Garmin Behind the Curve on WAAS GPS VNAV Approaches
Old July 16th 03, 12:17 PM
Richard Kaplan
Default Garmin Behind the Curve on WAAS GPS VNAV Approaches
"Scott Moore" wrote in message
Speaking only for myself, its pretty damm confusing exactly what would be
done with WAAS even if implemented. Garmins' other units that accept
WAAS is now implemented and IFR approved as of the past week.
If a receiver were approved for WAAS approaches, then TODAY you could use
VNAV/LNAV miniums on GPS RNAV approaches instead of LNAV minimums.
Presumably (though I am not certain) a VNAV/LNAV GPS RNAV approach would be
considered a precision approach. UPSAT's CNX80 web page touts the airports
you have access to today with WAAS; yet the version of the POH supplement
posted on their site says in the legal fineprint that precision approaches
are NOT permitted. So I am not certain if you can or cannot fly VNAV/LNAV
GPS approach mininums TODAY on a CNX-80.
What I would like to see from Garmin is a controlled descent option
on non-precision GPS approaches, which would be perfectly legal to
implement right now (because it is inside the "dive and drive"
If you want to do this as a backup to other navigation, you can do this now
with the VNAV function on the Garmin 430/530, albeit not yet with WAAS.
Nonetheless, there is a big question whether this will make sense for an
approach not explicitly designed as a precision approach. Many
non-precision approaches have a missed approach point from which a suitable
straight-in landing cannot be made; so you could well have a controlled
descent to the middle of the field an then in turn have to circle.
Richard Kaplan, CFII
www.flyimc.com
Old July 16th 03, 01:47 PM
I wouldn't be so certain of that. Today's VNAV minimums are predicated on
IFR-certified Baro VNAV equipment, not WAAS. WAAS approaches have yet to appear
from the FAA
Old July 16th 03, 02:57 PM
Mike Rapoport
So does the CNX-80 meet the requirement today? Is it "WAAS equipment
approved for precision approach"?
MU-2
"Lockheed employee" Mississippi@ home.com wrote in message
I have a Jeppesen briefing bulletin (DEN 00-A) that states:
LNAV/VNAV must have WAAS equipment approved for precision approach, or
RNP-0.3 system based on GPS or DME/DME, with an IFR approach approved
Baro-VNAV system. It appears that either is suitable for going to
VNAV minimums
would be
use
would be
airports
supplement
approaches
VNAV/LNAV
on
appear
from the FAA
Old July 16th 03, 03:05 PM
Tarver Engineering
Why are you asking a sock a technical question, Mike?
Uspat spent their own money to develop the idea of merging pressure altitude
and a subset of the TAWS database and for that they deserve the market. At
least until the other manufacturers catch up.
Old July 17th 03, 01:14 AM
Richard Kaplan
wrote in message ...
appear
from the FAA
From TERPS section 6:
NOTE: The published minima lines will identify required RNAV sensors; e.g.,
LPV, LNAV/VNAV (includes degraded WAAS and Baro VNAV), or LNAV (includes GPS
and WAAS without glidepath). A single RNAV
approach will be published depicting LPV and/or LNAV/VNAV, and/or LNAV
minimums where they share the same courses and altitudes.
I read this to say that if a CNX-80 is approved for WAAS approaches then it
could fly a current published RNAV (GPS) approach to VNAV minimums.
Again, however, I am unclear from UPSAT's data on its website and manuals
what the actual approved status is for the CNX-80.
www.flyimc.com
Old July 16th 03, 03:09 PM
Mike Rapoport
I don't know if "behind" is the right word. Garmin has had WAAS on numerous
products for a couple of years now. There are valid reasons to try to have
the best product on the market instead of the first product.
MU-2
"Richard Kaplan" wrote in message
news:6823bf21e87c61799d150096f329071b@TeraNews...
Garmin's website now says they are "committed" to providing WAAS GPS
approach capability for the 400/500 series by the "end of 2004."
UPSAT's site states that their CNX-80 is WAAS approved now but I cannot
find
an explicit statement that it supports WAAS approaches at this point.
Does anyone know for sure if the CNX-80 supports WAAS GPS approaches
*now*?
In any event, can Garmin really be that far behind the curve as to plan
WAAS
only fo rthe "end of 2004"? This seems very much atypical for Garmin and
almost an embarrassment for them.
www.flyimc.com
Old July 16th 03, 04:02 PM
Tarver Engineering
numerous
have
Garmin is behind because Upsat did the sensor merging on their own
initiative. I stood right there and watched the Transport Directorate say
"no" to the idea and FAA's chief scientist start running numbers in his
head. UPS was on the phone before the smoke break ended. WAAS alone could
not add any new services to existing GPS.
John P. Tarver, MS/PE
Old July 17th 03, 01:43 AM
Richard Kaplan
"Tarver Engineering" wrote in message
could
So are you saying that the CNX-80 is approved or will be approved to fly
approaches which the Garmin 530 never will be able to fly?
And are you saying in fact that the Garmin 530 will never be approved to fly
VNAV, LPV, PV, or other approaches with lower minimums than current GPS
approaches?
www.flyimc.com
Old July 17th 03, 05:44 AM
Tarver Engineering
could
Garmin has already announced plans to upgrade the 530. Garmin has also
announced plans to make the 530 a fully TAWS compliant display, as well. I
know some repair stations that are just barely getting by on TAWS
installations and they hope Garmin takes a long time to make the release.
fly
approaches?
No. I am writing that Garmin is now going to have to play catch up.
John P. tarver, MS/PE
