Small turbines for homebuilts?
Old November 28th 05, 07:35 AM posted to rec.aviation.homebuilt
Default Small turbines for homebuilts?
Has there been any development of small jet engines for light aircraft, like
the engines used on the Eclipse 500? Small turbines would be great for high
performance homebuilts if they were cheap enough. Anything down to the
price level that could compete with high horsepower Lycoming's or
Continentals? Thanks,
David
Old November 28th 05, 11:57 AM posted to rec.aviation.homebuilt
David,
Not competing with high horsepower output like your top Lycombings or
Conti;s but interesting nevertheless.
Check out http://www.tjt.bz/ as these engines are being used very
successfully in gliders at the moment. No idea on performance figures, fuel
burn etc.
Chris
Old November 28th 05, 02:25 PM posted to rec.aviation.homebuilt
"ventus2" wrote in message
David,
fuel
burn etc.
Chris
These little centrifugal turbojets are very inefficient consuming about
10GPH of Jet A for 50 pounds of thrust. Still, they are very cool.
Efficiencies are getting better so there's hope. I keep hearing rumors of a
8" diameter turbofan that would halve the fuel consumption.
Even today, they are a very interesting when applied to gliders. 50 pounds
of thrust would push my glider along at about 120 knots - probably a lot
more at high altitudes. Since it already has 75 gallon tanks in the wings
normally used for water ballast that could easily be converted to fuel
tanks, the range would be impressive. The airframes' aerodynamic efficiency
offsets the inefficient engine.
The engines tiny size and weight makes it easy to retract the engine into
the fuselage when flying as a glider.
Bill Daniels
Old November 28th 05, 03:43 PM posted to rec.aviation.homebuilt
David,
fuel
burn etc.
Chris
There 30lb thrust model specs at 5.5 gal/hour (350ml/min) which isn't
horrible for a jet. At speed 30lb is roughly 30hp so it takes 3.3 times to
get 100hp so 18 gal/hour which is about 3 times more fuel than a ricip but
it sure could be a lot of fun ;-)
John
Old November 28th 05, 04:01 PM posted to rec.aviation.homebuilt
"John" wrote in message
David,
fuel
burn etc.
Chris
John
If I recall correctly, one pound of thrust = one HP at around 325 knots.
That's quite a bit of 'at speed'.
Old November 28th 05, 04:36 PM posted to rec.aviation.homebuilt
to get 100hp so 18 gal/hour which is about 3 times more fuel than a ricip
but it sure could be a lot of fun ;-)
John
That sounds about right, I didn't have the figures in front of me. Even so
if you slowed it down to 150-200 you'd still have a fairly potent engine
for the weight. And it still would be a blast!
John
Old November 29th 05, 01:19 PM posted to rec.aviation.homebuilt
This ha actually been done here in Sweden. Two "model size" turbojets
atop the fuselage of a two-seat glider. Not enoug thrust for take-off
but plenty of power to fly home in marginal conditions to avoid an
"out" landing. I beleive they quoted 1-2 m/s climb rate.
Old November 29th 05, 01:32 PM posted to rec.aviation.homebuilt
...Not enough thrust for take-off ...
If your plane is small enough...
http://flight.cz/cricri/photos/unsor...10_gallery.jpg
Piero
Old November 29th 05, 11:05 PM posted to rec.aviation.homebuilt
I believe that plane lifted off from the roof of a speeding car, so really,
not enough to take off. Perhaps if you had a very very long runway? g
Old November 28th 05, 04:05 PM posted to rec.aviation.homebuilt
The most dependable, at the moment, are these
http://www.amtjets.com/
The top model gives 51,7 pounds of thrust.
I've seen many of them "At work" on RC models. Amazing.
Piero
Getting rid of turbines. (grin) ArtKramr Military Aviation 15 December 6th 03 05:25 AM
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! Small Blue Planet Toys Aviation Marketplace 0 October 15th 03 05:26 PM
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble Small Blue Planet Toys Aviation Marketplace 0 July 11th 03 04:00 PM
HUGE Summer SALE + Free Shipping @ Small Blue Planet Toys Small Blue Planet Toys Aviation Marketplace 0 July 8th 03 11:53 PM
