Flight plan equipment suffix
Old November 29th 05, 02:31 AM posted to rec.aviation.piloting
Default Flight plan equipment suffix
"abripl" wrote in message
I have no reason not to use it.... I use it all the time - just not for
IFR since I am not IFR rated. But from the comments I see that I can
continue indicating /G for my VFR flights even if the GPS data is not
current. So I think my question was essentially answered.
The AIM doesn't even mention filing an equipment suffix for a VFR flight
plan. For block 3 of the flight plan form it says only, "Enter the
designator for the aircraft, or if unknown, consult an FSS briefer." For
IFR flight plans it says, "It is recommended that pilots file the maximum
transponder or navigation capability of their aircraft in the equipment
suffix. This will provide ATC with the necessary information to utilize all
facets of navigational equipment and transponder capabilities available."
Old November 29th 05, 02:50 AM posted to rec.aviation.piloting
Visual Flight Rules
ink.net...
"Michael Ware" wrote in message
m...
What is relevant here is that the OP has stated that he is VFR only. He
cannot use the GPS for his primary means of navigation, regardless of
make/model of the GPS, the status of the database, or what equipment
suffix
he uses when he files.
Why not?
Old November 29th 05, 03:21 AM posted to rec.aviation.piloting
FAR 91 does not require equipment suffix either for VFR or IFR. In your
above quote (reference?) it says "recommended" (not "required") in
order for ATC to have more info for the IFR flight since ATC is more
likely to deal with IFR than VFR. Nowhere it says that equipment suffix
for VFR is not required or not recommended or forbiden. FAR 91 does
mention use of "full blown IFR GPS" for VFR use. When ATC does deal
with VFR the suffix may be helpful - as was in my one case with a
briefer.
Old November 29th 05, 04:24 AM posted to rec.aviation.piloting
m...
Visual Flight Rules
He cannot use the GPS for his primary means of navigation, regardless of the
make/model of the GPS, the status of the database, or what equipment suffix
he uses when he files, because he's operating under Visual Flight Rules?
What are you basing that on?
Old November 29th 05, 04:34 AM posted to rec.aviation.piloting
Correct.
FAR 91 does
Where?
When ATC does deal
briefer.
ATC does not have any briefers.
Old November 29th 05, 05:02 AM posted to rec.aviation.piloting
FAR 91 does
Where?
Its actually in AIM 1-1-19-b-1 "...GPS navigation under VFR are varied,
from a full IFR installation..."
Old November 29th 05, 05:24 AM posted to rec.aviation.piloting
I don't see "full blown IFR GPS" anywhere in that subparagraph.
Old November 29th 05, 06:33 AM posted to rec.aviation.piloting
You heard of paraphrase?
Last person making comments wins.
  #29
Old November 29th 05, 11:25 AM posted to rec.aviation.piloting
You're right, substitute the word 'sole' for 'primary'.
nk.net...
m...
Visual Flight Rules
suffix
  #30
Old November 29th 05, 01:13 PM posted to rec.aviation.piloting
What is the purpose of quotation marks?
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
