De-icing
Old December 11th 05, 06:44 PM posted to rec.aviation.owning
Default De-icing
City Dweller wrote:
I am curious about it also, and want to know what people who own composite
airplanes do about that nasty ice crust .
How about applying a stream of hot air (a hair drier-type device)?
Please advise!
The danger here is that the water will run and refreeze somewhere else.
It is better to mix something with it that won't allow it to refreeze.
Matt
Old December 12th 05, 05:12 AM posted to rec.aviation.owning
Default De-icing
Last winter, after a nasty ice storm, we tried the hair dryer and it
was worthless. The wind just blew the tiny stream of hot air away. A
friend used a propane heater with a big heating duct and set up some
sort of a small hood to hold the hot air in, it worked for him.
Hai Longworth
Old December 12th 05, 01:17 PM posted to rec.aviation.owning
Default De-icing
Alchohol, hmm, I think ISOPROPYL alchohol (there are three kinds of
alchohol) works well. So does car windshield washer fluid.
Old December 12th 05, 02:58 PM posted to rec.aviation.owning
Default De-icing
There are many many many kinds of alcohol.
Old December 12th 05, 03:00 PM posted to rec.aviation.owning
Default De-icing
Doug,
We use isopropyl alcohol mixed for defrosting and for washing off
the slushes. By itself, it can not help to melt ice.
Hai Longworth
Old December 13th 05, 03:55 PM posted to rec.aviation.owning
Default De-icing
A correction: what I meant was that isopropyl alcohol by itself is
very ineffective against large amount, solid block of ice. It has
lower freezing point than water so it will dissolve the ice layer by
layer very slowly. To loosen up large block of ice, we use hot (not
super hot) water in a plastic bag as mentioned earlier.
Hai Longworth
Old December 12th 05, 05:56 PM posted to rec.aviation.owning
Default De-icing
Kobra wrote:
: So how to you all de-ice your planes and are my mechanic's fear justified on
: the use of auto anti-freeze?
I have a set of wing & tail covers by Kennon. The ice & snow just peels off.
Don't put the covers on when the wings are wet, though, as the fabric gets
stuck to the wing. Get a set of dark colored covers and the solar heating
will help clear the ice off the covers in no time - mine are maroon.
Aaron C.
Old December 12th 05, 09:58 PM posted to rec.aviation.owning
Default De-icing
Well I have two solutions...no pun intended ;-)
1) Automobile windshield washer. Good to -25, cuts ice, and works. Best for
the light stuff. I like to heat it.
2) Isopropyl Alcohol, sprayed on to cut the ice then apply with a different
sprayer RV antifreeze bought at Home Depot. I hear one could mix these two
together 50/50 and get a pretty good third solution that cuts and prevents
refreeze in one application. I would heat this one carefully ;-)
3) Most importantly, be careful of refreeze. Hot water is not enough!!
Bill Snow, PE, CP, IA, ASEL
Old December 13th 05, 01:33 AM posted to rec.aviation.owning
Default De-icing
To clear up a few points.
Both Alcohol and antifreeze and deicing solutions ( as well as salt, and
almost any other substance that dissolves in water ) lower the freezing
point of water. So both alcohol and antifreeze both effectively melt the ice
by lowering the freezing point to below the current temperature. Since the
sprayed solution only contacts the top layer of the ice, it melts it away in
layers. The idea that one only melts and the other only prevents refreezing
is an OWT. Using a heated substance will melt it faster because you
simultaneously raise the temperature and lower the freezing point.
Some mentioned that spraying hot water only on the plane is prone to
refreezing in a dangerous way. Sage advice.
Known Icing requirements Jeffrey Ross Owning 1 November 20th 04 03:01 AM
Icing Airmets Andrew Sarangan Instrument Flight Rules 51 March 3rd 04 01:20 AM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
Supercooled Water - More on Icing O. Sami Saydjari Instrument Flight Rules 50 December 11th 03 01:20 PM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
