#21
Putting the plugs back in required using my other new tool -- a gigantic
Craftsman torque wrench. I had my A&P set the torque properly the first time, just to make sure I wasn't mis-reading the danged thing and twisting something off inside the engine. If I read this correctly, you got the torque wrench that "breaks" at the torque set on the handle. When you finished, did you "properly" store the torque wrench? (Just a test to see if you read the instructions that came with the tool.) |
(Just a test to see if you read the instructions that came with the tool.) Um, well, I very carefully put it back in the cheap plastic case it came in, and wrapped the directions around the handle. Was there more to it? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article NwoZe.161520$084.66032@attbi_s22,
"Jay Honeck" wrote: When you finished, did you "properly" store the torque wrench? (Just a test to see if you read the instructions that came with the tool.) Um, well, I very carefully put it back in the cheap plastic case it came in, and wrapped the directions around the handle. Was there more to it? unlock it, and unload the setting (e.g., set the torque setting to the low end of the scale). -- Bob Noel no one likes an educated mule |
Jay Honeck wrote:
Um, well, I very carefully put it back in the cheap plastic case it came in, and wrapped the directions around the handle. Was there more to it? Jay, He's trying to dazzle you with the brilliance that he knows to set the torque wrench back to "zero" when you put it away. This relieves tension on the internal spring, thus not wearing it out. (hope you did this) Happy Flying! Scott Skylane |
"Jay Honeck" wrote: When you finished, did you "properly" store the torque wrench? (Just a test to see if you read the instructions that came with the tool.) Um, well, I very carefully put it back in the cheap plastic case it came in, and wrapped the directions around the handle. Was there more to it? Yup. You are supposed to reset the torque setting to zero when you put the wrench away. Otherwise, the torque wrench can acquire a set and lose calibration -- usually it will click early, or a a lower than designated torque. |
Jay Honeck wrote:
Our best guess at this point is that it's something inside the right rear door -- but I haven't had time to rip it apart to see. A friend of mine worked on the warrantee line of a Datsun dealer back in the late 70s. One day he got in a car with the same complaint you have. Opened up the door and found an unopened can of soda with Japanese lettering. Near as he could figure, the factory had a rule against food on the assembly line, and some manager happened by just as one of the workers was about to open the can, so he stuffed it in the door and put the panel on. Al said it didn't taste very good to him. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Margy wrote:
I always find my mechanic is pleased when after using her tools I sweep the hangar, go buy lunch, bring the sodas, etc. And I just find that my mechanic gets ****ed when I use his tools. :-) George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
torque wrench back to "zero" when you put it away. This relieves tension on the internal spring, thus not wearing it out. (hope you did this) Well, nope, I sure didn't. But I'll do it tomorrow when I'm at the hangar... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#29
Jay Honeck wrote:
But I'll do it tomorrow when I'm at the hangar... Too late, you've ruined it! (just kidding) :-) George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
#30
Jay Honeck wrote:
Why, because I *knew* it would **** you off, Jay! ROTFL... Well, that and you're one of those guys that thinks we have a limited supply of lines Jay. Dontcha know, it's like oil...there is a finite amount of lines to be written Jay...don't waste them man...the rest of us have lines to write...come on man, play fair...please? :-) -- Jack Allison PP-ASEL-IA Student Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
| Thread Tools | |
| Display Modes | |
| Need Champion C26 Spark Plugs (era circa WW-II). | J. Graham | Owning | 1 | July 30th 05 06:57 PM |
| Spark Plugs: Champion vs. Unison | Jonathan Goodish | Owning | 7 | May 7th 05 12:19 AM |
| Unison spark plugs | Ed Sullivan | Home Built | 3 | April 21st 05 03:10 PM |
| Color of spark plugs | john smith | Owning | 5 | March 2nd 04 04:08 AM |
| Spark plugs for ASH26E | Ludovic Launer | Soaring | 4 | February 3rd 04 08:56 PM |
