Is EAA Working on an STC for Ethanol-laced MoGas?
Old November 25th 05, 03:07 AM posted to rec.aviation.piloting
Default Is EAA Working on an STC for Ethanol-laced MoGas?
Earl, while I respect and admire you for your work in the EAA and on the
ASTM committee on the the autogas subject, as the secretary (whose mission
statement is generally to accurately report the proceedings of the group) I
respectfully note:
automotive gasoline (ASTM D4814) with 10% ethonal added. Other
ethanol
to a fuel containing 10% ethonal. The aircraft that was tested failed
ethanol
EAA concluded that the modificiations needed to address the issues we
modifications
modifications were made the aircraft may still fail the requered
required
To assure you that EAA does not have some kind of biasis against
bias
ethonal fuels the same test concluded that an aircraft with some
ethanol
modification the aircraft could be certificated to a 100% ethonal fuel.
ethanol
The chemistry of a 10% ethonal 90% gasoline fuel is a dificult one to
ethanol difficult
in. Particularly when you are dealing with exsisting aircraft that
existing
incetive, from the manufacturers standpoint, to design such an aircraft
incentive manufacturers'
fuel. One test showed corrosion in electronic bost pumps that lead to
boost
eletrical arching in the pump itself. This condition discovered during
electrical arcing
tests and to EAA's knowldge has not ever occured on an certificated
knowledge occurred
we should consitrate our efforts on in other areas. EAA continues to
concentrate
both avaition and automotive fuels specificaitons. I currently serve
aviation specifications
as the secretary of the avaition gasoline subcommittee.
aviation
I hope everyone who reads this understand that it is not practicle to
understands practical
operate an older aircraft on a autogasline with 10% ethonal at this
auto gasoline ethanol
afordable, accessable and safe for recreational aviaiton. EAA
affordable aviation
make fuel more afordable for recreational aviation. The Autogas STC's
affordable STCs
has saved aircraft owners millions of dollars over the years and EAA
have saved
Earl Lawrence
EAA
V.P. Industry and Regulatory Affairs
Jesus Murphy, my EAA dues are going to pay a VP of EAA as illiterate as
this? Not only that, but he is my representative on the ASTM autogas
committee? No wonder we are in the bind that we find ourselves.
I want a public answer from the EAA management why a person of this dubious
literacy is allowed to represent me and my fellow members on high level
government committees and task forces.
Old November 25th 05, 03:35 AM posted to rec.aviation.piloting
Depends on class. Top fuel runs nitro, but there is an alchohol class.
They burn about 10 gallons in 7 seconds, BTW. High pressure and BIG
nozzels. The reason for alchohol is cost. Not of the fuel, but of the
engine. Engines that can run nitro are very expensive to build and
maintain. Any garage mechanic can work up an alchohol engine, well
maybe not any, but it puts in within the reach of a hobbyist with
limited bux.
Old November 25th 05, 04:04 AM posted to rec.aviation.piloting
But isn't it methanol, not ethanol?
George Patterson
We don't stop playing because we grow old. We grow old because we stop
playing.
Old November 25th 05, 04:54 AM posted to rec.aviation.piloting
"Doug" wrote in message
limited bux.
His point was that the subject is ethanol, and dragsters run on methanol.
Both alcohol, but not equal.
I hope I haven't consumed any methanol today, anyway!g
Old November 25th 05, 05:29 AM posted to rec.aviation.piloting
Mr. Lawrence,
Thanks for weighing in. Can you provide some links where the results of these tests are archived? I'd like to learn
more about ethanol as a fuel. A previous poster mentioned an exhibition airplane running on ethanol. I also recall
this bird and it seems I saw it fly at Oshkosh, circa 1997. It seems that it was a black fabric biplane with green
trim? I also ran across this: "But MOTHER's researchers weren't the only ones at the 1980 Fly-In who were piloting
vehicles powered by renewable fuel. Paul Poberezny (the EAA's "chief") was there to greet us with his "Pober Pixie"
airplane, which had been converted to ethanol the previous summer. " while doing a Google search. It seems that
corrosion issues can be handled with additives.
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
I can not provide a internet link to the test data, some of the tests
were EAA tests, some FAA tests, other tests have been published in SAE
papers, and still others are published in ASTM research reports none of
these are available on-line. The black fabric aircraft you saw
previously was Max Schauck's aircraft in the late 1990's he was running
the aircraft on ETBE and ether made from ethanol. The aircraft was
flown from show to show on 100LL and then he would do the show using
the ETBE. This was done, the use of 100LL, as you just can not pull up
to the pump at an airport and get ETBE. Max also did a significant
amount of work on certificating aircraft engines to 100% ethanol which
as I pointed out is different from gasoline with 10% ethanol. As far I
as know no one has ever certificated an engine or an aircraft to use a
EAA and Cessna completed research on the use of ETBE as an aircraft
fuel and all tests indicated is was an excellent fuel. But ETBE and
MTBE have no been outlawed in many parts of the US do to concerns of
contaminated water sources from ethers such as MTBE.
I will repeat to readers of this thread that EAA has never said that
one cannot convert an aircraft engine or an airframe to use 100%
ethanol. What we have said is that we were unable to certificate an
aircraft with the use of a gasoline with 10% ethanol. Aircraft and
aircraft engines have been certificated to use 100% ethanol. Also
remember getting an aircraft to work using a particular fuel is not the
same as getting it certificated to use that fuel. Certification
testing covers a wide range of conditions that some aircraft may never
see but must be addressed if we are going to let Type certificated
aircraft use the fuel. Remember an STC for a fuel would allow that
aircraft to fly with paying passengers at night, IFR in bad weather, in
the most extreme conditions e.g. Alaskan winter or Saharan Summer, so
the STC tests must cover all know operating conditions.
Earl Lawrence
Old November 25th 05, 05:43 AM posted to rec.aviation.piloting
It is good to see your manners are as good as they always have been.
Happy thanksgiving.
Earl
Old November 25th 05, 06:41 AM posted to rec.aviation.piloting
Uh oh, methanol vs ethanol thing. You know, I'm not sure.....
Old November 25th 05, 06:45 AM posted to rec.aviation.piloting
Drag racers run on methanol.
  #29
Old November 25th 05, 06:17 PM posted to rec.aviation.piloting
In article .com,
But drag racers usually tear everything down after one or a few more
races! That is not the same as exposing fuel systems to constant
immersion in alcohols.
Remve "_" from email to reply to me personally.
  #30
Old November 26th 05, 12:11 AM posted to rec.aviation.piloting
Mr Weir
Sometimes you carry that EAA chip on your shoulder to truly ridiculous
levels. Mr Lawrence has posted a detailed, informative and totally
understandable reply to the questions raised. He did so on
Thanksgiving Day... If you can't find it within yourself to recognize
that these are actually COMMENDABLE traits in an EAA employee, for
goodness' sake don't go on the attack about it. You really do come
across as a keyboard warrior of the pettiest kind.
Paul Stuart
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Home Built 82 May 19th 05 02:49 PM
MoGas Long Term Test: 5000 gallons and counting... Jay Honeck Owning 87 May 19th 05 02:49 PM
Mogas and microbial growth Economic Girly Man Owning 6 November 13th 04 09:14 AM
Air Force Working to Combat Stressors Otis Willie Military Aviation 0 September 18th 04 03:54 AM
Air Force Museum Working Group to release final report Otis Willie Military Aviation 0 November 18th 03 12:28 AM
