GPS and old-fashioned thinking?
Old December 3rd 05, 11:32 AM posted to rec.aviation.ifr
Default GPS and old-fashioned thinking?
says...
I think the only problem with GPS is the human interface.
I disagree. I think there is a more important problem. If you're flying direct
routes and RNAV with GPS as primary(and only random route) source of
navigation, in the event of a GPS signal degradation, you have a bit of a
balancing act to do to get back to "legacy" navigation. If you're in the
middle of the Great Plains that's no issue, but if you're shooting an approach
to White Plains it may be.
My point is we were on the way toward an integrated RNAV system until GPS came
along and we decided we have to hurry and trash everything else. What we need,
I believe, is an RNAV system which allows us to seamlessly maintain random
route navigation in the event of a primary source failure (GPS). eLoran would
be one possible answer, but so would existing ground-based (VOR-DME) systems,
if your box is programmed for this.
The "all-or-nothing" approach to GPS (I know this is an exaggeration - but
only a slight one) is contrary to everything we learn and practice in aviation
- where we're supposed to have an answer, and hopefully a good answer, to
every eventuality.
I love GPS, and I see no problem in being highly reliant on it, because it is
intrinsically reliable - however I believe it would be practical and desirable
to build a system that maintains full RNAV capability in the event of a loss
in GPS integrity.
G Faris
Old December 3rd 05, 11:38 AM posted to rec.aviation.ifr
john smith wrote:
Knowing EXACTLY where I am at all times and being able to direct to
pretty much everywhere (just the prohibited and restricted airspaces,
oh and TFR's to go around), save time, money and fuel.
And you cannot do that with a map and compass?
A *real* pilot doesn't need a map or compass -- that kind of technology
just makes you too lazy to fly low and read highway signs.
All the best,
David
Old December 3rd 05, 11:47 AM posted to rec.aviation.ifr
Wouldn't you be in the same situation if you were shooting an ILS
approach and the localizer went U/S?
All the best,
David
Old December 3rd 05, 01:00 PM posted to rec.aviation.ifr
"Doug" wrote:
Also, it makes flight planning a breeze. No legs to figure. Just click
in your route, check for restricted/prohibited airspace and TFR's and
go direct!
It helps to take a glance at the terrain too. I've got a flight planning
exercise I give to people to plan a trip to a destination on the other side
of what passes for a mountain range around here (the Catskills). I'll give
them a weather forecast with ceilings just about at the mountain tops.
It's amazing how many come back to me with "GPS direct" and seem to be
totally clueless that they've just planed a trip into cumulogranite.
Old December 3rd 05, 01:04 PM posted to rec.aviation.ifr
it is intrinsically reliable - however I believe it would be practical
and desirable to build a system that maintains full RNAV capability in
the event of a loss in GPS integrity.
The big boys have it, it's called Inertial Nav. Whether that will ever
become an affordable reality for GA is anybody's guess, but stranger things
have happened. With the current crop of GPS gear on the market, there are
already spam cans equipped with better nav systems than some jets.
Old December 3rd 05, 03:37 PM posted to rec.aviation.ifr
Here is something you have with a GPS that you don't have with most
other Nav -- GROUNDSPEED. (Yes you can get it if you have DME and are
flying to/from the station). How does that help? Helps with fuel
planning and time. Will you be flying at night or will you make it
before nightfall?
I once used GPS for deciding if I should attempt flying ridge lift. I
was heavily loaded in my Amphib. I can climb to 13000' I need to get
over Corona, but its not easy. Usually there is a west wind causing
ridgelift as you fly west to east. As I climbed, it was apparent that I
wasn't going to make it without circling. But...that west wind..IF I
was SURE it existed. So I turned into the wind (my destination was
east) to make sure and checked my GS with my airspeed. Sure enough it
was there. I went close to the ridge (so close you didn't want to be
there if there were downdrafts), and the wind just lifted me right up
and over the pass. WAY COOL!
Old December 3rd 05, 04:19 PM posted to rec.aviation.ifr
in GPS integrity.
You're thinking in light aircraft terms. All modern air carrier jets and
biz jets have IRUs, which will provide a decent RNAV platform for a
reasonable length of time in the terminal area and for a very long time
en route.
