#21
And it is not end of twilight, it is end or beginning of civil twilight.
Is there another kind of twilight? Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Yes, there is nautical twilight and astronomical twilight, and then just
plain old everyday "generic" twilight that we refer to in everyday speech. The former ones and civil twilight have precise definitions based on how far the center of the sun's disc is below the horizon, thus being useful for regulatory purposes. Generic twilight is defined in a usual dictionary but is not precise. "Jose" wrote in message ... And it is not end of twilight, it is end or beginning of civil twilight. Is there another kind of twilight? Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
As Spock would say - "fascinating". What is the reason for all these different twilights? (never mind, if the FAA can have two different definitions of night, I might as well just go google myself. ![]() Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Jose wrote:
different twilights? (never mind, if the FAA can have two different definitions of night, I might as well just go google myself. ![]() three definitions actually if I understood the AOPA article correctly; (seems that the difference between day or night special VFR uses yet another definition -- but then, I might just be confused about it all) :-) --Sylvain |
Jose wrote:
And it is not end of twilight, it is end or beginning of civil twilight. Is there another kind of twilight? I believe that twilight in and of itself is a fairly subjective description. Civil twilight, however, has been more rigorously defined and thus is more precise. I don't recall exactly, but it is something like the time when the center of the disk of the sun is so many degrees (6 sticks in my mind, but is just a recollection) below the horizon with respect to the point of the viewer. There are tables available to give you this time at pretty much at point on the earth. Matt |
Matt Whiting wrote:
Jose wrote: And it is not end of twilight, it is end or beginning of civil twilight. Is there another kind of twilight? I believe that twilight in and of itself is a fairly subjective description. Civil twilight, however, has been more rigorously defined and thus is more precise. I don't recall exactly, but it is something like the time when the center of the disk of the sun is so many degrees (6 sticks in my mind, but is just a recollection) below the horizon with respect to the point of the viewer. There are tables available to give you this time at pretty much at point on the earth. Matt For twilight definitions, see http://aa.usno.navy.mil/faq/docs/RST_defs.html. -- Tauno Voipio tauno voipio (at) iki fi |
Nautical twilight had a practical purpose when we depended on celestial
navigation. That was the period when it was dark enough to see the stars and light enough to discern the horizon. That's the only time you can "shoot" stars unless you use a leveling device. "Jose" wrote in message ... Yes, there is nautical twilight and astronomical twilight As Spock would say - "fascinating". What is the reason for all these different twilights? (never mind, if the FAA can have two different definitions of night, I might as well just go google myself. ![]() Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Well, there is sunset/sunrise, but that does not fall exactly within the
discussion of twilight definitions. The FAA uses three different types of "non-day" for different purposes: after sunset, after civil twilight, and more than one hour after sunset, and the corresponding morning times. "Sylvain" wrote in message t... Jose wrote: different twilights? (never mind, if the FAA can have two different definitions of night, I might as well just go google myself. ![]() three definitions actually if I understood the AOPA article correctly; (seems that the difference between day or night special VFR uses yet another definition -- but then, I might just be confused about it all) :-) --Sylvain |
#29
And, as we have said for a number of years, none of these "non-day" times
have a legal definition within the FAR. Jim "Stan Prevost" wrote in message ... Well, there is sunset/sunrise, but that does not fall exactly within the discussion of twilight definitions. The FAA uses three different types of "non-day" for different purposes: after sunset, after civil twilight, and more than one hour after sunset, and the corresponding morning times. |
#30
have a legal definition within the FAR. Well, I don't know about that. "one hour after sunset" is used thusly in the FARs and and is therefore a kind of "non-day" that is defined in the FARs, though a name isn't given to it. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
question about instrument proficiency check | Sylvain | Instrument Flight Rules | 14 | October 20th 05 09:11 AM |
another annoying commercial wannabe question... | gatt | Piloting | 4 | May 7th 04 12:37 AM |
Self fly hire in the US | Nigel | Piloting | 25 | March 28th 04 09:20 AM |
Question Commercial pilot | BTIZ | Piloting | 7 | February 22nd 04 04:49 AM |
Another Addition to the Rec.Aviation Rogue's Gallery! | Jay Honeck | Home Built | 125 | February 1st 04 05:57 AM |
