, along with AlfaAvio. V-M
automotive motors are very successful due to their low noise levels and
extremely low untreated exhaust emissions.
Further to the radial comments, Dont forget that the Packard radial
Diesel was built in Detroit and was not popular with airframe designers.
Old September 16th 05, 02:47 AM
On-Condition
Thanks for the details; it's most interesting. I had presumed that
a brand new engine was in the oven.
Yeah, there's that one thing that turns designers right off: weight.
Old September 19th 05, 10:22 PM
On-Condition wrote:
Just wondering, exactly why are radial diesels not part of the
diesel revival? You can't beat radials on airplanes for smooth
reliability. I once saw a cracked-off jug pounding through the
cowling as the engine was still running (the single Otter had
just landed).
Guiberson: 4 stroke 9 cylinder radial, 2 valves per cylinder, 300HP.
Packard: 4 stroke 9 cylinder 1 valve per cylinder (Neato) 225HP.
Zoche is a ported 2 stroke, if I recall it was supposed to be available
in 2 4 and 8 cylinders.
There is an V4 in development in the US, a piston-opposed 2 cyclinder 2
stroke 100HP engine in the UK that is apparently shipping, and 150HP
engine (I think in france?) that is also shipping and I believe is
either certified or approaching certification in the 172. (Anybody know
whether the ICAO agreements make that a certifiable install in the
USA?)
One thing I always wondered about the old radial diesels was how prone
these engines were to hydraulic lock? I mean you can take a plug out of
a gas radial and drain oil, but at the lower compression ratio you
should just have to walk a couple blades through once in a while to
prevent it. At 15 to 1 compression ratio, I would think diesel radials
would be much more susceptable to overpressuring the jugs. Looking at
the zoche engine this seems doubly odd, since there are no valves to
let excess engine oil out of the lower cylinders. Anybody know how they
deal with this?
I've read quite a bit of conflicting information about diesel radials.
One account said that the packard had good high altitude performance
because the nature of a diesel is to always have a lean air/fuel ratio,
so it it would richen the mixture into a better ratio as it climbed.
I've read in usenet other accounts that said that the high altitude
performance sucked. Guess we'll just have to take one out and fly it to
see :-)
The packard was 1 valve per jug, (reasonable since it is just air, not
fuel) ran on stove oil. The arrangement has a donut flange on the top
of the cylinders and uses ram air to clear the exhaust gasses. The side
effect though is that your exhaust is not funneled, so the pilot and
pax of a single engine bird end up sucking diesel exhaust. Obviously
hanging the engines under the wings fixes that, but in the thirties
that was easier said than done.
Then you have fuel considerations. Stove oil and summer diesel can gel
at altitude, requiring some fairly complex added equipment to correct
the problem, which I am guessing is why all the new ones are designed
to run on Jet-A. Somebody else mentioned a priming issue as well in a
previous thread. In essence, if you stop the engine from fuel
starvation, the fuel injectors suck air out of the cylinders instead of
sucking fuel out of the fuel line, so you can't restart. (Am I
understanding that problem correctly?) old diesels have hand priming
pumps to fix this. Look under the hood of Mercedes 240D for example, it
looks like a little accordion on the drivers side of the engine. I
believe common rail injection solves this problem though.
So the system infrustructure for using a diesel is a bit more complex
even though you don't need magnetos. Complex = weight. Though in
general I expect if it had ever become a reasonably standard practice
the kinks would have been worked out a long time ago. Actually it
probably would have been become more practical as the number of jugs
grew because of the increase in mechanical efficiency native to the
radial configuration. (Can you imagine an 18 cylinder diesel WASP sized
engine?) But now there are turbines for that kind of power, so theres
no reason to do it.
Weight is an issue with smaller engines yes. The packard made 2/3's of
the rated power of a comparable gas engine of the era at the same
weight. (And that is an educated guess, I don't feel like looking it
up, but it is probably generous.) Higher pressure in the jugs requires
more steel to be reasonably reliable. No way to get around that. Like
all things diesel, you have to accept some derated performance if you
want the benefits.
I read an article about a PT6A that was tested with B100 mixed into the
fuel. If I remember they noted no significant change in performance up
to about 20% blend or so. Though I have to wonder, since the PT6A is
sometimes configured to derate its max power whether this was accurate.
(Am I correct there? Isn't the one in the Caravan derated to 600HP from
1000?)Also the test was relatively short compared to the actual
lifespan of turbine so the results though positive, were not conclusive
in my humble interpretation of the report. But it was a while ago that
I read that.
So that about sizes up my understanding of the current situation
What I'd like to see someone work out a new turbine design with an
injector and hot section suitable for running on SVO or B100. Stick
that on a couple of 747's, diesel trains, and cruise liners and you
save thousands of tons of net-CO2 emissions a year.
Anybody is welcomed to jump in and correct me where I'm wrong. I'm sure
some of this in misinformation. This is usenet after all.
-Matt
Old September 20th 05, 03:21 AM
Cy Galley
Why would one ruin a good virgin for oil?
"dje" wrote in message
I think:
SVO = Straight Virgin Oil
B100 = 100% biodeisel
David
Mind explaining what SVO and B100 are?
David Johnson
Old September 20th 05, 05:01 AM
Dan, U.S. Air Force, retired
Because they outlawed sacrificing virgins for oil.
An elderly woman died a virgin, her tombstone reads "returned unopened."
Old September 21st 05, 03:11 PM
I'd be interested in reading anything on the practice of using diesel
and biodiesel in turbines your refering too. Did you read this
somewhere, or is that from experience? Have you actually heard of
Biodiesel being used in jets? Or is your reference to biodiesel gelling
related to cars?
Regarding Hydraulic lock I was thinking more preventatively. Like going
to the hanger once a week and walking through a few blades regardless
of whether you were actually going flying. Though I would figure at
15/1 it would require much less oil to frag the engine than at 7.5/1.
I'm probably overthinking the problem. Anybody know how the Guiberson
was mounted in the Stuart tank? Was it on it's back or was it mounted
upright like it would be in an airplane?
Shoot. Somebody ought to just take one out and strap it to Beech 18 and
go flying. Then give us all a pilot report to tell us what the the deal
really is. :-)
-Matt
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
2-stroke diesel is the (near) future? Max Kallio Rotorcraft 123 July 18th 05 12:39 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Home Built 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M General Aviation 1 January 4th 04 04:04 AM
Diesel Jodel information..........and .........diesel plane groups Roland M Owning 1 January 4th 04 04:04 AM
