I'm Going In... Radio Saga Continued...
Old October 10th 05, 08:38 PM
TaxSrv
"three-eight-hotel" wrote:
I'm going to hold off on putting the
trays back in and borrow the tools from my mechanic to do
it right, rather than figure out how I'm going to hold nuts on
the back of trays for each screw.
You mean to borrow his trained mouse, or his JB Weld to epoxy the
nut in place? Sight unseen, that's what I'd do if workable. What
are the screws affixing, the tray or the connector?
Fred F.
Old October 10th 05, 08:57 PM
George Patterson
nut in place?
I'd put in rivnuts (as Jim suggested). There's entirely too much danger of
epoxying the bolt into the nut.
If you do go the epoxy route, buy a bunch of nylon bolts and use those to hold
the nuts in place while the epoxy cures. If any of the bolts gets glued in, they
can be removed with a drill and tap pretty easily.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 10th 05, 09:18 PM
three-eight-hotel
Thanks Ross,
With all of the symptoms I have been having and troubleshooting reports
I have provided, I'm surprised anyone can follow these posts, because
I'm having a hard enough time myself! ;-)
In a previous post, I reported that I had swapped out my radio with a
known working TKM replacement radio, and encountered a failure with
that radio as well. I also let my instructor throw my radio in another
plane, for a lesson she was giving, and she reported back that my radio
worked the whole time. I also took the radio in to a Narco dealer and
they ran it up on the bench for several hours and said that everything
was within specifications. This, however, after they made a
questionable repair only weeks earlier!
Based on the TKM's failing in my plane, and my radio working in another
plane, it seems unlikely that it is in the radio, but not impossible.
I could easily be experiencing one set of coincidences after another!
"The side tone is a product of the radio not the audio panel",
perplexes me though... Reception loss and sidetone loss at the same
time is the current prevolent symptom. At the occurence of failure, I
have reception loss and sidetone loss, I do have sidetone going
through the intercom though, as I can communicate with the passengers
fine. It is only on xmit where I lose sidetone... Plugging into the
aircraft jacks directly doesn't help because if I understand correctly,
you wouldn't get sidetone there anyways. Sidetone in that respect is a
product of the intercom, is it not? So... there are three components
(radio, intercom, audio panel) that are all interconnected somehow, and
that's where my eye's glaze over and I start to drool... I just don't
get it???
Are there any recommended readings out there, that anyone could
recommend to at least bring my up to a third grade level on this stuff?
A search for "avionics for dummies", came up goose eggs!
Thanks again for your responses!
Todd
Old October 10th 05, 09:28 PM
three-eight-hotel
That's what I'm hoping for... I'll have to see what he has available
and make due with what I can.
To answer Fred's question, the screws are affixing the trays... I'd
use his mouse, but the poor thing was helping hand prop an old Piper
Cub, a couple of months ago, and wasn't following proper procedures...
If you've ever seen a rodent penetrate a sheet metal hanger door, you
wouldn't be surprised if I told you it was quite a mess!
Thanks and Best Regards,
Todd
Old October 10th 05, 09:40 PM
Tauno Voipio
three-eight-hotel wrote:
Thanks Ross,
get it???
The intercom and sidetone go different ways:
- the intercom connects the amplified mic signal directly to the
all the headphones,
- the sidetone is created inside the COM radio by receiving
the transmitted signal with a simple detector and feeding
the signal to the headphone line.
If the sidetone is missing, either the audio path is broken or
the radio does not transmit properly. There is a slight possibility
that the sidetone receiving circuit is the culprit, but it's so
simple that the probability is tiny.
Assuming that the radio behaves in another plane, I see the
possible causes:
- the power supply to the radio is flaky,
- the microphone signal path to the radio is flaky,
- the audio output path from the radio is flaky, or
- the antenna connection is broken / shorted.
The simultaneous loss of reception and sidetone kind of
drop the microphone from the cause list above, the others
are still relevant.
HTH
Tauno Voipio (OH-PYM)
tauno voipio (at) iki fi
Old October 10th 05, 10:20 PM
three-eight-hotel
Thanks Tauno!
all the headphones,
So, feeding the signal to the headphone line would automatically send
the signal to all headphones on the intercom unless the intercom was in
Pilot ISO mode, if I understand correctly? I'm assuming this, since
the passengers can typically hear the radio calls I make. When I lose
sidetone (and reception), the passengers can't hear my xmissions
either, indicating, based on your response, that the signal is never
being fed out of the COM radio (or possibly the signal isn't even
getting to the COM radio). Am I catching on?
possible causes:
are still relevant.
If the power supply to the radio was an issue, would that be evident in
the radio itself, such as led's dimming or loss of power? I never seem
to notice a visible issue with power, and if it's relevant, the NAV
side of the radio never seems to fail at all. I always have constant
indication of a tuned in VOR, regardless of issues I am having on the
COM side.
This loss of reception and sidetone is ALWAYS simultaneous, so I'll
skip the microphone issue.
"The audio output path from the radio"... Would this be a coax cable
from the radio to the intercom? I recall seeing a box (2"x4" or so),
separate from the intercom, with coax from the radio to it... I tried
to trace where the coax went from there, but it seemed to be buried
deep inside a nest of other wires, so I gave up on trying to follow it.
If the radio behaves in another plane, I am assuming you are talking
about an audio output path that is not a part of the radio. So...
somewhere between the radio and the intercom then???
"The antenna connection is broken/shorted" - I'm a little confused at
the likelyhood of this, because what I seem to be hearing in this and
previous posts is that the loss of sidetone likely rules out a
connection between the radio and the antenna. Maybe I'm not catching
on? ;-)
Slowly but surely, I think I'm getting it, but I still think one of you
guys could make a lot of money on an Avionics for Dummies book! I'd
buy it! ;-)
Thanks for your feedback!
Todd
Old October 10th 05, 10:27 PM
Ross Richardson wrote:
: went back to the factory. It is fixed and working fine. The side tone is
: a product of the radio not the audio panel. How I isolated it was
The sidetone can usually be set up either way (radio or intercom).
* Cory Papenfuss *
Old October 10th 05, 10:35 PM
: Based on the TKM's failing in my plane, and my radio working in another
: plane, it seems unlikely that it is in the radio, but not impossible.
: I could easily be experiencing one set of coincidences after another!
Sounds like you've pretty much removed the radio from the equation.
: "The side tone is a product of the radio not the audio panel",
: perplexes me though... Reception loss and sidetone loss at the same
: time is the current prevolent symptom. At the occurence of failure, I
: have reception loss and sidetone loss, I do have sidetone going
: through the intercom though, as I can communicate with the passengers
: fine.
"Sidetone" generally refers to hearing what you are transmitting on the radio,
not what you are saying on the intercom. One could argue it's a pedantic difference,
but for what you are troublshooting, the difference is important.
Correction: It's only when you transmit that you should *HAVE* sidetone.
Any other time your "sidetone" is simply the intercom intercom'ing.
Plugging into the
: aircraft jacks directly doesn't help because if I understand correctly,
: you wouldn't get sidetone there anyways. Sidetone in that respect is a
: product of the intercom, is it not?
It could be on the intercom, on the radio, or *both*, depending on how
whomever installed it decided to wire it up.
: (radio, intercom, audio panel) that are all interconnected somehow, and
: that's where my eye's glaze over and I start to drool... I just don't
: get it???
: Are there any recommended readings out there, that anyone could
: recommend to at least bring my up to a third grade level on this stuff?
: A search for "avionics for dummies", came up goose eggs!
Trouble is that there is no "one true way" to install the stuff. There are
generally enough connections included in all of the devices that there are different
ways to accomplish the same thing.
Judging by your statement he
:Reception loss and sidetone loss at the same
: fine.
I'd say you've got a bad connection between the "audio out" of the radio and
the COM[12] on the audio panel, or between the audio panel and the intercom. I would
also speculate that the intercom is not producing sidetone, but the radio is... thus
the loss of sidetone upon transmit, but the intercom remains functional.
I don't specifically remember other details that may contradict this idea, but
I'm sure they'll be pointed out to me by someone...
-Cory
* Cory Papenfuss *
  #29
Old October 10th 05, 10:42 PM
: So, feeding the signal to the headphone line would automatically send
: the signal to all headphones on the intercom unless the intercom was in
: Pilot ISO mode, if I understand correctly? I'm assuming this, since
: the passengers can typically hear the radio calls I make. When I lose
: sidetone (and reception), the passengers can't hear my xmissions
: either, indicating, based on your response, that the signal is never
: being fed out of the COM radio (or possibly the signal isn't even
: getting to the COM radio). Am I catching on?
Ah... you gotta be careful when you talk about intercoms. Sometimes they do
some funky relay switching when the XMIT is hit. What it's probably doing (even when
not in pilot ISO mode) is that it's disabling the intercom circuit. At the same time,
it's routing the pilot MIC to the radio, but routing the sidetone (that is generated
by the RADIO, not the intercom) out to all the pax's headsets. ... or at least that's
what's supposed to be happening.
As if that wasn't complicated enough, a flaky relay inside the intercom could
cause all sorts of spastic and seamingly unrelated failures between XMIT and non-XMIT.
: If the power supply to the radio was an issue, would that be evident in
: the radio itself, such as led's dimming or loss of power? I never seem
: to notice a visible issue with power, and if it's relevant, the NAV
: side of the radio never seems to fail at all. I always have constant
: indication of a tuned in VOR, regardless of issues I am having on the
: COM side.
Not likely given the swap-out... radio is likely blameless.
: "The audio output path from the radio"... Would this be a coax cable
: from the radio to the intercom? I recall seeing a box (2"x4" or so),
: separate from the intercom, with coax from the radio to it... I tried
: to trace where the coax went from there, but it seemed to be buried
: deep inside a nest of other wires, so I gave up on trying to follow it.
: If the radio behaves in another plane, I am assuming you are talking
: about an audio output path that is not a part of the radio. So...
: somewhere between the radio and the intercom then???
The audio output path from the radio is usually a "coax"... actually, a small
shielded aircraft wire... definately NOT an antenna-looking RG-58-type wire.
: "The antenna connection is broken/shorted" - I'm a little confused at
: the likelyhood of this, because what I seem to be hearing in this and
: previous posts is that the loss of sidetone likely rules out a
: connection between the radio and the antenna. Maybe I'm not catching
: on? ;-)
Antenna likely vidicated before.
: Slowly but surely, I think I'm getting it, but I still think one of you
: guys could make a lot of money on an Avionics for Dummies book! I'd
: buy it! ;-)
The bitch of the avionics installs is getting the damn information you need.
With install manuals for everything, it's usually pretty straight-forward. Without
them, you're flying blind most of the time and things get mis-installed.
-Cory
* Cory Papenfuss *
  #30
Old October 10th 05, 10:54 PM
TaxSrv
danger of
That's indeed Murphy's Law, but I'm assuming a 6 or 8-32 screw, not
a bolt. But if you put a little auto wax on the screw, she'll come
out if the goo oozed onto the threads. The screw doesn't have to
be real tight during cure, and a regular nut + toothed lockwasher,
not a self-locking nut, is preferred. After cure and removal of
the screw, install the tray.
Reg,
Fred F.
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 06:39 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 11:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 04:30 AM
