Flying through known or forecast icing
Old December 15th 05, 07:00 AM posted to rec.aviation.ifr,rec.aviation.piloting
Default Flying through known or forecast icing
The general icing AIRMET always contains the qualifier "in clouds and
precipitation". You're perfectly legal if you stay out of the clouds
and precipitation.
Old December 16th 05, 02:43 AM posted to rec.aviation.ifr,rec.aviation.piloting
On Wed, 14 Dec 2005 16:33:31 GMT, George Patterson
John Doe wrote:
1) If the cloud layer is forecast to potentially have icing, can you legally
and would you climb through the layer to get up high for your trip? how
thick a layer, type of forecast, time spent in the layer, etc. What would
you be willing to risk transition through possible icing?
No. Legally, forecast ice is "known icing."
A bit of a distortion.
The phrase in the regulations is "known icing conditions". A forecast that
mentions icing satisfies this as the conditions (leading to potential) icing
are indeed known -- if you have read the forecast -- and you are required by
regulations to obtain all relevant information for the flight which includes
a weather forecast.
Many pilots try to parse the requirement as "known-icing conditions" whereas
the FAA has defined it to mean "known icing-conditions" -- a subtle but
inportant difference when it comes to defending oneself against a
certificate action. A forecast of icing constitutes "known
icing-conditions."
4) Let's say yoru trip starts off VFR but by the time you get to your
destination, a cloud layer has formed that has reported icing in it. Can or
or would you be willing to transit this layer to land at this destionation
or would you turn around or divert to land someplace to stay out of the
clouds?
If I want to stay VFR, I won't be transiting any clouds. Being unwilling to risk
a violation if I file IFR and then fly through reported icing, I would divert.
George Patterson
Coffee is only a way of stealing time that should by rights belong to
your slightly older self.
Jay.
(remove dashes for legal email address)
Old December 16th 05, 03:02 AM posted to rec.aviation.ifr,rec.aviation.piloting
"Jay Somerset" wrote in message
that
icing
by
includes
a weather forecast.
whereas
icing-conditions."
What you say appears to have been true in the past, but not currently. As
noted earlier in this thread, the FAA now defines the terms as follows:
"Forecast Icing Conditions--Environmental conditions expected by a National
Weather Service or an FAA-approved weather provider to be conducive to the
formation of in-flight icing on aircraft."
"Known Icing Conditions--Atmospheric conditions in which the formation of
ice is observed or detected in flight."
(AIM 7-1-23, http://www.faa.gov/atpubs/aim/Chap7/aim0701.html#7-1-23)
--Gary
Old December 14th 05, 08:28 PM posted to rec.aviation.ifr,rec.aviation.piloting
Tain't legal. The simple answer.
The more important question is: Can you figure out a way to do it
safely
so you don't draw attention to yourself?
For example... you never punch up thru a layer unless you have pilot
reports about
tops or you stay over a place that has wx good enough to get back with
100% certaintly if things go badly as you try to get on top.
As you go along, you must be sure you always have a 100% out. If it's
less than a 100%, you might get in a bad situation.
So you can operate not legally but with safety if you can figure this
out.
If you can't play out the whole solution, or don't have a continuously
updated 100% out, it's a no go.
On top is the answer in little airplanes. You don't start down until
you can get cleared the whole way down. You need good deals with
ATC to get this. Never descend thru a layer unless you have
reported weather underneath and are absolutely sure you can make
the approach. Search on N100KC for a dreadful example of violating
this idea.
The guys who claim they will never do this actually will when the
chips are down! So best is to think the problem through in great
detail rather than assume you will never do it.
Just one more thing: Always understand the wx well enough to
recognize the chance for freezing rain. It will bring you down! Night
time
makes this all much worse!
Bill Hale
Old December 14th 05, 08:44 PM posted to rec.aviation.ifr,rec.aviation.piloting
As you said, the answer 'depends' on how risk averse you are.
Legally, the answer is, you cannot climb into icing conditions
(forecast or reported) no matter how thin the layer is.
In reality, you can use some judgement in the decision. Is the freezing
level above the MEA? It is icing rime or clear? How thin is the layer?
ATC is not traffic cops. Their job is to keep you separated from other
traffic. They don't care whether you have de-icing equipment or not, or
whether you are complying with all the other FARs.
Old December 14th 05, 11:18 PM posted to rec.aviation.ifr,rec.aviation.piloting
John Doe wrote:
Ok, I know this is one of those "it depends" answers, but I'm curious as to
what folks are willing to do in the winter time.
Assumptions:
Single engine piston aircraft with NO de-icing equipment.
Situation:
It's wintertime. You want to fly XC and there are midlevel clouds in the
forecast with the potential for icing to occur.
It looks like the band is thin enough to climb through and cruise in the
clear above the weather.
SO:
I believe the recent interpretations is that this would be illegal as
the cloud layer at below freezing temps would constitute an area of
"known" icing and thus penetrating it would not be legal. As to what I
would do personally ... well, I won't answer that here! :-)
2) Would that change any if those same conditions were now reported icing
from a recent PIREP?
It would change my personal view of the situation, but I don't think it
changes the legality.
3) If it's reported, can you transit the cloud layer legally?
I don't believe you can do so legally.
clouds?
Again it depends, but if I had sufficient fuel, I'd probably divert. If
I was low on fuel, I'd descend through the layer.
Matt
Old December 15th 05, 05:19 PM posted to rec.aviation.ifr,rec.aviation.piloting
What if anything happens to the whole "known versus forecast" issue if there
is a pirep for "negative icing in clouds".
"Matt Whiting" wrote in message
to what folks are willing to do in the winter time.
Assumptions:
Situation:
SO:
legally and would you climb through the layer to get up high for your
trip? how thick a layer, type of forecast, time spent in the layer, etc.
What would you be willing to risk transition through possible icing?
I believe the recent interpretations is that this would be illegal as the
cloud layer at below freezing temps would constitute an area of "known"
icing and thus penetrating it would not be legal. As to what I would do
or or would you be willing to transit this layer to land at this
destionation or would you turn around or divert to land someplace to stay
out of the clouds?
Again it depends, but if I had sufficient fuel, I'd probably divert. If I
Matt
Old December 15th 05, 05:40 PM posted to rec.aviation.ifr,rec.aviation.piloting
Under current FAA/NTSB rules, nothing, the forecast stands
until officially amended.
The old joke, summer time forecast...
Chance of severe thunderstorms and tornadoes along and 1,000
miles either side of a line from 150 miles south of
Washington, DC to 300 miles north of San Francisco, CA. Tops
to FL600.
Winter forecast, same line from an unknown location to an
unknown location, with this...
Blizzard and whiteout conditions over the continent and
coastal waters, chance of moderate to severe icing from the
surface to FL240.
The forecast calls "wolf" so many times that pilots and
ground pounders became complacent. At least here in Kansas,
the new standard for issuing a "severe thunderstorm warning"
was changed for the 2005 season. They increased the size of
the hailstones and the winds that trigger a warning so there
would be fewer warnings.
Since Kansas can have steady winds of 25 to 40 knots and
higher gusts, without being associated with any storm, the
severe T storm warning of gusts to 60 mph didn't really
alert most locals.
James H. Macklin
ATP,CFI,A&P
"pgbnh" wrote in message
but I'm curious as
| Assumptions:
equipment.
| Situation:
and cruise in the
| SO:
icing, can you
high for your
in the layer, etc.
possible icing?
be illegal as the
area of "known"
what I would do
now reported icing
don't think it
legally?
you get to your
icing in it. Can
land at this
someplace to stay
| out of the clouds?
| Matt
Issues around de-ice on a 182 Andrew Gideon Piloting 87 September 27th 05 11:46 PM
Have you ever... Jay Honeck Piloting 229 May 6th 05 08:26 PM
Known Icing requirements Jeffrey Ross Owning 1 November 20th 04 03:01 AM
Wife agrees to go flying Corky Scott Piloting 29 October 2nd 03 06:55 PM
