Turbine Duke or turbine Baron?
Old December 12th 05, 06:20 PM posted to rec.aviation.piloting
Default Turbine Duke or turbine Baron?
("Thomas Borchert" wrote)
There's also a guy in Germany working on a conversion of the Duke to
twin Thielert diesels - the big ones doing 350 HP. He's got one flying.
See http://info.thielert.com/centurion/m...php?newsid=340
(From the link)
"The Centurion 4.0 of the GmbH Thielert Aircraft Engines is a V8-engine with
state-of-the-art technology, and in the twin it replaces the initially
built-in Lycoming IO-541-E1C4 which is not produced anymore. Furthermore the
manufacturer discontinued the product support for the IO-541-E1C4.
In comparison the diesel conversion weighs 20 kilograms (50 lbs) less. The
entire consumption was 22 gallons of kerosene per hour, which sums up to 8
gallons less fuel consumption. For this reason the range of the Duke
increases from 1100 Nautical Miles to 2000 Nautical Miles."
Huh? So the Duke was getting 15 per side (30) and now gets 11 per side (22)?
30 gal x 6 lbs = 180 lbs fuel/hr ...Avgas
22 gal x 7 lbs = 154 lbs fuel/hr ...Diesel (Saving 26 lbs/hr fuel weight)
I don't see how that almost doubles the Nautical Miles? Six hours of diesel
flight gets you a free hour. (6 hrs x 26 lbs/hr (saved) = 156 lbs)
Add in the diesel conversion saving of 50 lbs? I still don't get it.
If there was an increase in speed, I would think Thielert would want that
little extra bonus fact front and center.
Montblack
Old December 12th 05, 06:28 PM posted to rec.aviation.piloting
A lot of small businesses bought Dukes and hired the
cheapest high time pilot they could find, usually it seems
that was a retired B47/B52 Colonel who didn't know better
than to slam the throttles open - closed just like he did in
those other airplanes. The Dukes that I saw, that were
flown by civilian trained pilots usually flew pretty trouble
free to TBO. The ones that were flown by retired jet jocks
needed turbo replacement at 600-800 hours and new cylinders
at 1,000. They saved a buck on the salary and spent a ton
on maintenance.
James H. Macklin
ATP,CFI,A&P
of the Duke to
got one
| flying.
| I read the article - wow that's a huuuuge bump in range
over the
| gassers eh? Didn't know Lyc wasn't supporting the TIO-541
anymore (I
| think the P-Navajo has the same engine?) but doesn't
surprise me as
| I've heard they're quite finicky and must be babied more
than most high
| HP turbo'd piston engines.
Old December 12th 05, 06:42 PM posted to rec.aviation.piloting
My favorite turboprop is the 300 King Air because all of the
little hold over plumbing problems were fixed. It was
stable, the flight controls were smooth and well harmonized.
The CG range and gross weight were nearly impossible to
exceed unless you were flying lead or gold. It had the
ability to fill all the seats with grown men, top all the
tanks and fly 2,000 miles and be in the VG at take-off and
landing, don't try that in a Cheyenne 400.
The early A90 King Air used combustion heater just like a
Queen Air, and the operation of the fuel system involved the
pilot properly setting the system before take-off and
monitoring the operation. A Transport Canada King Air was
lost because the pilot was not setting the fuel boost pumps
to auto before take-off. When the fuel level in the nacelle
tank drops through the set level, the boost pump comes on to
refill the nacelle. On the early airplanes if you didn't
arm the system before the signal, it would not turn the pump
on automatically. Later airplanes fixed that silly design
flaw, the pump will come on anytime the level is low and the
pump is in auto.
The trick the CDOT pilot didn't know or forgot was to "test"
the boost pumps when he decided to manually refill his
nacelle tanks. Of course he was violating the operating
procedures and AFM, but what the Hell, all pilots are
perfect.
James H. Macklin
ATP,CFI,A&P
k.net...
| Everything I have heard about the Duke is consistant with
your statements
| and certainly a turbine Duke is better than a piston Duke.
Piston twins
| have some of the high reliability systems of the
turboprops, but the factory
| turboprops have *all* of them. I would even go so far as
to say that the
| factory turboprops that started as pistons (King Air 90,
Conquest, Cheyenne
| and Meridian) are inferior in a number of ways to the
airplanes that were
| designed for turbine power from the beginning. Ultimately
airplanes are
| flying sets of compromises between cost, weight,
robustness and utility and
| designers choose different compromises when the airplanes
are powered by
| turbines instead of pistons.
| Mike
| MU-2
| "Jim Macklin" wrote
in message
| newszfnf.28446$QW2.15610@dukeread08...
| The Duke does have a dual bus system, a real hot
windshield
| and plenty of room in the panel. The control systems
were
| designed for operation at altitude and there is a lot
more
| cabin room. The Duke's biggest failing is that it is
heavy
| and the big Lycoming engines are easy to abuse. But
doing a
| conversion when there are a number of "better"
turboprops on
| the market seems a waste of money. Seems more sensible
to
| buy a decent airplane, such as a King Air and refurb it
with
| interior, avionics and new paint. The Duke is old, will
be
| as expensive to operate as a King Air and is one of the
best
| looking Beech aircraft built.
message
nk.net...
| | wrote in message
| | For the same money, you could buy a Mitsubishi
| Solitaire and go faster
| | with
| | a larger cabin and (probably) more reliable
systems
| | How much faster are we talking here? Never flown in
an
| MU-2, but I've
| | heard they can be a handful and there are plenty of
NTSB
| reports on
| | Mitsu accidents. I read recently about the FAA
looking
| into the recent
| | accidents with these planes. May very well be
related to
| training
| | issues but the plane seems to have a rep, kinda like
| Aerostar did
| | years back IIRC. I think I'd feel more comfortable
with
| a conventional
| | aileron/flap than the spoiler. As far as systems
| reliability, not sure
| | why you think there'd be an appreciable
difference(?)
| | Wooly
| | The Solitair will go 315kts and has a Vmo of 250KTIAS.
| What is the
| | accident record on turbine Baron's and Dukes? They
are
| going to have the
| | same problems as other high-performance-owner-flown
| aircraft. The problem
| | is pilots that fly ~100hrs/yr when fatigued and in bad
| weather and often
| | don't get enough training. I think the TBM 700
actually
| has the worst
| | accident record of any turboprop. How many pilots who
| just paid over $2
| | million for their TBM get failed in initial training
| (zero). They get
| | signed off and then go crash. If the same pilots
could
| try flying Learjets
| | single pilot, they would crash even more. Give them
F104s
| and they would
| | all be dead. I suspect that when the big training
centers
| lose a few more
| | lawsuits this may change (hopefully).
| | There is no difference in handling between ailerons
and
| spoilers except that
| | spoilers are more effective at low speeds. Two pilot
| crews of Beachjets
| | aren't crashing or complaining about the spoilers on
their
| airplanes. The
| | MU-2 does have a bad rep even though its accident
record
| is middle of the
| | turboprop pack.. The current investigation is
political
| (the FAA
| | acknowledges this) and includes several CFIT, gear up
| landings and even a
| | crash into a ground vehicle on the runway. The whole
| notion that an 18
| | month spike in accidents with no common cause could be
| attributed to the
| | design of an airplane that has been flying over 35yrs
is
| crazy since the
| | design of the airplane didn't change! The conclusion
will
| be (again) that
| | the pilots who do not undergo frequent recurent
simulator
| training have
| | accident rates 10x the pilots who do. I wish that my
| government wouldn't
| | waste my money tilting at windmills. Almost all the
| accidents whether
| | Skyhawk, MU-2, Super Cub or anything else are pilot
error.
| The more capable
| | airplanes get flown into more weather over longer
| distances and are often
| | flown for business where there is pressure to get
there
| and back on time.
| | The high-performance-owner-flown aircraft gets all
these
| increased risks but
| | no two-pilot professional crew. The lower performance
| aircraft don't get
| | flown halfway across the country in large thunderstorm
| complexes by tired
| | business people at the end of a long day. My own
| situation is that every
| | flight in the MU-2 is over mountains, at night in the
PNW
| where the weather
| | is often bad. In contrast, I have never flown the
Helio
| at night and only
| | once in IMC because there are no Helio flight where I
| *have* to get there.
| | Generally, you will find that aircraft originally
designed
| for turbines will
| | have better *everything* from structure to avionics to
| systems like heated
| | glass windshields (instead of narrow "hot plates),
full
| dual-bus systems,
| | remote electric gyros, bearings instead of bushings
ect..
| It isn't just the
| | engine that make a TBM cost more than a Malibu, it is
a
| whole host of
| | improvements.. They can incorporated these things
because
| the airplane has
| | so much more power that some weight can be traded for
| better, higher
| | reliability, systems. When you do a conversion you
get a
| piston airplane
| | with turbine engines. I am certainly not against
| conversions, I am
| | contemplating a turbine in my Helio but the reason I
am
| thinking about it is
| | that there is no aircraft with comparable performance.
If
| there where, I
| | would prefer to buy the proven, tested, solution.
| | BTW The most effective turbine conversions tend to be
| radial engined
| | airplanes like Otters, Beavers, the various Grumman
flying
| boats and DC3s.
| | The greatly improved aerodynamics from getting rid of
| draggy radial
| | overcome the thirsty turbine engines. Of course they
| don't sound as
| | good....
| | Mike
| | MU-2
Old December 12th 05, 06:43 PM posted to rec.aviation.piloting
("Montblack" wrote)
(22)?
diesel flight gets you a free hour. (6 hrs x 26 lbs/hr (saved) = 156 lbs)
Is it 30 gals ...per side? Turbo'd!
So now it's every "three" hours you get a bonus hour of fuel. Will that get
you an extra 900 Nautical Miles?
Does "entire consumption" mean per engine or ...entire, as in both,
combined? Now I don't know what "sum" means either. Oh well.
Montblack
Old December 12th 05, 08:59 PM posted to rec.aviation.piloting
The Dukes that I saw, that were flown by civilian trained pilots usually flew pretty trouble free to TBO.
Another BS hangar myth destroyed. I've heard the same of the Cessna 421
from a few guys who've owned/flown them. Most of what I'd heard
previously about that type was the turbo'd & geared Contis were a
complete pain in the arse and would never make TBO without new jugs or
worse. I guess ya gotta question just how qualified somebody is when
they start talking trash about airplanes & engines, huh?
Wooly
Old December 12th 05, 10:27 PM posted to rec.aviation.piloting
There is some truth in many stories, but with any
turbocharged aircraft engine, allowing the temperatures and
clearances to normalize is critical. A turbo may be at
70,000-100,000 RPM, at 1400 degrees on one end of the shaft
and just a few hundred on the other. The cylinder heads may
be at 375-425 degrees and when you cut the power to idle the
heads shock cool, the turbo cools and that includes the
housing which can shrink faster than the impeller. The next
thing is that the housing and impeller make contact and
grind away. The turbo may spin for some time after
shutdown, without any engine oil pressure or flow. If the
pilot lands on the far side of the airport or stops on the
ramp/taxiway to allow the turbo to spin down and more
importantly cool, the oil will flow and cool the turbo
bearings and the oil won't fail (coke) extending the turbo
life. From 40-to 30 inches you can move the throttle
smoothly, but I would never go below 20 inches in-flight and
then not until I'd flown a minute at 25 inches. I used the
cowl flaps to keep the engine warm on approach and opened
them for all ground and T..O/climb operations. I used full
rich in the climb and I made sure to observe the TIT limits
as well as oil and cylinder temps.
I rarely flew any single airplane more than a dozen times,
but I saw many airplanes that were flown thousands of hours
by one pilot.
One thing about the Duke, I always made a modified soft
field take-off, using full back elevator until I got to
about 50 kts, then I'd fly the nose down to prevent a
premature take-off. The Duke sits with a negative angle of
attack and the engines will drive the nose down unless the
pilot lightens the load on the nose wheel. Take-off
performance is much improved with this technique.
James H. Macklin
ATP,CFI,A&P
some support
the Cessna 421
heard
were a
new jugs or
somebody is when
| Thanks,
| Wooly
Old December 13th 05, 07:50 AM posted to rec.aviation.piloting
On 2005-12-12, Mike Rapoport wrote:
Almost all the accidents whether
Skyhawk, MU-2, Super Cub or anything else are pilot error. The more capable
airplanes get flown into more weather over longer distances
And with more people on board. When I bought my Comanche I read a lot
of NTSB reports looking for patterns. What I saw was a higher percentage
of weather accidents, and a MUCH higher typical number of people onboard
in an accident. I used to think that insurance rates were
disproportionately high for 6 place airplanes. The reality is that a
Cessna 172 is a "one and a half" seater as far as insurance claims go,
while a Lance or Bonanza is a "five and a half seater".
Ben Jackson
http://www.ben.com/
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
Rick Stitt, Joe Rinke, Rinke Aerospace, BJ Schram, Mini 500, Turbine, Helicopter, Kit TurbineMini Richard Rotorcraft 2 January 24th 04 01:15 AM
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit TurbineMini Richard Rotorcraft 0 January 15th 04 11:48 PM
TRUTH OF THE MINI-500 TURBINE CONVERSION Dennis Chitwood Rotorcraft 10 January 7th 04 05:33 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
