Engine exceeds TBO
Old October 12th 05, 05:53 PM
Cy Galley
TBO is a rather cupreous number. If you were in part 135 you can petition
the FAA for a 10% (IB) extension in the TBO hours if all the parameters are
good. That is how the manufacturers get longer recommended TBOs.
"Scott" wrote in message
I'm not sure what you base your assumption that it will NEED
replacement/rebuilding shortly. My old Chief had 2400 hours on its C-85.
Compressions were well into the upper 70s. I have a friend who flew
Citabrias to 10000 hours between overhauls. The key to that long of a
life was useage. They used them for power line patrol and flew 10-12
hours daily. He believed the key to longevity was usage. Sitting unused
it what kills these engines...TBO is RECOMMENDED, unless it is used in
commercial operations, where it's required.
Scott
Steve Foley wrote:
Yup. It's run out, and will need replacement/rebuilding shortly. Like you
said, anything else is gravy.
Don't you have a T-Craft engine?
"Michael Horowitz" wrote in message
I have a lead on a Tcraft with an A-65 engine that has exceeded
recommended TBO. It is my understanding the compression is still good.
How should I approach this engine ( i.e. just assume everything over
1800 hours was a freebee and there is no guarantee it's not about to
poop out)? - Mike
Old October 14th 05, 03:04 AM
Capt.Doug
"Cy Galley" wrote in message
are
good.
You don't need to petition the FAA. Meet the manufacturer's parameters and
the approval is automatic. I went through this recently.
D.
Old October 12th 05, 02:33 AM
Steve Foley
Sorry Mike, I was obviously wrong. Go ahead and buy this plane. TBO means
nothing.
poop out)? - Mike
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 01:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
