#21
("Jim Burns" wrote)
Hope the alternator itself isn't toast! "Montblack" wrote: That's a half-baked assumption. Like those Capital One ads ...No, No, No. Any way you slice it, it's always the ground. ...cheaper that way. g Just be careful not to fry it. |
Oh, now you're talking like a man with only 1/2 a loaf!
![]() Jim "Montblack" wrote in message ... ("Jim Burns" wrote) Hope the alternator itself isn't toast! That's a half-baked assumption. Like those Capital One ads ...No, No, No. Any way you slice it, it's always the ground. ...cheaper that way. g Montblack |
![]() Clean all the grounds. The alternator ones, the regulator ones, the frame to engine one... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
("Jim Burns" wrote)
Oh, now you're talking like a man with only 1/2 a loaf! ![]() Are you implying I'm light in the loafers? Montblack Loafing around the house today |
Hmm.... if the shoe fits!! lol
![]() Jim "Montblack" wrote in message ... ("Jim Burns" wrote) Oh, now you're talking like a man with only 1/2 a loaf! ![]() Are you implying I'm light in the loafers? Montblack Loafing around the house today |
"Jay Honeck" writes:
2) In steady-state flight, both of us hear a "woo--woo--woo..." softly in the headphones. It sounds just like strobes that aren't grounded properly. .... 6) Turning the alternator side of the split master switch ALSO makes the noise go away. It sometimes stays away when I turn the alternator back on. Sometimes it doesn't. After you clean all the grounds... C) Others mention the split master. Does it feel warm at all? Since its brothers have been found guilty before; it's a good suspect even if stone cold. Wonder if there is a safe way to bypass it long enough to make a test flight. I'd say just replace it, but know that a $5 switch like that becomes a $500 switch once annointed with FAA Holy Oil. B) The skyranch URL sounds like the Right Stuph. A) This does NOT sound like a blown alternator diode to me. The 'pulsing' from that is in the kiloHertz range; this sound like it's more like 0.5 Hz. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Jay Honeck wrote:
See: http://www.sacskyranch.com/altnoise.htm Awesome source -- thanks! And located just down the road from me! -- Jack Allison PP-ASEL-IA Student Arrow N2104T "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
![]() C) Others mention the split master. .stuff snipped I'd say just replace it, but know that a $5 switch like that becomes a $500 switch once annointed with FAA Holy Oil. Actually, that split switch for Jay's plane is a fooler. I bought the official Piper part from Des Moines Flying Service (DMFS.com) a couple of years ago and I remember it being less than $50. Some day I actually have to INSTALL IT! I like the idea of the "Bypass wire" test. I could do it on the ground because my Cherokee does this all the time. Good Luck, Mike |
#29
![]() "George Patterson" wrote in message news:Q%7ff.60$N44.3@trndny08... snip Alternator problem. Possibly a filter, but my guess is a diode is going bad. snip Diodes are solid state devices which either work, are open (most common failure), or are shorted out (less common failure). They don't suffer from "going bad" or "getting weak". They either work or they don't. If they are intermittant, it's a connection, not the diode itself. DB (Many years of Electronics experience) |
#30
"Doodybutch" writes:
Diodes are solid state devices which either work, are open (most common failure), or are shorted out (less common failure). They don't suffer from "going bad" or "getting weak". They either work or they don't. If they are intermittant, it's a connection, not the diode itself. Well, maybe... I have had some larger power diodes whose *internal* bonds would open when the diode got hot. When it cooled again, guess what. I also had a matrix of small-signal glass diodes that tested just fine with an ohmmeter, but in operation.... turns out some would "zener" when tested with the 12v that was used in the circuit. But I really doubt that Jay's issue is alternator diodes.... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Logging time on a PCATD | [email protected] | Instrument Flight Rules | 3 | December 18th 04 05:25 PM |
FAA Application -- kinds of time | Gary Drescher | Instrument Flight Rules | 5 | November 23rd 04 02:33 PM |
FS9 Time Zone Files in BETA Test | DDT | Simulators | 3 | April 5th 04 06:06 PM |
Retroactive correction of logbook errors | Marty Ross | Piloting | 10 | July 31st 03 06:44 AM |
